2025 McLaren F1 Team
taperoo2k
taperoo2k
Re: 2025 McLaren F1 Team
bauc wrote:
26 Feb 2025, 21:33
taperoo2k wrote:
26 Feb 2025, 17:41
Seanspeed wrote:
24 Feb 2025, 23:42
The guy wasn't denying that, though. Only arguing about the degree to which it was actually true. Because this is all about nuance and degrees of truth, if you yourself even agree that they aren't on equal footing. You simply side on the collaboration being much stronger, while the other person believing the collaboration being less strong. You're not fundamentally disagreeing on the core argument here, which you've been trying to portray them as doing, and the only reason I felt like speaking up.
McLaren have a more preferential deal with Mercedes vs other customer teams by the looks of it. It allows for a certain degree of input on the PU design, helpful when you build your own gearboxes. And it sounds like they might be first in the queue for newer parts that the works team will obviously get first. I'd not call it a semi works team deal. More like an Enhanced Customer Deal. At the end of the day, if the Mercedes F1 team wins the constructors or McLaren does? Still great marketing for Mercedes "Look even a customer team can win with a Mercedes AMG HPP Engine in F1".
It could well be a great move by Zak Brown signing a new deal with Mercedes for the PU's. We'll find out in '26.
Mclaren already has a deal with Mercedes till 2030
https://www.formula1.com/en/latest/arti ... 4r4mi0vhT5
That was the deal I was talking about. If the Mercedes PU in '26 is as good as the 2014 PU in terms of performance, then McLaren will be in a good place.
bauc
taperoo2k wrote:
27 Feb 2025, 23:27
bauc wrote:
26 Feb 2025, 21:33
taperoo2k wrote:
26 Feb 2025, 17:41
Aha.... I misunderstood your point, all clear :D
the EDGE
the EDGE
68
taperoo2k wrote:
27 Feb 2025, 23:27
bauc wrote:
26 Feb 2025, 21:33
taperoo2k wrote:
26 Feb 2025, 17:41
When you say McLaren are first in queue, that’s not correct. If Merc update the PU spec, no team (including merc) can run the new spec unless it’s available to all customers at the same time - assuming that’s what you mean
FittingMechanics
FittingMechanics
16
So McLaren brings a new aggressive suspension (front and probably back) which affects the car down the line but we still get people claiming it is normal that McLaren understands the car more than Ferrari.
Btw Wache from Red Bull said that McLaren suspension is interesting but that he thinks it would be too risky for them.
Quite positive that the car seems to worl well on day 2. I guess Rob Marshall showing his skills.
Nicktendo86
Nicktendo86
Absolutely no coincidence that Rob Marshall is in the team imo. He’s made a massive difference and the fact he worked with Prod at Red Bull during the Vettel era is also probably no coincidence.
mwillems
46
Emag wrote:
27 Feb 2025, 21:38
CjC wrote:
27 Feb 2025, 21:29
I always think Mark has a few good nuggets of information- like how Lando went purple in the middle sector doing pitstop practice which I missed.
However, what data was he looking at to have Lando slower than Leclerc AND Antonelli in the second stint?
https://www.the-race.com/formula-1/mark ... -analysis/
Incredible. This is what passes for top tier journalism in this sport? There were fans in this forum keeping track lap by lap who gave a better overview of the data than this excuse of an article.
One of the comments highlighted the error and he's corrected it.
-Bandit
Emag
Emag
FittingMechanics wrote:
28 Feb 2025, 00:00
I think it's because the race sim by Lando was so good, people are being extra scrutinous when it comes to finding all the possible reasons why it was that good. I understand why people would assume Ferrari has more to learn, and that could very well be true, but I doubt it's really as significant as some people are making it out to be.
The switch from push to pull rod at the front is primarily made for aero reasons as multiple engineers employed on the field have pointed out numerous times. The mechanical differences between the two are not as significant. I don't understand why Ferrari would somehow be in a position where they're in level zero when it comes to setup knowledge, just because they switched from push-rod to pull-rod. Mechanically-speaking, the same principles will still apply and their knowledge gained from the SF24 applies as well.
Every team starts the new season with plenty of things to learn. All cars are developed with specific weaknesses targeted and taken into consideration. Sure, some might have had more weaknesses to explore and work around, but the premise that any team is capable of fully optimizing a new package in day 2 of testing is flawed in my opinion.
There are a lot of caveats that apply when analyzing testing data, so there are no conclusions that can be made with any degree of significant confidence.
We can however make observations. And those observations, at least today show that McLaren had really strong race pace.
Now does that mean this will be the case come Australia? No, it doesn't. However in the context of testing, it's obviously a very competitive showing. You're not really proving anything by showing capabilities of that pace, but you're not exactly sad for being in this position either.
Developer of F1InsightsHub
CjC
CjC
mwillems wrote:
28 Feb 2025, 00:08
Emag wrote:
27 Feb 2025, 21:38
CjC wrote:
27 Feb 2025, 21:29
He has indeed, now his article makes more sense and brings him inline with everyone else’s thinking…. Apart from Lawrence Barretto
Just a fan's point of view
CjC
CjC
mwillems wrote:
28 Feb 2025, 00:08
Emag wrote:
27 Feb 2025, 21:38
CjC wrote:
27 Feb 2025, 21:29
mwillems
46
A quick look at the telemetry on my mobile suggests it is the low speed corners that we are stronger in through all phases of the race sim. This is mainly where our time is found.
Engine modes etc won't affect this, only fuel loads.
Feels like fuel loads are likely to be close, so it feels like this is the first major improvement that can almost be confirmed for this car.
Given the cars are comparable in other areas of the race sim, this does suggest that we may ebb and flow at different tracks.
Bahrain may flatter us, so my advice is caution, there's a long way to go.
-Bandit
Emag
Emag
Car looking nervous when pushed today.
DragonSGC
DragonSGC
Lando does not look like hes having much luck with whatever setup they have him on currently, seeing as its his last day I guess they doing some quali sims, not fully quali fuel perhaps and I know the wind is up but yikes it looks a handful,
elldizzle
elldizzle
Just came on here to comment the same thing. has taken him about 4 aborted laps to set one time. Not too sure where they have the car but it seems very unstable on the rear.
mwillems
46
They are most likely just trying some different settings to see if there's anything surprising.
Time and again teams find a setup option late in a season that suddenly unlocks a tenth or two, with the results being unexpected from some slightly more exotic setup choices.
-Bandit
FittingMechanics
FittingMechanics
16
The track seems to be very slippery/windy at the moment. All cars (VER and LEC included) are making mistakes. Still, NOR managed a decent lap on 3rd or 4th hot lap of what will be a soft tyre.
Temperatures are much higher today, track 32C at the moment. Yesterday it was under 20C track all day.
