Renault R31
H.Lyoud
H.Lyoud
Re: Renault R31
Looks like Renault has a problem, a big one.
Anyways as far as i remember Kubica said they will search progress at Valencia, not speed.
Re: Renault R31
Well.. looks like I have to wear a yamamoto avatar... I knew its possible, but i didn't think it was sane to do it. Also didn't know the exhaust curled backwards.
I have to appologise to all the people I called BS on in routing the exhaust at the front :lol: but I won't apologise to the part about pointing the exhaust forwards now that's ridiculous. 8) but hey part of the fun at this forum.
So, It seems they EXIT AT THE FRONT, BEHIND the BARGEBOARD curl around POINTING BACKWARDS and shielding it from high pressure using the bargeboards. The are shooting the hot gas under the WHOLE FLOOR.
from f1fanatic link above: http://www.f1fanatic.co.uk/2011/02/01/r ... /_jle0965/
horse
Re: Renault R31
kilcoo316 wrote:
Yep, your spot on, that is what they are trying to do (mimic the effect of skirts).
Another possibility is pointing the exhausts outboard at around the splitter location, in an attempt to better "seal" off the floor of the car; think fluidic sideskirts.
Could you explain more about how this works? Side skirts are for stopping flow coming in from the sides, but these are pumping sideways from the front. I don't think restricting the flow entering from the front is beneficial.
myurr
myurr
Re: Renault R31
Scarbs has another explanation on his blog. Apparently this is about energising the flow under the floor rather than sealing the sides.
FrukostScones
Re: Renault R31
BREAKING NEWS: according to Auto-Motor-und-Sport.de McLaren will have the same, combined with ToroRosso like side pods. The exaust will blow into the deep undercut backwards. Mercedes is also working on a solution like this.
"I ain't with the FIFA, I'm in Tokyo." LH
imightbewrong
imightbewrong
Re: Renault R31
myurr wrote:Scarbs has another explanation on his blog. Apparently this is about energising the flow under the floor rather than sealing the sides.
Looks like his initial guess of how the system was laid out was a bit wrong, the exhaust point outwards, not down. But it might be more complex than that, we just don't know yet and it seems like they can have hidden quite a bit there..
bosanac1
bosanac1
Re: Renault R31
=D>
after seeing the pictures Renault have really brought something extreme and innovative
but you have to question if this concept might be too extreme to work
240
Re: Renault R31
I don't think that exhaust system will work well.
If they were going to do it that way it needs a few more modifications. Otherwise it should have been placed further downstream, after the widest part of the side pod and pointing backwards.
Something tells me they might scrap the idea if it costs them too many problems though.
Blowing it under the car is not the right idea. That is wrong.
High pressure air belongs on top of the floor.
WhiteBlue
92
Re: Renault R31
horse
Re: Renault R31
ringo wrote:Blowing it under the car is not the right idea. That is wrong.
I think they are surmising that it won't stay at high pressure for very long. I suspect the pressure will drop off rapidly once the gas has left the exhaust and started mixing with the external flow. As long as the temperature stays high then it should work, I reckon.
EDIT: Got rid of some stuff I don't think is right.
240
Re: Renault R31
I was expecting something like this:
The exhuast creates a wall screen off free stream air from going under the floor.
Thus sealing the floor and creating a fluidic skirt. I mentioned it a few pages back, but i never though they would try it.
The only problem is getting the pipes to the edges of the floor, and the effect of the tyres.
They seem to have put most of the exhaust over the floor though, just a sliver of it is blowing under the edges to act as a seal.
The idea is novel, but too many drawbacks; weaker engine, heavier exhuast pipes, more weight from thermal protection, wasted space useful for placing heavier things besides a hollow pip full of hot air.
If it works for them then no problem.
slimjim8201
Re: Renault R31
ringo wrote:I was expecting something like this:
Whether the exhaust gases are used to seal the floor from the side or create a local low pressure zone to accelerate additional airflow under the car (or both) and assuming this has a reasonable effect on downforce, the car will be somewhat throttle dependent in high speed corners. Considering how much overall downforce is resultant from the underbody...I'm curious what the drivers will have to say.
Re: Renault R31
Maybe they skim the exhaust air. Some of it is skimmed off into the boundary layer under the floor, enabling them to run a steeper rake and a steeper diffuser.
OR if the if idea is to use it as an "air curtain/skirt" the rest is tripped up into vortices to seal the sides.
mith
Re: Renault R31
slimjim8201 wrote:Whether the exhaust gases are used to seal the floor from the side or create a local low pressure zone to accelerate additional airflow under the car (or both) and assuming this has a reasonable effect on downforce, the car will be somewhat throttle dependent in high speed corners.
They can overcome it partially with ignition retardation providing somehow constant flow.
horse
Re: Renault R31
ringo wrote:The exhuast creates a wall screen off free stream air from going under the floor.
I don't quite get the physics of this. Surely the exhaust gas will mix and dissipate, especially if it is initially at high pressure? Would this system be much better than just using vortex generators, for instance?
ringo wrote:They seem to have put most of the exhaust over the floor though, just a sliver of it is blowing under the edges to act as a seal.
Again, It looks more 50/50 to me:
I mean, they might well be doing something like you describe, but I can't image that they are completely ignoring the idea of blowing the diffuser with this system, at least as part of its function.
n smikle wrote:Maybe they skim the exhaust air. Some of it is skimmed off into the boundary layer under the floor, enabling them to run a steeper rake and a steeper diffuser.
I really think having higher temperature air under the floor is beneficial for reasons similar to this. If you can keep the boundary layer energised all the way to the diffuser opening then your floor should be working more efficiently I would say. Like Ringo says though, you need to avoid effectively pressurising the floor with the exhaust which is maybe why it seems to be split.
Ah, sweet conjecture. [-o<
