Formula 1 fan 1996
Formula 1 fan 1996
Will both Hamilton and Russell start race from pitlane?
Formula 1 fan 1996 wrote:
20 Oct 2024, 10:25
If Mercedes can prove they are replacing parts with older lesser spec because they don't have enough spares of the good stuff Russell should keep his position.
Reality check day for Mercedes after they were so enthusiastic on friday, many articles talking about how awesome their updates were...
GrizzleBoy
GrizzleBoy
Hot take:
Russel put the car in the wall to force the ream to put him in a car with parts that arent now 1s second slower per lap.
Lewis even offered Goerge his upgraded parts so that he could use the old ones and George refused.
Neither driver wants to drive this car in its current iteration.
Luscion
Luscion
136
https://www.auto-motor-und-sport.de/for ... oxengasse/
Hamilton had his car modified. Russell changed nothing. Both drivers noticed early on that their cars felt completely different to the day before. “The conditions were similar to yesterday,” puzzled Russell. The asphalt temperatures were 37 degrees on both days. Only the wind had picked up a little. But that could not explain why a potential winning car suddenly became a problem case.
Russell saw this as a reflection of the entire season. “If we get our car into the magic window, we can get pole position and win races. If not, we're nowhere.” Hamilton described nowhere like this: “The car was a nightmare. I couldn't find any grip, the balance swung from one extreme to the other.”
Because the yellow flag at this point slowed everyone else down, Russell kept his sixth place. But there was no joy. The 26-year-old Englishman knew full well that there were only two of the upgrades (front wing, underbody, engine cover, front axle, wishbones) that had been accompanied by so much hope. And his had deformed into a pile of carbon fiber garbage.
Hamilton immediately offered his colleague his upgrade kit, because Russell's chances on Sunday were significantly better than those of the record winner. But the noble gesture is unlikely to be realized. The mechanics are not allowed to work on the cars until 8am. Until then, they will be parked in the parc fermé.
If Mercedes were to accept Hamilton's offer, two cars would have to undergo a general exchange of parts. That is not feasible in the short time available. “We can't completely rebuild two cars at the same time. There are a lot of components involved in the upgrade,” explained a team spokesperson. Due to the high workload, it has also not yet been decided whether Hamilton's setup will be modified again, which would lead to a start from the pit lane.
The situation is different for Russell. Even if he has to bite the bullet and make do with the Mercedes in the Singapore configuration, he will keep his grid position. A special rule for sprint weekends applies.
If a team brings a new development to the start but is short of parts, it can apply to the FIA in advance to be allowed to revert to an older specification without penalty in the event of an accident. For Russell, the GP USA will be a journey into the unknown. He only has three to four laps on the way to the starting grid to get used to the unfamiliar car.
Luscion
Luscion
136
https://formu1a.uno/it/mercedes-la-w15- ... nti-dubbi/
Making the situation more complex is the fact that the two drivers suffered from different problems during the Sprint Race, then highlighting a general lack of pace against McLaren, Red Bull and Ferrari. “We saw that we are not at the level of our rivals. In the Sprint Race we had to push to keep up with them, but then we overheated and overused the tires,” analyzed Race Track Engineer, Andrew Shovlin. Specifically, “Lewis suffered with the rear tires, George with the front tires,” said Toto Wolff. A complicated situation for sure. The common feeling, however, is that the Mercedes W15 was not in the ideal window of use compared to Friday and this cost a lot in performance.
“Lewis was unlucky in Qualifying, because he found traffic that cost him elimination in Q1,” revealed Shovlin, who, however, then confirmed what his driver said immediately after the race, with the No. 44 Mercedes suffering damage during the Sprint Race, in the front suspension area, which was quickly repaired later between the two sessions. In addition to that, changes were made to improve balance and behavior of the W15, clearly with poor results. “Despite the changes, we are not back to Friday's level. We have an uphill race ahead of us. There will be a lot of work to do on George's car, and for Lewis it will be about damage control and trying to score some points.”
venkyhere
43
Dunlay wrote:
20 Oct 2024, 08:44
venkyhere wrote:
20 Oct 2024, 06:35
Juzh wrote:
20 Oct 2024, 01:14
He goes in too fast, that's it. Of course russell binned it on it's own.
it's a classic case of oversteery balance leading to a snap in a high speed corner.
