2025 Scuderia Ferrari F1 Team
deadhead
82
Re: 2025 Scuderia Ferrari F1 Team
jambuka wrote:
26 Feb 2025, 02:51
Will the team have perfected the new suspension system in first attempt? Testing will tell everything.
Big ask, but they better have it figured out by Q3 in Oz…
dialtone wrote:
21 Feb 2025, 17:01
DJ Downforce wrote:We don't know the setup they were running. If it's a big problem the car will express it at Bahrain
T4 in Bahrain has negative camber and is high traction with understeer built into it, i agree with you that if that’s a problem it will show up there.
Interesting with that lap from Lewis in mind
Venturiation
Venturiation
103
Space-heat
Space-heat
26 Feb 2025, 10:41
dialtone wrote:
21 Feb 2025, 17:01
Watching with a delay. Is the understeer present?
@berrageiz noted similar from Lewis early runs.
Early days and somewhat expected with the suspension change. Also hard to know fuel loads. Hopefully team can dial it out if it is an issue. The larger gap between testing and Aus might serve Ferrari well if the need to fiddle with the suspension internals.
Space-heat wrote:
26 Feb 2025, 11:20
26 Feb 2025, 10:41
dialtone wrote:
21 Feb 2025, 17:01
Lots of issues at T4 including understeer and snaps/twitches
Space-heat
Space-heat
26 Feb 2025, 11:25
Space-heat wrote:
26 Feb 2025, 11:20
26 Feb 2025, 10:41
Cheers. Have to see how it progresses over the next three days.
Fakepivot
Fakepivot
how does ferrari still seem to have understeer if the angle of front wing looks more than other like redbull.
Xyz22
Xyz22
125
Fakepivot wrote:
26 Feb 2025, 11:40
RB suffered from understeer last year after the dominance of the first few races.
These cars are very sensitive.
CouncilorIrissa
CouncilorIrissa
None of the cars have looked particularly good in T4 so far, it's just the nature of the corner.
yooogurt
40
Teams are working to determine what “ basic” balance the car has, the most telling will be the faces of the drivers and the team.
FORZA FERRARI SEMPRE!
bluechris
Seems to me that the car is very stiff especially when the camera is from behind in several acceleration areas its bumping.
I suppose they have a fixed suspension setup today and the see the aero correlation etc
Seanspeed
Seanspeed
C3
1: 36.638
1: 36.850
1: 36.278
1: 36.797
1: 36.630
1: 36.525
1: 37.140
1: 37.795
These are the same as the 'softs' for the race last year, right? Cuz if so, assuming anything like a full fuel 1st stint, the race times last year for Leclerc were:
L2 - 1:36.862
L3 - 1:38.062
L4 - 1:37.752
L5 - 1:38.131
L6 - 1:37.782
L7 - 1:38.957
L8 - 1:38.136
L9 - 1:37.844
L10 - 1:37.884
Though if it's not full fuel 1st stint-esque thing, then the 2nd stint in the race last year was consistent mid-high 1:36's basically the entire way on hard tires, which is more comparable.
deadhead
82
deadhead
82
Seanspeed wrote:
26 Feb 2025, 12:54
C3
1: 36.638
1: 36.850
1: 36.278
1: 36.797
1: 36.630
1: 36.525
1: 37.140
1: 37.795
L2 - 1:36.862
L3 - 1:38.062
L4 - 1:37.752
L5 - 1:38.131
L6 - 1:37.782
L7 - 1:38.957
L8 - 1:38.136
L9 - 1:37.844
L10 - 1:37.884
SF24 Bahrain spec is much slower than the Abu Dhabi spec I think at least 0.5
yooogurt
40
Hamilton immediately collected data at different speeds via rakes behind the new front.
FER, MCL, and I would say RBR are configured with thinner wings than everyone at the rear, which leads to early sliding on rear limited but is not indicative factor
