2024 Mclaren Formula 1 Team
CjC
CjC
mwillems wrote:
05 Jun 2024, 23:01
Cheers. That’s just the answer I was looking for when I posted the ‘rumour’ earlier in the week.
Response to all: I wasn’t *hit stirring when I posted the Instagram post. I’m a 24 year Mclaren fan for heavens sake, I was concerned and wanted to know if anyone knew anymore on the matter (isn’t that the point of a forum in the first place?)
However, in future I’ll refrain from posting when I’m so tired so I can articulated myself better.
Just a fan's point of view
LionsHeart
LionsHeart
There are still high chances of rain throughout the weekend. Well, in such conditions, in the same qualification, the difference between the cars will be calculated not in tenths, but in seconds. OK, we will see. Be that as it may, I hope that the race will take place in dry conditions. I also don't like red flags when the race is interrupted because the cars are kicking up a lot of water.
mwillems
46
CJC, As far as I'm aware no one accused you or thought you were sh*t stirring, don't sweat it.
-Bandit
bauc
bauc wrote:
06 Jun 2024, 09:29
mwillems wrote:
05 Jun 2024, 23:01
Like we all said, it was just a click bait :)
FIA selected LANDO's car by random choice, not deliberately - a key information that was missing in the post published on twitter (aka the ''source'') :mrgreen: .... instead, it was presented as FIA Is checking the legality of the Mclaren car as a intention/suspicion of wrongdoing, completely different case therefore a classic clickbait.
Cs98
Cs98
bauc wrote:
06 Jun 2024, 13:32
bauc wrote:
06 Jun 2024, 09:29
mwillems wrote:
05 Jun 2024, 23:01
These types of extensive inspections are always "random" officially. Sometimes that truly means it is random, as in picked out of a hat. Other times it's like 2023 USGP, where the FIA "randomly check" cars they have a suspicion about. No idea which was the case here, they passed regardless.
CaribouBread
CaribouBread
101
The start of the rumor was a single person speculating based on a reach (Leclerc quote), then to his credit, immediately rescinding and deleting the post. I thought it was put to bed that instant but nope.
Mountain out of a molehill again.
FittingMechanics
FittingMechanics
16
Seemed like a wild rumour but apparently there were real tests of the fuel system.
Btw makes little sense to check the car in Monaco. A track without ability to overtake.
Mattchu
59
LionsHeart wrote:
06 Jun 2024, 19:14
I'll wait until someone open a new topic on chassis 2026.
There already is one:
viewtopic.php?t=31296
I`m hoping we get a bit of wet running in free practise to see the water doing its thing around the various cars, plus Lando is a top wet running driver!
LionsHeart
LionsHeart
Mattchu wrote:
06 Jun 2024, 21:05
LionsHeart wrote:
06 Jun 2024, 19:14
Thanks a lot!
mwillems
46
-Bandit
BMMR61
mwillems wrote:
06 Jun 2024, 23:21
Sounds more like Lando!
hollus
A reminder to all NOT to use this thread as a catch all thread.
If it is not McLaren specific, it does not belong here.
Posts about the new regulation set, which affects ALL cars, are deleted (you get your post back by PM).
Feel free to post them here:
TANSTAAFL
FittingMechanics
FittingMechanics
16
John Noble (Autosport) journalist predicting a McLaren 1-2 :D
Let's hope he guessed right.
Jdn1327
Jdn1327
Cs98 wrote:
06 Jun 2024, 13:39
bauc wrote:
06 Jun 2024, 13:32
bauc wrote:
06 Jun 2024, 09:29
Is there even anything you can do to this fuel system to have an advantage? Isn't this a part supplied by the FIA?
LionsHeart
LionsHeart
Jdn1327 wrote:
07 Jun 2024, 10:35
Cs98 wrote:
06 Jun 2024, 13:39
bauc wrote:
06 Jun 2024, 13:32
The fuel system is usually developed by the engine specialists themselves. The FIA, for its part, can only supply sensors that read fuel consumption. Therefore, the person who posted the message that an investigation is being conducted against McLaren was greatly exaggerated. In that case, the FIA ​​could have investigated other cars with Mercedes engines for comparison. I am more than sure that the fuel line and fuel pump are identical for all Mercedes customers.
I did not discuss this topic for one simple reason. I was waiting for the team to respond at the official level. I did not wait until the FIA ​​posted a document showing that it was a routine check that did not reveal anything bad. I think this topic about fuel can be closed.
To close this topic, I will add. If I remember correctly, in 2019, Ferrari revealed their cards and told the FIA ​​how they managed to bypass the sensor that reads fuel consumption. It seems that the signal that reads the consumption per unit of time was known to the teams. Now, since 2020, the fuel system uses two sensors at once to read fuel consumption. And they operate at different frequencies, which does not allow engine specialists to bypass this loophole. The only case when this could happen is a failure of the fuel pump, which would go beyond the nominal operation, which would be immediately identified on the sensors by the Mercedes engine specialists.
