2025 Aston Martin | Aramco F1 Team
selvam_e2002
selvam_e2002
-1
Re: 2025 Aston Martin | Aramco F1 Team
we need to thank Alonso for Honda success in F1 with RB. Without his Famous comment on Honda GP2
selvam_e2002 wrote:
31 Oct 2025, 19:47
That might not be true but I can see why your "Reputation" is -1.
selvam_e2002
selvam_e2002
-1
diffuser wrote:
31 Oct 2025, 19:52
selvam_e2002 wrote:
31 Oct 2025, 19:47
Yes. -1. but that comment from Alonso should have triggered their upper management to prove them self.
Let see what surprise they are going to give in 2026.
selvam_e2002 wrote:
31 Oct 2025, 19:55
diffuser wrote:
31 Oct 2025, 19:52
selvam_e2002 wrote:
31 Oct 2025, 19:47
You have no idea what you're talking about but yet you write.
WardenOfTheNorth
diffuser wrote:
31 Oct 2025, 16:18
peewon wrote:
31 Oct 2025, 06:05
diffuser wrote:
31 Oct 2025, 05:48
The only difference between 2014 and 2018 was the removal of the token system. That change untied Honda's hands and allowed them to undo all the wrongs they created by jumping into 2014 regs too early and with so little préparation. They were able to completely redesigned the PU for 2018
I meant that I think this regulation change is as significant a change as 2014 was. So how each PU manufacturer has been performing till now may well be drastically altered in 2026. Honda may well produce a good power unit but its all relative to the competition. So even though they are at par with Mercedes now under current regs, the change in regs is significant enough that its possible that a significant gap could develop between them and Mercedes. Whenever theres a huge overhaul like this, theres also possibilities of loop hole exploitations and if you look at Mercedes history, they always seem to find some loop hole exploits.
Yeah I guess.
Merc had been building F1 PUs for years prior to 2014. So when the 2014 regs got finalized in 2010, they immediately started working on the PU for the 2014 regs. Honda didn't decide to jump back into F1 till late 2012, at that point they didn't have anything in F1. They'd been out of the game for at least 5 years. They knew they wouldn't be ready but McLaren having divorced from Merc, pressured Honda. McLaren needed a PU for the 2014 season and Honda had agreed to be that supplier. I don't think anybody had figured out at that time how hard whatever design mistakes they would make going into F1 in 2014 would be to change. The token system limited how much could change from year to year. So if you wanted to move the exhaust ports on the Heads, well that would mean a modification to the intake as well(cause the intake ports would be in the way) and the exhaust manifold. You were only allowed to change 2 parts.....Intake, heads and exhaust manifolds would be 3 parts.
The token system was design to limit spending on PU but in the end it ended up being a lobster trap on the original design. So yeah, circumstances lead to the initial Honda PU being poorly designed from jump. Then the token system made it really hard to correct those design flaws. The CAP now is just how Much money they spend. So even if some team does get it wrong the first year. They can change whatever they want.
Honda left in 2008 and returned in 2015. Remember McLaren ran Merc PU for 2014.
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
peewon
diffuser wrote:
31 Oct 2025, 16:18
Yeah I guess.
I think its possible that Honda produces a PU on par with Merc. But I think its also possible Merc is ahead. If you read into what happened in 2014, Merc already had a novel technology under their belt which was the split turbo design, 5-7 years prior to the regs. It came from Daimler which is their trucking division. Even if Honda came in prepared, they would have struggled to match Mercedes in 2014.
My sneaky suspicion is they have something similar in hand related to regen or deployment based on how they have been the only team to strongly oppose any changes to the regs when almost every team not listed to be a Merc customer has expressed concerns about running out of battery on straights.
Yes the token system protected Merc's advantage for 5-6 seasons but now we have the cost cap, which may not be as restrictive as Token system but will have the same effect so it may only need 2 or 3 seasons to catch up but wont change much for 2026.
peewon
RedNEO wrote:
31 Oct 2025, 09:09
Well Mercedes engine department was led by Andy Cowell back then and there’s already been suggestions he’s helped Honda along with Newey with nailing down their ambitious ideas. Let’s see what happens but I’m hoping Honda can pull a rabbit out of the hat again at the final hour.
