2026 Aerodynamic & Chassis Regulations
Hoffman900
Hoffman900
220
Re: 2026 Aerodynamic & Chassis Regulations
https://www.researchgate.net/figure/Dow ... _228616843
Flat floor(plate floor) vs venturi floor. With and without vortex generators.
Venturi floors have a higher peak and a much steeper falloff.
hsg
hsg
Hoffman900 wrote:
19 May 2025, 17:30
Is floor for 2026 flat+diff or venturi?
Hoffman900
Hoffman900
220
hsg wrote:
19 May 2025, 23:20
Hoffman900 wrote:
19 May 2025, 17:30
I believe they’re mostly going back to a flat floor. Look at previous iterations and you can see the VG’s are either on the leading edge or they’re on the barge boards.
https://www.researchgate.net/figure/Sch ... _228616843
hsg
hsg
Hoffman900 wrote:
19 May 2025, 23:58
hsg wrote:
19 May 2025, 23:20
Hoffman900 wrote:
19 May 2025, 17:30
Do we have 2026 written regulation, so we can find rules for floor?
mzso
mzso
68
vorticism wrote:
17 May 2025, 21:59
How much shorter are the '26 cars expected to be? (or prescribed to be) Not this short I assume. I assume crash structure performance might limit how short FIA-approved cars could become. Regardless, one goal looking forward could be to make Monaco less precessional via narrower and shorter cars.
https://i.postimg.cc/N0dnDWNN/s1.jpg
https://i.postimg.cc/76bWWmdq/s2.jpg
https://i.postimg.cc/3R6c52Qm/s3.jpg
https://i.postimg.cc/cCn5s6dj/s4.jpg
I don't think crash structure limits anything. Stuff, including crash structures, would just be bulkier with a shorter car.
Hoffman900
Hoffman900
220
Everyone keeps talking safety, but IndyCar drivers routinely walk away from 90-100g plus crashes, and those cars are lighter (in speedway trim) and significantly shorter.
I’m not convinced a F1 car would survive / driver fair as well on a crash on an oval.
mzso
mzso
68
Hoffman900 wrote:
20 May 2025, 13:13
What are the differences in size and weight?
Hoffman900
Hoffman900
220
mzso wrote:
23 May 2025, 19:09
Hoffman900 wrote:
20 May 2025, 13:13
IndyCar:
1785lbs (809.6kg) in RR trim,
1740lbs (789kg) in oval trim.
Excluding driver which is set at 185lbs (84kg). Also excludes fuel (70L when full)
With fuel (methanol) they’re around 2050-2092lbs (930-949kg) sitting in the grid w/driver.
The hybrid added 105lbs (47kg) to the cars.
Length: 201in (5.1m)
Width: 75.5in - 76.5in (1.91-1.94m)
F1:
1764lbs (800kg) with driver, excludes fuel (130L - ish).
Length: 222in (5.63m)
Width: 78.77in (2m)
With fuel, just a little over 2,000lbs (908kg)
I was wrong about lighter as I forgot Indy is w/o driver and F1 is. IndyCar being a spec series, there isn’t any incentive for the suppliers to take out weight to the n’th degree like F1 can, which would increase costs.
mzso
mzso
68
That rather sheds a positive light on their crash safety. Being heavier but and shorter, the car still protects the drivers well, in heavy oval circuit crashes.
vorticism
vorticism
356
After 12 long, monotonous, droning, what you might call vacuum-cleaner-esque seasons, Red Bull might finally get air-water intercoolers with RBPT/Ford. Will Newey suggest air-air intercoolers for AMR-Honda? Or were they always chosen at the behest of the power unit manufacturer? As what might have been Red Bull's case 2014-2025 with Renault & Honda. Renault iirc introduced their air-water IC after RB had switched to Honda, and Honda have yet to develop one for F1. That too might change, if it was part of Honda's own preparations for 2026, or requested on the part of AMR.
SB15
SB15
All I know is we're going to see some crazy concepts. Almost as crazy as the pre-ground effect cars especially with around the new bargeboards area and floor edge. I don't care what you guys say, these cars are going to look epic and I'm mostly excited what the Mclaren MCL40 and the Mercedes W17 will look like.
F310AlexB
The NEXT FORMULA PROJECT, spearheaded by the Japan Motor-Racing Industry Association (JMIA), unveiled a groundbreaking 50% scale model of the 2026 F1 car at the People and Cars Technology Expo 2025 YOKOHAMA, held at Pacifico Yokohama from May 20, 2025.
jjn9128
780
F310AlexB wrote:
14 Jun 2025, 22:24
https://media.imagepond.net/media/The-N ... 74c0cc.jpg
It's nothing to do with the FiA, slightly irritating composite image typical of the twitter/instagram karma farming, also not legal in many ways.
#aerogandalf
Fakepivot
Fakepivot
could bathtub pod of f-75 make a come back? since there no beamwing :?:
mzso
mzso
68
Fakepivot wrote:
15 Jun 2025, 19:00
How are the the two related?
