2026 F1 Cars - General Thread
lio007
327
Re: 2026 F1 Cars - General Thread
collindsilva wrote:
02 Jan 2026, 11:33
lio007 wrote:
31 Dec 2025, 15:37
collindsilva wrote:
31 Dec 2025, 11:16
Where is the info available, does FIA provide reports on the crash test or it is reported by other channels.
Somebody on Twitter posted it yesterday:
https://twitter.com/i/status/2005700609174036597
And no, the FIA don't reveal this kind of sensitive information whether teams have passed the crash test or not.
Wouldn't consider it as sensitive information, since the crash test are mandatory requirement from FIA.
I'd say the involved parties consider it sensitive, if not, it would be made public... that's my interpretation.
Hello everyone,
with the first visual interpretations of the 2026 regulations emerging, I found the Cadillac concept particularly interesting from an aerodynamic standpoint.
One element that stands out is the reintroduction of a nose cape (or mantle), a solution last seen prominently in the pre-2022 era, especially on Mercedes cars. With the 2026 rules moving toward a flat floor and significantly reduced wing complexity, it looks like teams are already searching for alternative ways to recover front-end load.
From an engineering perspective, the cape makes sense in this context:
it can generate local low pressure under the nose,
help condition the flow toward the leading edge of a flat floor,
and potentially create controlled vortical structures to improve underfloor sealing, even in a regulation set designed to reduce vortices overall.
A more detailed technical breakdown of this concept (with flow management considerations and 2026 constraints) is available here, if useful for the discussion:
https://www.newsf1.it/f1-2026-cape-cadi ... -analysis/
It feels like 2026 may not be a clean break from the past, but rather a selective revival of older concepts adapted to new constraints. I’d be curious to hear opinions on whether solutions like the cape can meaningfully compensate for the loss of Venturi effect, or if we’re looking at a fundamentally lower-downforce era regardless.
Stu
WRT front wing active flap control/hardware, how will the teams package this?
As I see it, using the main hydraulic pump and reservoir would require ‘dry-break’ hardware within the nose & bulkhead (this would usually have a manual lock collar to release the couplings and require a ‘fully charged’ system within the nose structure (in the event of a FW change in race conditions) with the inherent risk of allowing SOME air into the system during changes (resulting in poor performance).
A pure electrical system would have some positives in that there is already an electrical interface between the nose and bulkhead (CANbus, most likely) for reading surface pressure on the wing elements themselves but, for me, a directly linked servo-motor (or motors) would need to be of an unreasonable size to cope with the activation forces involved.
Will teams be running a self-contained hydraulic system (electric pump/reservoir and actuators) within the nose structure, could this be mounted to become a useful Tuned Mass Damper?
matteosc
matteosc
Stu wrote:
05 Jan 2026, 10:02
Are you sure a servo-motor solution would be too big? I think a lot can be done by using levarage, micro-gears etc...
Hydraulic solutions may be even bulkier (local) or complex (remote).
Stu wrote:
05 Jan 2026, 10:02
This is from 2009:
Beware of T-Rex
Stu
matteosc wrote:
05 Jan 2026, 19:49
Stu wrote:
05 Jan 2026, 10:02
I do, but that is due to the speed at which the flaps will be required to change position (particularly at deactivation), they MUST operate at the same point in time AND at the same pace as the rear system - which is already hydraulically actuated. If this is not achieved the drivers will be very vocal and the cars will exhibit a very strange aero transition between X & Y modes.
Stu
05 Jan 2026, 21:01
Stu wrote:
05 Jan 2026, 10:02
This is from 2009:
https://cdn-6.motorsport.com/images/mgl ... _ADJUS.jpg
Great illustration, and a very useful reference point (I think that it also backs up my point as well!?); this worked because it was used by the driver to adjust the front wing and balance the car, in my experience a LinAc cannot be made to operate quickly enough for the ‘instant’ change required. At the same time rotary servo-motors would need to be synchronised side to side (anyone that has owned an original MX5/Miata/Eunos Roadster will be aware of the ‘winking’ phenomenon and operational time difference between two synchronised servo-motors!).
Hydraulic operation would allow you to move the bulk into the nose and retain small actuators, also the technology for hydraulic operation at speed is widely understood (been the de facto method for DRS since its introduction).
Stu wrote:
06 Jan 2026, 09:02
05 Jan 2026, 21:01
Stu wrote:
05 Jan 2026, 10:02
This is from 2009:
I wonder if any team considers a cable system.
Beware of T-Rex
dren
228
06 Jan 2026, 09:43
Stu wrote:
06 Jan 2026, 09:02
05 Jan 2026, 21:01
This is from 2009:
At least in the detachable part of the nose, have hydraulic actuators in the chassis. A cable or rod system.
Honda!
Stu wrote:
05 Jan 2026, 10:02
The hydraulic in the nose can be isolated and actuated by mechanical piston.
dren
228
PlatinumZealot wrote:
09 Jan 2026, 05:08
Stu wrote:
05 Jan 2026, 10:02
That seems the most straight forward way to me.
Honda!
mzso
mzso
75
Are there dates revealed when the cars will first run on PR runs or whatever they are called? (at least that is where we they usually did recently.)
Giando
93
Front suspension is surely a push-rod. Nose cone is higher and sculpted in the lower part, as expected.
Quite high sidepods for now at the back and with a different shape compared to previous generation of F1s.
GoranF1
GoranF1
149
Why is all this in team thread?
mzso
mzso
75
Giando wrote:
09 Jan 2026, 17:40
https://youtu.be/r2mcEg92Qdo?si=M9Jb1dx47q7PZRqW
Nothing drastic here. New rear and front wing, and bargeboard. otherwise it looks almost identical to 2025's cars.
GoranF1 wrote:
09 Jan 2026, 18:29
Maybe because there's no car thread yet. Not even a speculation thread.
