McLaren MCL39
mwillems
46
Re: McLaren MCL39
There was a time not long ago that our little papaya car looked under developed. Just look at that suspension setup, it's like sculpture.
-Bandit
240
Re: McLaren MCL39
A simple curiosity of the 39 is also where the water slide starts on the side pod. It starts very much behind the cockpit compared to Ferrari and other teams. Some cars have none, like the Mercedes, others have it, but it starts closer to the front.
The brakes and suspension and flex wing would have you believe there is no devil in the details of the body.
Andi76
Andi76
451
Re: McLaren MCL39
McLaren used again a big tank, nearly 3-4
liters capacity filled with dry ice to be able
cool the cockpit for prologued time. In fact
the way MCL39 runs wears the skid block
further forward than most of the cars, right
under the cockpit area, increasing the heath
under the driver.
M840TR
M840TR
315
Re: McLaren MCL39
ringo wrote:
02 Jun 2025, 01:25
They introduced that design in Miami 24 to reduce drag.
Farnborough
Farnborough
124
Re: McLaren MCL39
Andi76 wrote:
02 Jun 2025, 21:05
https://postimg.cc/06vgwg1P
under the driver.
And soooo ...... 3 to 4 litres of dry ice capacity, unidentified "silicone" hose within rear brake assembly !
2+2=5 I'm surprised there's not any conspiracy theory floating around, anywhere.
I don't believe it's a system, but nobody talking about it at least just seems odd.
Pooler
Pooler
Re: McLaren MCL39
Farnborough wrote:
30 May 2025, 17:25
Good "witness" marks on rear tyres in above post, virtually even distribution from centre line for dust pickup, indicating they are set to VIRTUALLY zero static camber in presentation to track surface.
One of the ingredients in McL tyre wear/durability operational sphere.
Likely make the "decay" in ultimate lateral grip a little "pacey" which we see and hear from the drivers.
I wonder if this is also helps their thermal management of the core temp , less camber would reduce the camber thrust down the straights ultimately putting less energy into the carcass. McLaren seem to run less camber than other teams from what the eye can tell.
240
Re: McLaren MCL39
McLaren understand the tyres better than the other teams. They take more than just 1 lap to bring the tyres up to working temperature. I noticed this listening to Piastri and Lando's radio.
The car is probably very much biased to qualifying at the front, then managing the pace from there to bring in the tyres carefully, as counter intuitive as that sounds giving MCL39's strong tyre management and race pace.
mwillems
46
Re: McLaren MCL39
ringo wrote:
03 Jun 2025, 18:04
It's what Merc did, built a car that wasn't great in dirty air, and was designed to get in front and stay in front.
Worth mentioning too that the Mclaren did 2 fast laps on the same times in Q3 recently, setting the fastest times on the second having done a cooldown lap in the middle. Quite astounding.
-Bandit
.poz
.poz
51
Re: McLaren MCL39
Farnborough wrote:
03 Jun 2025, 14:52
Andi76 wrote:
02 Jun 2025, 21:05
under the driver.
i never heard of a team adding weight just to cool the driver....
btw If my memory serves me correctly, FIA said that cooling the brakes with a gas it's not against the rules
Andi76
Andi76
451
Re: McLaren MCL39
Farnborough wrote:
03 Jun 2025, 14:52
Andi76 wrote:
02 Jun 2025, 21:05
under the driver.
There is! An Italian on its Youtube Channel says:"Are they trying to pull our leg? 3 to 4 kg of extra weight so far away from the CoG to cool the driver? That serves a different purpose!" According to him, these 3 kg of dry ice are supposed to cool the tires... The theory that dry ice, which changes its state to gas at 5 degrees, is used to cool the tires says it all.
Macklaren
Macklaren
Re: McLaren MCL39
Andi76 wrote:
06 Jun 2025, 08:15
Farnborough wrote:
03 Jun 2025, 14:52
Andi76 wrote:
02 Jun 2025, 21:05
under the driver.
Waiting for a rival to brake check the McLarens in Canada because we are one nose change away from proving this thesis is another fantasy herring :roll:
Andi76
Andi76
451
Re: McLaren MCL39
Macklaren wrote:
06 Jun 2025, 18:47
Andi76 wrote:
06 Jun 2025, 08:15
Farnborough wrote:
03 Jun 2025, 14:52
This theory is so ridiculous that I don't think there's anything to worry about in this regard. A material weighing 3 to 4 kg that turns into a gaseous state at 5 degrees Celsius is supposed to keep four tires and brakes within the window for an entire race? That alone is completely absurd. The next question is: how is the gas supposed to get there to cool it? There are no pipes, units, or ducts that could transport it there. Therefore, this theory is so absurd in every respect that there is no danger of anyone with any sense taking it seriously.
.poz
.poz
51
Re: McLaren MCL39
Andi76 wrote:
07 Jun 2025, 10:23
this is pure speculation
let's assume they are cooling only rear wheels
it' 3-4 litres, dry ice density is about 1,5 so it's 4,5-6kg
6 kg of dry ice generates 3300 litres of CO2.
for a 90 minutes race it's 18,3 litres/minute (or 0,3 l/sec) of 5C CO2 for each wheel
again, this is pure speculation but nobody add 4,5-6kg of weight on a F1 car just too cool the drivers (and the mandatory cooling equipment by FIA is totally different)
Emag
Emag
Re: McLaren MCL39
If they’re happy with the balance (very loaded front), they can remove the front wing ballast and put that weight somewhere else where it can benefit drivers as well.
It doesn’t have to be so complicated.
EDIT:
Although as I come back to this, I guess this doesn't really make much sense since the 4kg of dry ice probably evaporates over the race distance, so they have to be careful with being underweight. Have they had this much dry ice at every race so far, or has it only been limited to the hotter races only?
Developer of F1InsightsHub
mwillems
46
Re: McLaren MCL39
Emag wrote:
07 Jun 2025, 19:55
EDIT:
But if the car displays its tyre whispering during extreme heat, perhaps they are happy to take the extra weight?
It won't be used often and it possibly is only made full during the most extreme situations. I'm not sure, but we should assume I guess.
With the positioning of the dry ice, is it able to cool the fluid in the master cylinders? Assuming they are hydraulic.
-Bandit