Too much front DF w.r.t rear OR too little rear DF w.r.t front.
I wish Mercedes knew this simple fact! :lol: Of all the high speed corners, that's the one place such a simple issue strikes!
If you intend to patronize my post, ask yourselves the question - "why are members (including me) here, in an internet forum called F1-technical" ? You will have your answer.
We are not here because we are experts, it's because we are trying to bounce our layman-enthusiast ideas with each other, to satiate our hunger to learn and discuss more about the 'machine' aspect of the sport.
As to your question :
Of course Mercedes know this, the drivers know this... their fundamental problem is they are too sensitive w.r.t tyre temperature as regards the car's grip balance. Whatever 'setup' they had optimized for 35C track temp, is not just becoming 'sub-optimal' (like it does for other teams) if the track temp rises to 40C, it's becoming undrivable. Their car's aero grip isn't working harmoniously with mechanical grip. Everyone knows this. Probably you don't. And the reason the issue strikes in 'of all the high speed corners, that's the one place such a simle issue strikes' is because T19 is the place where both steering angle and cornering speed are both together super-high.
Hammerfist
Hammerfist
It’s a shame Lewis will probably have no clean air all race. I’m anxious to see how the old spec car compares to the new. Knowing Merc they probably didn’t optimize the upgrade yet. The car was better on Friday and they made it worse it seems. Or is it the others improved theirs from Friday?
As far as Lewis in quali he lost most of the time in turn 12 again. Just like on Friday but for a different reason.
https://www.planetf1.com/features/lewis ... grand-prix
Dunlay
Dunlay
venkyhere wrote:
20 Oct 2024, 16:42
Dunlay wrote:
20 Oct 2024, 08:44
venkyhere wrote:
20 Oct 2024, 06:35
For all of your explanation, trying to simplify the problem, the track temperature was 36C throughout Q3. Watch live timing replay on F1 app. George did two attempts in Q3, one where there was no such problem and he sets a time and the other when he crashed, despite track temps being the same. Guess what, the track temp was 35C in Sprint qualifying when that car was flying. Some basic research would help. It's better not to try and justify the oversimplification by using vague explanations. What happened in that particular incident is very peculiar and there must be far more intricate reason for it. That car is quite unpredictable and little changes are causing major behavioral issues. So I wouldn't try to sound like I know exactly why it happened, because I don't and I don't think most people know either.
Lasssept
123
George Russell will start the US Grand Prix from the pit lane running the Singapore spec parts. The team had to work during the night under parc fermé to finish the repair work in time. Hamilton will start from P17 on the grid. No setup changes for him.
https://x.com/tgruener/status/184802189 ... j0Lrg&s=19
Joel709
Joel709
Makes sense for George, having to revert to an earlier package as mentioned yesterday due to lack of parts, think they had no other choice
Joel709 wrote:
20 Oct 2024, 17:28
Why wouldnt they give him a new PU whilst they’re at it? Is that not permitted?
chrisc90
Surprised they didn’t take Lewis’ upgrades off given he offered them.
I’d be putting new PUs and components in both cars
Venturiation
Venturiation
103
Why aren't they changing setup for lewis too and get a new pu?
Parc ferme breach. It's probably going to be pitlane start for George.
#ReleasetheADUO
Luscion
Luscion
136
chrisc90 wrote:
20 Oct 2024, 17:31
Team member said it would take too much time with them having to strip both cars, put Lewis' parts on Russell's then revert Ham's car to old specs
