McLaren MCL38
232
Re: McLaren MCL38
I did not really consider it, but Oscar Piasti stated that with the upgrades the low speed perfromance improved, and the window is wider for the tyres, but he noticed a reduction in the high speed perfromance. Interesting observation by him. We wont really know why this is so as onlookers, but based on their upgrades could it be the floor or front wing causing this shifting of their capabilities?
I was suggesting that refining the engine cover could claw back some drag reduction allowing them to up downforce for the high speed corners.
mwillems
45
Re: McLaren MCL38
ringo wrote:
21 May 2024, 15:36
I don't think it is to do with the abilities of the car to generate downforce per se. I would imagine it is more to do with how they are now able to set the car up based on the way the airflow is conditioned. In any corner they need to keep the floor flat and low to the ground as possible, but the demands in each of the corners are very different and the way they can get the car to work in those corners are now also different based on changes to the front wing, the floor and the sidepods.
I would assume that with these changes the car has a new range of settings that will work in low speed corners and another set in high speed corners. Each corner type will have its optimal setting and there's a window where these settings overlap. This window of potential and optimal settings across different corner types has moved slightly away from highspeed but greatly opened up what we can extract out of low speed.
If you were to set the car up for purely high speed, it'd be probably at least as good as before, as the ability to generate DF at high speed hasn't gone I don't think. So I don't think that the car isn't as good in high speed. It's just that it will be set up with different balance than before. But if you set it up purely for low speed, as we've seen, it will be nearly as good now as when we set it purely for high speed. But when we try and balance for these "non-isochronal" tracks, then we can overall extract more time but lose a little bit in high speed.
-Bandit
f1rules
f1rules
621
Re: McLaren MCL38
Re: McLaren MCL38
Top of the Sidepod...
f1rules
f1rules
621
Re: McLaren MCL38
its a strake to keep the diffuser/floor in place under load
LionsHeart
LionsHeart
Re: McLaren MCL38
mclaren111 wrote:
23 May 2024, 12:07
https://i.ibb.co/qj16P7T/GOQQIETXo-AAEHNR.jpg
Here is the updated rear wing and beam wing that Oscar tested at the beginning of third practice. It looks different from the version that debuted last year in the Netherlands and Singapore.
Tomsky
Tomsky
29
Re: McLaren MCL38
SilviuAgo
16
Re: McLaren MCL38
Rear wing for Monaco
And a throwback time in 2023, just for fun:
mwillems
45
Re: McLaren MCL38
It's our bigger wing but with the efficient winglets. This is a small reduction in downforce for a bigger gain in efficiency.
Similar wing to last year but I notice others are running smaller wings than last year.
-Bandit
Tomsky
Tomsky
29
Re: McLaren MCL38
Re: McLaren MCL38
Having some colour on the bodywork really lets us appreciate how tight new sidepods are.
Flattening the shape of the top surface suggests they wanted to reduce the curvature and lift on top, something I expected RB to do, but this direction now applies to all top 3 cars
LionsHeart
LionsHeart
Re: McLaren MCL38
mwillems wrote:
23 May 2024, 12:46
No. Red Bull is comparable to the previous year. Ferrari's rear wing has become even larger compared to last year. Aston is comparable, McLaren is comparable.
Edit: The top flap size of McLaren is smaller than that of Aston and Red Bull, but comparable to Ferrari.
Tomsky
Tomsky
29
Re: McLaren MCL38
Re: McLaren MCL38
Is this an Air Outlet ?
101FlyingDutchman
101FlyingDutchman
Re: McLaren MCL38
mclaren111 wrote:
23 May 2024, 15:57
https://i.ibb.co/yXFRz0t/racefansdotnet ... Hi-Res.jpg
Looks like different carbon weave direction in that lower panel. Making it appear like an opening
