oh please? Ferrari had this planned from the beginning when they made the car concept. The others are just simple add onns/solutions because they cannot do what ferrari did because they angled the drivetrain
But offcourse they gain some performance or they wouldnt do
In general, I couldn't see many big changes on this car, so a bit underwhelming considering how much it was oversold as a completely new car. It certainly did the job (so far) though, so whatever they did to it, it's working. I think I noticed that their floor leading edge is similar to Ferrari's now as well, but other than that, the sidepod shape differences and everything else listed on the upgrade sheet is hard to tell apart from the previous spec.
Let's see what they bring for Canada.
In this picture you can see the updated "daggers" at the floor entry. They have adopted the grid-fin arrangement of Ferrari. Also I can't tell if the mouse-hole at the base of the diffuser actually exists, or if that's just a shadow line.
Mclaren have this bulges by the mounting points on the chassis. By the suspension I can understand it (big forces). But by the mounting for the barge board it is odd. https://pbs.twimg.com/media/HHTfLpNXsAA ... ame=medium
I always thought having a shorter car it is easier to reach the min weight limit. But with a rear axle more forward it needs more ballast at the front to have the regulated weight distribution. So maybe it is harder.
Not sure what you mean. The regs set a minimum axle weight. You can have any weight distrubtion you like, so long as one axle isn't under weight.
The sum of the weight on the two axis gives you the total weight of the car. The weight distribution gives you how the total weight is distributed between the two axes. So no, you cannot have any weight distribution you like.
