Aston Martin AMR26
wiktor977
wiktor977
43
Re: Aston Martin AMR26
f1316
88
Brahmal wrote:
07 Mar 2026, 04:36
07 Mar 2026, 01:22
The Aston Martin is running the largest cooling exits by a long way. IT's strange because they are reportedly running 100hp down on an already very limited PU. Why do they need this much cooling?
OTOH their intake size is one of the smallest in the field. I think they are trying to create suction to pull air through the system, instead of pushing it in through bigger intakes. Alpine appears to have the opposite philosophy.
It’d probably be most interesting to compare vs Ferrari, given that car is the only other one with the small rollhoop intake
Brahmal
Brahmal
73
f1316 wrote:
11 Mar 2026, 23:05
I meant total intake/inlet area, sidepods included. Ferrari's side intakes are quite large, as I don't believe they have any centerline cooling. .
Farnborough
Farnborough
152
In the first image it can be seen the "bridges" from one side of brake caliper to the other (silver metal surround that series of holes) the brake disc periphery with small bore multiple holes to vent, also the brake pad next to that (the division clear from the line between the two) also having holes in larger bore to flow cooling air through the pad material.
In third image, can be seen just how far that top knuckle joint for upper rear wishbone location is outboard from chassis centre and far into the wheel that will surround it. Looks more or less central to tyre width in location, with that link going to the rear wing pylon location chassis side, it will provide the longest possible link length in optimisation of wheel geometry "curve" and desirable to control better the suspension travel dynamic involved there.
There's some very adventurous thinking in this chassis (as expected) which looks to give positive potential in this rules set.
We've not been able to see clear hard performance, yet. It looks like there's going to be a lot more to arrive when some of the headline fundamental issues are resolved.
Interesting...Another front wing for China.
Beware of T-Rex
FNTC
FNTC
Is it back to the first wing but maybe with a larger 3rd element? It doesn't even have the outwashing strakes on the footplates.
FNTC wrote:
12 Mar 2026, 19:55
Hmm, maybe I would hold off for now. Teams are known to use old wings during pitstop practice.
Beware of T-Rex
12 Mar 2026, 20:12
FNTC wrote:
12 Mar 2026, 19:55
I was gonna say, China is front limited and that "new" wing looks like it has less wing.
Leon Kennedy
Leon Kennedy
12 Mar 2026, 19:47
https://pbs.twimg.com/media/HDOPbIrXUAE ... name=large
It's incredible how the Melbourne winger looks a lot like the one from Imola 2024.
vorticism
vorticism
449
One nice side effect of the longbow and rigid anchors in general is that it would make set up easier. No fumbling with the ends. Just hold the upright up to them, insert bolts, done. No ball joints to accidentally over-stress.
Wheel hollows:
@n_mode_log
Beware of T-Rex
Rear brake. There's a strange cover on the disc, behind the caliper. Maybe it's a Suzuka adaptation to keep the rear brake disc warm since there is so little braking here.
Beware of T-Rex
The "imola wing" is back
Beware of T-Rex
26 Mar 2026, 15:45
https://pbs.twimg.com/media/HEU9ULibAAA ... name=large
They ran that in China too. I think they had the other wing just for the build up. Might mean they have a new wing ....
diffuser wrote:
26 Mar 2026, 19:36
26 Mar 2026, 15:45
Ah right, I didn't catch the follow up in China where I suggested they were using the old one for pit stop practice.
Beware of T-Rex
