Henk_v
Henk_v
89
They know max has 1 up in the Rain and likely took a gamble (weather seems dry during the race now).
They now have a very startegic car set up. They can fend off faster cars as max will likely be impossible to overtake. They can defed against a split strategy (1 and 2 stop) from mcl and can smoke their tires if necessary to defend against undercuts.
Maybe max ordered it this way and promised to squeeze out a pole
venkyhere
43
kurtj wrote:
06 Jul 2025, 07:36
venkyhere wrote:
05 Jul 2025, 19:53
Vettel165 wrote:
05 Jul 2025, 18:44
https://postimg.cc/xJ4BWhYF
The car is the knifiest of the knife-edge cars out there. And then to make it worse, go to Silverstone with a Monza spec wing. And still be fastest in high speed corners - that takes spectacular talent.
Yep, Flintstone like. First, perform poorly in free practice and everyone would call it a trash car, a shopping cart etc., Then show the actual potential of the car and get pole. Viola, it's mega talent, the same talent that went missing in Austria qualifying. We used to see this sort of opera with Lewis at Mercedes in their heydays.
The car is so finicky that when the track temps went up a bit, the tyres were 'out of the window' in Austria. Even in Silverstone, the difference between first Q3 run and second Q3 run was 0.3s and they did some flap adjust between the two runs, because track temp was different w.r.t Q2. Seeing how sensitive the RB21 is on it's tyres, shows that it isn't a well designed car (something went fundamentally wrong right from RB19->RB20 itself, and got amplified with RB20->RB21) and is massively inconsistent. The car was 'poor' on friday and the way they chose to address the massive understeer in the fast corners, was to take out rear wing. That option, or the option to add a stronger front wing but which will sacrifice top speed, still not match the McLarens in the fast corners, but make it much easier to drive. They chose the 'risky' approach, which places a lot of onus on the driver to be able to deal with a mega twitchy car. Even with the change, it still understeered massively in the slow turns T4/T6, but atleast the high speed corners were addressed.
Without understanding such 'balance' issues, coming here with confirmation bias garnished with low-rent hatred, and dishing out smart a** comments, is not what this forum stands for. Make technical arguments, not facebook/reddit level hot-takes.
kurtj
kurtj
venkyhere wrote:
06 Jul 2025, 09:46
kurtj wrote:
06 Jul 2025, 07:36
venkyhere wrote:
05 Jul 2025, 19:53
Sorry to say, getting personal with other posters and throwing jibes is not what this forum stands for. Maturity is when opinions are countered with respectful disagreements and offering differing opinions. Thank you.
Juzh
161
kurtj wrote:
06 Jul 2025, 07:36
venkyhere wrote:
05 Jul 2025, 19:53
Vettel165 wrote:
05 Jul 2025, 18:44
Not sure what you're on about, Max didn't get to complete final Q3 lap because of yellow flags. That lap would put him somewhere on second row as no one was touching mclarens in Austria, something very obvious.
Juzh
161
Some observations about pole lap:
- 180 kmh in brooklands is very respectable, nearly on par with mclaren and ferrari who as we know carry more loaded wings. Somehow this is also faster than 2020 W11
- 321 kmh into copse is seriously fast, maybe fastest I've seen (ever? hard to say). Aided by slight slipstream from the car ahead
- 304 kmh minimum speed in copse is again almost certainly fastest speed ever trough there. He actually has to lift because entry speed from slipstream is higher than usual and a very slight washout from dirty air is causing some understeer at the apex. Even so, he's still gaining time compared to his previous Q3 lap which was without slipstream and was flatout
- for some reason Max loses time on back straight towards stowe corner compared to his first Q3 lap, 1 tenth worth. Why that is the case I'm not sure. There is a car ahead in the far distance but this can't be the reason as it is too far away
kurtj
kurtj
Juzh wrote:
06 Jul 2025, 10:28
kurtj wrote:
06 Jul 2025, 07:36
venkyhere wrote:
05 Jul 2025, 19:53
My point is simple. Trying to overhype a driver for achieving the full potential of a car, built to his liking, while constantly thrashing the team that is building it, isn't necessary. There is zero doubt that, Red Bull has been building cars for one driver, almost their entire existence so far. When the car is good for the day, a good driver takes the best out of the car and on the days when it isn't, nothing much can be done. No driver has the talent to put a Sauber on pole. If a car is on pole, it means that car is capable of being there and most drivers can put it on pole when the car is built to their liking and on the day, it is there for it. This isn't to belittle Max. But credit where it is due, the team did a great job to enable that car to be on pole.
Henk_v
Henk_v
89
Juzh wrote:
06 Jul 2025, 10:45
Max reported post Q he saw he had enough delta to take it easy the last sector and took no risk. All before him had a terrible S3.
marcel171281
marcel171281
31
Henk_v wrote:
06 Jul 2025, 10:51
Juzh wrote:
06 Jul 2025, 10:45
Well yes, but that would be in a corner, which shows as well in the data, he took less risk in the last chicane, about one tenth worth. But he lost a tenth as well on the hanger straight towards stowe. That has nothing to do with risk. Also data shows he was on 100% throttle both laps and in his fastest even earlier out of chapel, but ended with 5kmh deficit before stowe. Either headwind or deployment settings.
Sergej
It's pouring at Silverstone. With a wet race, not sure where we're going with that super slim rear wing...
Juzh
161
marcel171281 wrote:
06 Jul 2025, 11:04
Henk_v wrote:
06 Jul 2025, 10:51
Juzh wrote:
06 Jul 2025, 10:45
I'm leaning towards headwind because he's slower for entire straight, not just on top end as a result of clipping. Traces for rest of the pole lap are nearly identical with first lap so I don't see where extra energy could be spent.
Sergej wrote:
06 Jul 2025, 11:08
Bad news, hopefully it dries out in time, or else we're in for a bad day.
Henk_v
Henk_v
89
They have had one shower. As predicted. Looking at the radar and satellite, that'll be all for today. Maybe a freak drizzle.
f1isgood
f1isgood
Whatever happens a podium can be hopefully realistic. Been a while since Canada.
Paa
f1isgood wrote:
06 Jul 2025, 11:45
I think it was possible in Austria. Without the yellow flag in qualy and Kimi in the race.
f1isgood
f1isgood
Paa wrote:
06 Jul 2025, 12:18
f1isgood wrote:
06 Jul 2025, 11:45
True. I think every team has shifted to 2026, and everything suggests Max is gonna go (which I think is still kinda stupid as 2027 would be better). So we hope for the best and enjoy whatever we get :)
Waz
Waz
kurtj wrote:
06 Jul 2025, 10:47
Juzh wrote:
06 Jul 2025, 10:28
kurtj wrote:
06 Jul 2025, 07:36
Strange argument all bssed on the incorrect narrative that the Red Bull is built towards Max's liking. We have enough statements confirming that Max does not like the car, nor the direction they chose to develop towards last year.
I guess it's convenient though, because then the narrative can be used to dismiss the fact that 4 other drivers were setting lap times capable of Pole position, but all 4 made mistakes that prevented it.
