LVDH wrote:Hi,
I do not use OCCFD but this sounds like you did not or incorrectly installed Paraview.
pybatch is the executable that creates the pretty pictures (in batch).
You should check if you can run Paraview, then if you can start it from command line and then if you can start pvbatch.
LVDH wrote:On the homepage it says that OCCFD supports:
v3.98.0, v3.98.1, v4.1.0, v.4.2.0, v4.3.0, v4.3.1, v4.4
In my experience every Paraview has its very own bugs, so you might have to experiment which one works for you.
And pvbatch is something that will run in batch mode so I do not think that you should already have it running.
But you should check if your most beautiful OS can run the command "pvbatch".
For the option 1 it is a specified volumetric flow rate, so larger surface equals lower velocity.CAEdevice wrote:Hi everybody, I don't have the data from occfd with me, so I can't check the bc files.
I was wondering if the bc applied to the inlet/outlet cooling surfaces are a flow (larger surface means lower air speed) or a velocity.
i'm using OpenFoam 2.3 and occfd 1.1.006 and paraview 4.4CAEdevice wrote:Are you using OpenFoam 2.3 and occfd 1.1.005? It seems the "parallelization" issue.
Sorry, I'm a complete novice. Where will I find the log?CAEdevice wrote:Look into the log: at the end of the document you should find as many "openMPI" errors as the logical processors.
