RE: vibrating wing
I don't think anyone's running it (can't see anyone getting something based on turning vibration to their advantage, right without some failures on track).
Harmonic resonance is just a possible tool for inducing a (harmonic) vibration at 1 frequency in part of the chassis from another frequency already present in the system. Vibrations aren't really Sci fi. The resonance won't magically melt the wing (which I get the feeling is what Strad thought I meant).
The 2 effects as I saw it that could be used are:
> Low frequency/long wavelength vibration (less feasible imho)
- the wing would effectively be trying to "flap" as the wave travels along it
- on the "downstroke" (for the want of a better word), a additional force would be applied in the same direction as the pressure above the wing.
- the force of the aero would dampen the upstroke. (+ rob the energy from the vibration, preventing any sustained "true" resonance & likely making the energy demand higher than what's available)
- my thought was that there is potential here to use the additional downward pressure to actuate a "cranking" mechanism(?) in [the structure of] the wing.
> High frequency vibration
- stiffening effect (can be induced deformation - vibration applied drawing the structure into a different shape, stiffening it against variation from that shape)
- effectively this could enable vibration to induce a curve in the wing, or conversely (with different structure)stiffen a flat wing.
- someone's always already written a paper on just about any idea (or in this case a similar application of the effect):
adaptive tuned vibration absorber with variable shape stiffness element
- I don't have a clue what the direct effect of high frequency oscillation would be on aero performance.... Could be bad, could be good.
