Technical Directive 12/05/25
miguelalvesreis
miguelalvesreis
Re: Technical Directive 12/05/25
vorticism wrote:Not sure about that. TD039 was supposedly iirc about plank flex and the location of plank portals that permit access of the FIA chassis & plank deflection test rig apparatus. This new topic is about the skid blocks, which if I've read the rules correctly could be mounted to the plank independent of the chassis and if so, there's Greg's compliant substrate. Just my guess.
Nevertheless, if attached by bolts, those need to be the weakest link
So the substrate would have to be more rigid than the bolts
Only if you could, somehow, create a gap and have some elasticity on the part of the bolt that lays on that gap
But, most probably, bolts materials are also regulated
Enviado do meu RMX3572 através do Tapatalk
vorticism
vorticism
334
“If used to attach a skid to the car....” Apply to whether or not the wording intends to imply “car” as chassis or any part of the car (i.e. plank) as “car.” If plank is car, then the bolts could be stronger than a locally compliant part of the car known as the plank. Otherwise it would force the skids to be bolted to the chassis with or without sandwiching the plank in the expected manner.
atanatizante
125
I've asked about how could FIA prevent the floor not no bend/flex under a certain increased load in the same manner as the FW and RW are flexing now... is the TD039 related to this matter?
Jesus
