2023 Scuderia Ferrari F1 Team
CouncilorIrissa
CouncilorIrissa
Re: 2023 Scuderia Ferrari F1 Team
Here's to hoping that tomorrow will be much cooler, then.
Space-heat
Space-heat
Vassuer said they made a mistake on the cooling for Charles and Carlos after the race. On the on-board Xavi was asking Charles to increase lift off nearly every lap.
Hopefully they can fix their cooling for tomorrow.
deadhead
70
Space-heat wrote:
04 Nov 2023, 21:51
Some weather sites have tomorrow cooler by up to 3 Celsius so they might be alright if they aren't not allow to change any of that before then
Xyz22
Xyz22
124
For a good result tomorrow we need to get out of the first lap in P2. This could allow Leclerc to have free air (Max will do another race) and thus manage both tyres and engine temps.
I think Norris will be also too fast tomorrow, but we can fight against Lewis, Russell, Alonso and Perez.
search
deadhead wrote:
04 Nov 2023, 22:02
Space-heat wrote:
04 Nov 2023, 21:51
yeah, may even be intentional, for more pace tomorrow, I guess. The team said that the sprint was no priority, so it would kinda make sense to race with less cooling, if it comes with an advantage for the race.
Vanja #66 wrote:
04 Nov 2023, 21:14
They were at least second fastest on Friday on pace, that went away quickly...
Norris did no long run on Friday and I would say he seems to have 5 tenths to 1 second over piastri at this track. Might be the cause of Ferrari's sudden appearance of dropoff
If there was dropoff it was probably due to cooling. Seems like they were lifting & coasting constantly in the sprint. Tomorrow will be cooler and Leclerc should have more clean air, and they might be able to improve the cooling setup in parc fermé idk
Xyz22
Xyz22
124
Just to understand how crazy the management was...
Ricciardo gained over 2s in 2 laps on Sainz after he overtook Piastri
Space-heat
Space-heat
Xyz22 wrote:
04 Nov 2023, 22:44
Sainz might have lost 8th with out the DRS from Hamilton on the last straight...
Hopefully either the predicted cooler temperatures or a cooling setup change will let Charles and Carlos push a bit harder during the race.
Duchessa on Twitter ( seem to be suggesting the Merc have set their car up for the Med-Hard compounds in the race. Have to see, but hopefully the Astons can get a DRS train going and let Charles pull away.
04 Nov 2023, 22:42
Ah, so, thanks :)
Sphere3758
Sphere3758
Were Ferrari on more used tyres compared to McLaren, Redbull and Mercedes?
They did not even use a new set in sprint shootout q3, which means they had 2 fast laps on theirs compared to 1 on the rest ?
If that’s the case, makes Leclerc’s tyre deg more interesting imo
scuderiabrandon
111
Sphere3758 wrote:
05 Nov 2023, 11:29
Max only used 1 set in SQ3 and no new softs in FP1, he'll have the same tyre allocation.
The Ferrari were doing some heat management aswell so the rac eif they are able to pusgh should be a bit better.
Seems like they will be able to fix their cooling issues from yesterday
the EDGE
the EDGE
68
05 Nov 2023, 14:10
Isn’t it supposed to be cooler today anyway? So may not need to change
the EDGE wrote:
05 Nov 2023, 14:34
05 Nov 2023, 14:10
Yep quite a bit cooler. And Leclerc should have cleaner air today
Still they were so on the limit yesterday that even with lower temps they will probably be more conservative today
