Cut Tyres
beelsebob
beelsebob
85
Re: Cut Tyres
strad wrote:
beelsebob wrote:
strad wrote:SO it once again proves my point that the drivers should be required to drive ON the track...If they cut a tire becuase they want to straightline a corner..too bad..
That said,,,I would have sworn I saw Massa run over somethuing just prior to his tire letting go.
They do drive on the track. The track is defined as all area in which you can have some part of tyre touching the white line.
Sorry...You're wrong..The track as defined by the FIA is between the white lines.
FIA Sporting Regulations wrote:A driver will be judged to have left the track if no part of the car remains in contact with the track.
The FIA define it as having any part of your car in contact with the white lines or the tarmac between them.
Cam
45
Re: Cut Tyres
And further to that, some discretion is given per track isnt' it. Wasn't there several cases where the cars were clearly 4 wheels off the track but were given approval for that corner?
Abu Dhabi 2012 (race thread) - this was discussed at length.
raymondu999 wrote:Yeah, everyone was doing it.
Example:
http://i14.photobucket.com/albums/a308/ ... 4754PM.png
― Socrates
krisfx
krisfx
Re: Cut Tyres
Cam wrote:And further to that, some discretion is given per track isnt' it. Wasn't there several cases where the cars were clearly 4 wheels off the track but were given approval for that corner?
Example:
Yeah at Monza they run all four wheels off track at the Variante Ascari, but the FIA let them do it because they have for so long, the system is track specific, and I imagine the drivers are told beforehand what they can and can't get away with
