Sergej wrote:
23 Sep 2024, 23:45
here's how to stop Lando from winning
fit Checo with a new engine in Austin, gauge the engine to last only two races, take Austin super easy and then go banzai in Mexico City, super party mode in quali and 70 laps on full beans; then bin the engine and repeat for Interlagos-Vegas.
Hmm this engine sacrificing approach in the run-in seems familiar. Probably just my imagination
ispano6
164
Maximizing sprint race weekends is crucial, the points from the sprint race will make a difference. So would an extra point for pole position!
I forget if penalties can be applied to sprint instead of a race. Like starting from the back of the grid.
Paa
ispano6 wrote:
24 Sep 2024, 01:41
No.
Watto
Watto
On a somewhat unrelated subject. I wonder if there is any scenario where now that it looks like the constructors championship is gone - even Red Bull are admitting that. If their is any way they would look at wanting to drop to 3rd behind in the constructors championship. - more to me that their development path has taken a bit of a mis step this year. Would the extra wind tunnel and CFD runs maybe something they need so just so they can maybe put that to good use - maybe the system is working (add in their budget cap penalties) are starting to have the desired effect.
TimW
TimW
36
Watto wrote:
24 Sep 2024, 07:48
.... - maybe the system is working (add in their budget cap penalties) are starting to have the desired effect.
That could very well be the case. Developing updates while having little wind tunnel time, and thus being forced to do little model validation, is an excellent recipe to lose correlation between models and reality.
KimiRai
KimiRai
301
Austin track is being resurfaced apparently. Does this help the car?
Cassius
Cassius
KimiRai wrote:
24 Sep 2024, 10:20
The car is strong when driven low and stiff, so that would help. However, new track surface often leads to graining. RB had a lot fo graining issues in recent GPs that were resurfaced, especially compared to McLaren. If car is less well-balanced, RB will suffer more than McLaren.
mendis
mendis
19
KimiRai wrote:
24 Sep 2024, 10:20
It should, some of their issues are also related to bouncy tracks. IMO, now that they have lost the WCC, they should use Perez as a mule to test their upgrades and use the whole of US weekend to simply measure the upgrades. It's a sprint weekend, so no point using Max to do any upgrade experiments.
Paa
mendis wrote:
24 Sep 2024, 11:18
KimiRai wrote:
24 Sep 2024, 10:20
It's fine. If upgrade doesn't deliver then it is over anyway.
So they can just put it to Max so he can make use of it in case it works.
Also they can test the setup during sprint then they can make adjustments now so setup shouldn't be too big concern.
KimiRai wrote:
24 Sep 2024, 10:20
Austin is constantly resurfaced and fails to resolve anything. They have drainage issues due to decisions made when building the circuit, so the ground beneath circuit constantly moving and creates the uneven surface as soon as they fix it.
I don't think it will make a big difference. The combination of the high-speed esses in S1 and the long radius slower corners in S3 will play totally into McLaren's hands and they'll be strong at cota.
For me I've written off interlagos and Mexico, and partially COTA as well
Sergej
which race could be winnable, provided the Austin correction delivers ? Vegas ? McLaren won't have their "magic" rear wing, could help in beating them
Vettel165
24 Sep 2024, 11:51
KimiRai wrote:
24 Sep 2024, 10:20
I am thinking high speed corners are areas in which Red Bull is still the strongest. In S1 Red Bull could be stronger than Mclaren with the right setup, Mexico, Brasil is usually a high downforce setup because of high altitude. None of the races are a write off for us, because we were strong in our worse tracks (Singapore, Baku). Red Bull doesnt like bumps, high kerbs and a lot of slow-speed corners. Also mainly all the races until the end will be hot. Lets go, bring it home boys. [-o<
Sergej wrote:
24 Sep 2024, 12:09
Qatar, Vegas and Abu Dhabi I'm thinking
Cassius
Cassius
24 Sep 2024, 12:27
Sergej wrote:
24 Sep 2024, 12:09
Qatar and Vegas were already very difficult with the RB19. Mclaren and Ferrari were pretty close. So maybe Abu Dhabi, although McLaren is likely to be better there as well.
avantman
avantman
Cassius wrote:
24 Sep 2024, 12:51
24 Sep 2024, 12:27
Sergej wrote:
24 Sep 2024, 12:09
mclaren was fastest car in qatar, ferrari was fastest in vegas. not just close.
