Yeah I generally agree of course, but with a complete absense of a flat floor (at least at press time yesterday) I think we could be seeing a new concept for ground effect which lead me to my red line... I know the red line is an over simplification and the white line brings more realism.Just_a_fan wrote:Your white line is what I basically described several posts before...SR71 wrote: EDIT:
After looking at some more photos I see a double diffuser, the white line traces this as well as the leading edge of the floor.
Overall still following the RED line as i see it...
https://postimg.org/image/raiphxlz5/![]()
Your red line is a bit of a red herring, I fear. If you had an aero body like that the centre of pressure would be massively in front of the centre of mass and the car would be totally undriveable, especially with the blue one in front. You need to balance the downforce distribution to be consistent with the mass distribution, with the centre of pressure to the rear of the mass. That what gives stability at speed. Think of a dart - centre of mass at the front, centre of pressure at the rear.
Most likely is your blue line (but smaller, obviously) and your white line. This would give a distribution of downforce consistent with the major masses. By placing the throat of the diffuser somewhat rear of centrally in the wheelbase, it will be close to the big mass that is the engine/transmission group.
Look at the 001 and compare it to the pressure plot:
http://www.totalsimulation.co.uk/wp/wp- ... 24x520.png
I think the front wing will not be as effective as in the plot, not will the rear diffuser. I think the central blue portion will be much bigger on the 001 with the rear end balancing it to ensure correct distribution.
Certainly, there is nothing much forward of the car's waist, other than the front diffuser/wing, that will generate downforce in meaningfully large amounts. So far as we have seen, anyway. Having a flat portion of floor near the waist, driven by the diffusers, would seem to be the obvious solution from the images available.
I guess its more 2 medium wings (white and blue) that achieve the principal the red line shows.
Overall i see the body more like a wing upside down flying 2 feet off the ground than a flat floor + classic diffuser + classic wings front and rear...
