I like this,ESPImperium wrote:My proposals, which are achievable.
* Ban cascade wings on front wing, make cars understeer more.
* Standardised steering rack - Make power steering half as powerful as present. Aid yes, not do all the work.
* Standardised active suspension - Allow the driver to tune the ride, but only 3 times per Quali session & Race, unlimited in Fridays & P3. Also cuts costs.
* Re-Introduce the beam wing and increase rear wing width to 2008 size. Beam wing shall have a standardised and aero neutral section in the middle.
* DRS limits, each driver has 150 seconds (1.5 Minutes) per race of DRS, this can be used by driver when he wants - if his car will allow, and for how long, no stupid DRS zones.
* Tyre war - Two tyre companies will manufacture 3 compounds for the entire season. Every race each driver has 5 soft, 4 medium and 3 hard for the entire weekend. P1 drivers get an extra set of mediums. Tyre companies can make one change to a single compound per year as a joker. Hards last a maximum of 200Km/65%, Medium a maximum of 160Km/50% and Softs a maximum of 110km/35%. Each car has to run at least 2 compounds per race, allowing drivers to drive on a hard 2 stopper or more conservatively to a 1 stopper race. Pit windows yes, almost, but more Drivers/Racers battles.
* Steering wheels, limit them to 5 rotaries and 8 buttons or switches. Each button/switch does what it says it does, no Diff Magic crap. However if a Multifunction rotary needs to happen, one other rotary and three buttons car assigned to it permanently.
* Live telemetry is limited to just 32 streams per car, and must be open to all to see. Any more streams must be downloadable after a session. With this a ban on Mission Controls during a live session is also a must.
* Driver coaching Bite Points and Dog Learning on the parade lap is fine, but no tech info on engine or fuel mixes or "where am slower" whilst the car is on the track, pit lane whilst a pit stop yes, track no. Track conversations must be limited to Weather, personal timings to that driver and no other.,
* Bring that bloody nosecone up to the height of the front axle for gods sakes, give the aero guys something back.
* Make ERS systems free and open to development, but allow the teams to use them for 45 seconds a lap. Id open MGU-K, MGU-H, Control Electronics & Batteries open for free development, just as long as each component did not exceed 5 for the season.
with some minor tweaks regarding the sections i coloured red:
Driver Coaching: I think parade lap coaching and updates are indeed a good thing to keep, but instead of halting the entire coaching from thereon, I'd say they should only be allowed the same level of 'coaching' or communication on pit entry and pit exit (between the lines), and during safety car period. Calls for a pit ('pit pit pit now, repeat, pit pit pit) should be allowed during the entire race, safety concerns aswell (debris, oil, or accident on turn whatever), and technical damage info should be allowed during the entire race, too (damaged front wing, tire pressure leak, engine failure).
you can't keep engine info out of it because they're limited to a certain amount of powerplants, and it would be unfair to impose radio clampdown with a result of engines getting destroyed because they can't be told to park the car or run the engine in safe mode).
Steering wheels: i'd say there should be no more than 2 rotaries regarding engine settings; off, safe mode or normal mode,
and the other for the electronic part (hybrid), off, safe mode or normal mode.
and an additional rotary for brake balance. total of 3 rotaries max.
Pit limiter, radio button, drink button, reverse, and 2 additional ones.
6 switches and 3 rotaries.
Allow distance info from Fia's official live timing through the steering wheel on car in front and car behind, but 5 seconds across finishline ( gap and laptimes ) paired with driver number. f.e. : cross finishline and on the display appears:
▲ # 3 - 1:25.667 [ - 6.778 sec. ]
▼ # 12 - 1:25.890 [ + 1.334 sec. ]
Active suspension: ban.
