Ferrari SF21
tpe
tpe
-4
Re: Ferrari SF21
Interesting change for the front wing.
Maybe trying to increase flexing?
gordonthegun
254
Re: Ferrari SF21
tpe wrote:
18 Jun 2021, 07:42
I don't think so. To try to increase flexing in this particular moment is not a good idea. :)
amr
amr
Re: Ferrari SF21
I think there might be multiple reasons for this new front wing:
1: moving the setup screw gives now having a bigger setups window, which follows the recent trend where their main performance gains came from the setup of the car, rather than new parts.
2: this new bigger setup window might make the FW usable for all the races for the rest of the season, helping them to reduce parts diversity and overall cost
3: the footplate and underwing turning vane, will try to work the z floors harder (the current and/or the tested and unraced one).
Ferrari went from straight cut floor to the z cut floor without any other changes. They tested the new z cut floor and it gave good results on its own and, I think, bad integration with the package (FW and bargeboards). I suspect it made no sense to bring new parts at Monaco and Baku so now we are seeing that development stream resuming. I think we will see some development in the bargeboards next and then the new tested floor will be back, and they will stop this year's development completely after that.
tpe
tpe
-4
Re: Ferrari SF21
gordonthegun wrote:
18 Jun 2021, 08:48
tpe wrote:
18 Jun 2021, 07:42
The focus is on the rear wing though :twisted:
Re: Ferrari SF21
gordonthegun
254
Re: Ferrari SF21
zioture wrote:
18 Jun 2021, 21:28
Also the height of the the most external fin under the wing has been reduced in the new FW.
Re: Ferrari SF21
Manfer
Manfer
Re: Ferrari SF21
Ferrari running lower df wing in FP3. Looks like most teams are going low df compared to yesterday.
aerofoilf1
aerofoilf1
247
Re: Ferrari SF21
gordonthegun
254
Re: Ferrari SF21
Do you know if this change is related to the lower downforce wing or will it be used always as a new version of RW?
aerofoilf1
aerofoilf1
247
Re: Ferrari SF21
gordonthegun wrote:
19 Jun 2021, 22:33
On Friday they ran with a high downforce rear wing (before using spoon wing for FP3/Quali) and still used this endplate, so would suspect that this will be standard spec for all RWs.
gordonthegun
254
Re: Ferrari SF21
aerofoilf1 wrote:
19 Jun 2021, 23:15
gordonthegun wrote:
19 Jun 2021, 22:33
So Ferrari brought changes to both wings, good.
The bargeboards might be the next to be modified, if Ferrari still wants to invest on 2021 car.
Re: Ferrari SF21
Spielberg
Via AMuS
gordonthegun
254
Re: Ferrari SF21
Morteza wrote:
24 Jun 2021, 15:09
Spielberg
Via AMuS
Was the black fin behind the wing pillar already that way, finishing lower than the pillar itself? :?:
Edit: yes, on the front wing, the bases of the pillars have the height for the exceeding black fin.
FDD
FDD
83
Re: Ferrari SF21