Mercedes' advantage in 2014 came from their split turbo design which they borrowed from their trucking division Daimler.
https://www.espn.in/f1/story/_/id/14759 ... -get-right
Its almost impossible to say who was the main person responsible for that in such a scenario but Cowell does seem to be ambitious in targets and gels well with Newey.
peewon wrote:
01 Nov 2025, 02:50
Why would Merc have developed a split turbo 5 years ahead of time when they didn't even know if the new regs would use a supercharged 4 cylinder or normally aspirated v10?
I think you're dreaming of this but nobody REALLLLLLLLLLY knows where the new PU manufactures performance are. If they claim they know, they're full of shiit. Their is so much money riding on this that letting anything out would just be stupid.
madridista
diffuser wrote:
01 Nov 2025, 22:47
peewon wrote:
01 Nov 2025, 02:50
Did you read the article or anything of what the guy you are responding to said? They were running this split turbo system independently from f1 in Daimler road Trucks (because it had whatever use there), later saw gains in it related to the f1 engine regs, and integrated it in their solution.
https://www.espn.com.au/null
Mercedes started work on its power unit three years before it was introduced, but Cowell admits his team had little in the way of expertise at that stage and even borrowed some ideas from Mercedes' truck department.
"Daimler with their truck engine division, and the turbo chargers involved in that, helped tremendously. There were several thermodynamic sizing areas where they helped and several reliability issues where they helped as well.
madridista wrote:
02 Nov 2025, 05:19
diffuser wrote:
01 Nov 2025, 22:47
peewon wrote:
01 Nov 2025, 02:50
Yeah, I did. Cowell says the split turbo hadn't been done before.
madridista
rereading it he doesnt deny it, but i probably read too much into the „borrowed some ideas“, as ive found nothing else anywhere of Daimler putting it to use so you are right
peewon
diffuser wrote:
02 Nov 2025, 06:47
Cowell was referring to it not having been done in F1. Obviously there was an adaptation required there. But there are many stories from that era which suggest that Mercedes would be miles ahead of everyone. Its also part of the story of how Nikki Lauda convinced Hamilton to join Mercedes on that basis, according to Hamilton himself. Hamilton didnt talk specifically about the power units but Lauda convinced him Mercedes would be the best team. Luca Montezemelo also claimed that Lauda admitted to him that Mercedes had been working on a hybrid PU good 5-7 years prior to 2014. With regards to these regs Mercedes was also in Formula E for a substantial time where battery deployment and regen was a key factor in performance so who knows what all knowledge they mightve gained from that program.
peewon wrote:
02 Nov 2025, 15:02
diffuser wrote:
02 Nov 2025, 06:47
That points more to corruption in the FIA than anything else. Like Merc knew the direction of the regs before they were actually chosen.
I hope that isn't the case this time.
DoctorRadio
DoctorRadio
https://it.motorsport.com/f1/news/f1-cl ... it/603699/
Ecclestone said in 2015 that Mercedes knew long before about the new regs.
peewon
diffuser wrote:
02 Nov 2025, 15:22
Its a grey area whether its outright corruption or not. F1 has and will always favor big brand names because thats what gives it credibility as the premium racing series. If Ferrari and Mercedes decided to race in another serries and leave F1, nobody would think its the premier series. This is why Ferrari has a special revenue deal and why it used to be a joke that FIA stood for Ferrari International assistance. Now, Mercedes is the branding behemoth which gets coveted by them. Mercedes was coming in at the back of the financial crisis and many brands like Honda were struggling to stay in F1.
FIA may not have know the extent to which Mercedes had advantage when they formulated the rules. And ultimately other teams agreed. Paddy Lowe even claimed they hid true performance from everyone to prevent rule changes to close the gap.
I dont think it'll be as bad as 2014, but a mini version of 2-4 years seems very possible.
