turbof1 wrote:gruntguru wrote:To quote some numbers we know, the Honda RA167E had 50% more power than the engine that replaced it - the RA168E. Did Honda save significant weight by paring down critical components in line with the reduced power? I don't think so.
What I'm getting is that safety margins are very marginal, just enough to barely cover a hot race. The safety margins aren't at 100%. Let's reduce that to 3-4% and we are much closer to the reality.
In terms of the stresses created by cylinder pressures, margins are much higher than that. Besides, those particular stresses do not increase in direct proportion to boost or BMEP. In fact if CR is reduced, they need not increase at all.
Not a fair comparison since the reduced boost and fuel restrictions forced Honda to start with a blank sheet of paper concerning its engine. It was a very conservative approach, of which I'm sure they were able to cut weight by a lot later on. Naturally, since they were allowed to make as many updates as they liked at any time. That's something you can't do anymore. Manufacturers got a heads up on the new engine rules 3 years before introduction, and are only allowed to change half of the PU in the second, progressively freezing the PU over the years. There is no scope to play it conservative as Honda did because of the restrictions on development, so you are automatically starting with much smaller margins.
This is first year out with a brand new PU. It appears they are already at 850 hp. Incremental development will have them pushing 1000 within a couple of seasons - in spite of the rules dictating annually diminishing lattitude to beef-up critical areas to cope with power increases. There is no way in my mind these PUs have been pared down to the fragile limit. The weight savings you refer to are minute, the engines have to meet a minimum weight and CGH of the engines is regulated.
My opinion - the power output of the ICE could be
doubled without any changes to the head, block, rods or crank.
