Lotus E20 Renault
Crucial_Xtreme
Crucial_Xtreme
404
Re: Lotus E20 Renault
Aero test rig on RW
Forza
238
I would expect them to put some more heat protection on the upper wishbone. Also the trace of exhaust flows by side of the bodywork. There is also that metal protection on the floor. "OP" on it means optional in my view and I assume they use it to clean the rear tyres They have a bit grooved surface on the middle on this picture.
MIKEY_!
Metal shielding on the rear floor???
Pierce89
Looking at above pictures, is it normal in F1 for the rear mount on top rear a-arm to be mounted conventionally? I thought F1 wishbones used flexure mountings so they could eliminate some friction.
edit: sorry mods. decided I needed to quote the pic to show the specific picture I'm asking about because there are quite a few up there.
MIKEY_!
And they look circular which is unusual.
Testarossa2012
Testarossa2012
beelsebob
beelsebob
85
MIKEY_! wrote:And they look circular which is unusual.
What look circular? The exhaust exists? That's mandated by the rules.
blokkie
blokkie
No , I think he means the wishbones .. at the point where they connect with the body of the car.
Thos connection points are circular
Crucial_Xtreme
Crucial_Xtreme
404
Flo-Vis
And new DRS
The sidepod intakes seem to have 4 secondary side crash structures now (two per sidepod - like the R31) while they had only 2 in Jerez.
:-k
http://i49.servimg.com/u/f49/14/79/55/26/lotu_g10.jpg
Jerez
http://i49.servimg.com/u/f49/14/79/55/26/669_210.jpg
Today
Barcelone/Jerez
http://i49.servimg.com/u/f49/14/79/55/26/q7oot10.jpg
R31:
http://www.racecar-engineering.com/wp-c ... upe207.jpg
New rear bodywork with a thinner cooling outlet ?
kwanchepan
kwanchepan
The outfit of the central part is much smaller than original one.
shelly
shelly
136
Side crash structures detached from the sidepod begin to come out. Will we see them on mclaren and ferrari also, after all the pre-launch speculation?
twitter: @armchair_aero
Owen.C93
Owen.C93
191
The crash structures must bring decent gains if they crash tested both versions to run the pre-season.
Here you can see a hole for driver cooling ;)
I think they must be metal then. To withstand the heat. Maybe inconel or Titanium or even Zirconium or Osmium.
