Ferrari SF-26
Re: Ferrari SF-26
Seems like the vertical plate is directly connected to the exhaust pipe. Haven't seen this detail yet.
via Zander Arcari
matteosc
matteosc
32
Re: Ferrari SF-26
MtthsMlw wrote:
25 Feb 2026, 21:32
https://pbs.twimg.com/media/HCBPuGXXkAA ... &name=orig
via Zander Arcari
From a schematic drawing from Craig Scarborough (if I am not mistaken) there are brackets to make sure that the gas do not bypass the wing laterally, forcing them upwards.
venkyhere
43
Re: Ferrari SF-26
matteosc wrote:
25 Feb 2026, 21:48
MtthsMlw wrote:
25 Feb 2026, 21:32
via Zander Arcari
Is there any pic (with similar closeness to object) from 'the other side' a.k.a looking at the 'exhaust hitting' side of the plate ? curious to see the curvature in the middle
aberracus
aberracus
Re: Ferrari SF-26
venkyhere wrote:
25 Feb 2026, 21:55
matteosc wrote:
25 Feb 2026, 21:48
MtthsMlw wrote:
25 Feb 2026, 21:32
via Zander Arcari
it exist, and its in these forum, im sure I have seen it, and the exhaust is not as close as these image appears to be.
atanatizante
133
Re: Ferrari SF-26
1. I wonder why the former DRS wing had to rotate 270 degrees forward when it would have been much easier to rotate it backward by only 90 degrees. This way, not only would the movement have been much faster, but it would also have avoided the braking/parachute phase.
2. Why didn’t they use the old central actuator on the main plane, configuring it to push the former DRS wing upward so that it could rotate backward by only 90 degrees?
3. Why didn’t they design a system that moves both the main plane and the former DRS wing together as a single unit? Could the movement be either a forward 270-degree rotation or a rearward rotation of only 90 degrees?
Jesus
atanatizante
133
Re: Ferrari SF-26
Are there aerodynamic benefits to having the halo, cameras, "horns", and rear wing as aligned and streamlined as possible? If so, what are they?
Jesus
myurr
myurr
Re: Ferrari SF-26
atanatizante wrote:
25 Feb 2026, 23:12
If the wing rotated the other way it would clip through the other plane. The pivot point is further back so that when it rotates the upper plane is moved backwards somewhat - I presume to interact with the exhaust plume.
That requires the actuator to be at the wing tips rather than using the historic DRS activator design. This has the benefit of moving the blockage to the relatively unloaded wingtips and freeing the blockage from the more heavily loaded centre of the wing.
aberracus
aberracus
Re: Ferrari SF-26
venkyhere wrote:
25 Feb 2026, 21:55
matteosc wrote:
25 Feb 2026, 21:48
MtthsMlw wrote:
25 Feb 2026, 21:32
via Zander Arcari
https://twitter.com/ScarbsTech/status/2 ... 5373726131
Scarb got it !
Farnborough
Farnborough
152
Re: Ferrari SF-26
atanatizante wrote:
25 Feb 2026, 23:12
Because they've a, relatively, whole warehouse full of CFD capabilities to test their own theories, then a manufacturing capability in carbon layup to produce the best iteration, then a real wind tunnel to run that model, covered in sensors and strain gauges to measure the effectiveness.
Guess you must have similar at immediate disposal to develop your own theory and questions :D
venkyhere
43
Re: Ferrari SF-26
aberracus wrote:
25 Feb 2026, 23:39
venkyhere wrote:
25 Feb 2026, 21:55
matteosc wrote:
25 Feb 2026, 21:48
https://pbs.twimg.com/media/HBc9dbuWoAE ... name=small
Scarb got it !
Thanks, so it's actually a semicircular 'cup' right where the bottom half of the exhaust hits the 'wall'. Nice, this would mean that they are creating a cup-shaped high static pressure region where the bottom half of the exhaust exits, thus encouraging the entire exhaust to shoot at double speed (like using our thumb to cover half of the garden hose orifice, to make it shoot out water at higher speed).
This high speed exhaust is going to 'see' an 'inverted waterfall' like air shooting up from the diffuser in the bottom, and will 'join the party' to together exit (while also pulling more 'inverted waterfall' air) and pass just beneath the rear wing, diagonally rising up. This will make the rear wing work even better. So it's a 'triple whammy' effect.
I wouldn't be surprised if the SF-26 is the car that has the best tyre wear on rear-limited tracks for the entire year.
aberracus
aberracus
Re: Ferrari SF-26
venkyhere wrote:
26 Feb 2026, 00:47
aberracus wrote:
25 Feb 2026, 23:39
venkyhere wrote:
25 Feb 2026, 21:55
Scarb got it !
And the Flipping Rear Wing works in tandem with this system accelerating the car forward, as Kyle the F1 Aerodynamist have speculated, lets hope Ferrari has the new rear wing ready for Australia.
vorticism
vorticism
449
Re: Ferrari SF-26
MtthsMlw wrote:
25 Feb 2026, 21:32
via Zander Arcari
Going through the regs... The extension of the tailpipe is actually their interpretation of the single permitted Tailpipe-Bracket. It's U-shaped with two airfoil-shaped feet that connect to the panel extension of the Tail bodywork. Very clever reading of the rules. Blown bodywork has been prevented since 2012, so we'll see how long the FIA lets this last.
Specifically: it looks as though they rotated RV-Tailpipe-Bracket to a more advantageous angle. Considered as a whole with its mirror, they form a chevron shaped volume that the horseshoe-shaped bracket fits into. Pretty sure that solves the legality question.
matteosc
matteosc
32
Re: Ferrari SF-26
Farnborough wrote:
26 Feb 2026, 00:29
atanatizante wrote:
25 Feb 2026, 23:12
Also, if you rotate it 90 degrees "forward" you go against air resistance and it requires much more power.
Re: Ferrari SF-26
MtthsMlw wrote:
25 Feb 2026, 21:32
via Zander Arcari
A night race should reveal all.
Brahmal
Brahmal
73
Re: Ferrari SF-26
The internet says that exhaust gas volume and velocity scales linearly with engine revs. I wonder if that could potentially destabilize the blown rear-end when, say, downshifting in the middle of a corner?
