Ferrari F60 aero-mech development in 2009
SpookTheHamster
SpookTheHamster
Re: Ferrari F60 aero-mech development in 2009
Anyone notice the Red Bull style ridges on the car this morning? Looks like they've made some new chassis in their time off, their photocopiers must have been working overtime.
wrcsti
wrcsti
SpookTheHamster wrote:Anyone notice the Red Bull style ridges on the car this morning? Looks like they've made some new chassis in their time off, their photocopiers must have been working overtime.
Not a new chasis. They are "glued" on, just like brawns. RB's is part of the chasis.
BreezyRacer
BreezyRacer
Toyota did the same ..
bar555
bar555
GP MONACO
1.Front Wing
2.Steering
3.Front brake ducts
4.Front wheel ring shields
5.Hot air exit – engine cover
6.Floor in front of the rear wheels
7.Rear wheel rim shields
STEERING IN MONACO
Anti Ackermann geometry
RIDE HEIGHT IN MONACO
MASSA ACCIDENT IN MONACO
Special thanks to FLC
Future is like walking into past......
Blog : http://formula1techandart.wordpress.com/
Twitter :http://twitter.com/bar555onF1
bar555
bar555
FRONT WING - MONACO
A small gurney flap was also added at the rear tip of the second plane .
REAR WING - MONACO
BARGEBOARDS - MONACO
ENGINE COVER - MONACO
EXHAUSTS - MONACO
Similar exhaust outlets to Spain but in addition there was a larger triangular hot air exit at the end of the engine cover due to the lack of the longitudinal side cut . Probably that engine side cutting influenced negatively the rear wing .
bar555
bar555
REAR FLOOR - MONACO
DIFFUSER - MONACO
FRONT BRAKES - MONACO
FRONT WHEEL RIM SHIELDS - MONACO
REAR WHEEL RIM SHIELDS - MONACO
bar555
bar555
GP TURKEY
Undergone changes from Monaco
1.Lighter KER system
2.New rear Wing
3.Modified DD diffuser
WEIGHT DISTRIBUTION , BALLAST - TURKEY
Weight distribution front : 44 % rear : 56 %
Total ballast used = 25 kg
FRONT WING - TURKEY
bar555
bar555
REAR WING - TURKEY
EXHAUSTS - TURKEY
DIFFUSER - TURKEY
Above : Monaco
Below : Turkey
FRONT BRAKES - TURKEY
REAR BRAKES - TURKEY
Gonner
Gonner
Excellent job, nice. Can you explain why the new DD had " teeth " in Turkey. I understand the need to reduce vortices, hence the teeth in the floor; next to the rear wheels, but I don't see the point on the DD.
Thanks
Callum
Gonner wrote:Excellent job, nice. Can you explain why the new DD had " teeth " in Turkey. I understand the need to reduce vortices, hence the teeth in the floor; next to the rear wheels, but I don't see the point on the DD.
Thanks
i thought that the teeth created vortices?
Michiba
Michiba
I think they create a bunch of small vortices rather than one big one. There is some discussion somewhere here relating to barge boards. Not sure if the same principles apply because those teeth are much smaller than the 'steps' in Ferrari's barge boards of previous years.
bar555
bar555
GP G. BRITAIN - SILVERSTONE
Evolution never stops and Ferrari continues to develop heavily the F60 to match the rivals pace .
Undergone changes from Turkey
1. New lighter chassis for Massa No 277
2. Modified front wing
3. New front suspension wishbones to change weight distribution
4. Modified front wheel fairings
5. Lighter KERS
6. Slightly modified rear wing
7. New rear axle winglets
bar555
bar555
FRONT WING - G. BRITAIN
REAR WING - G. BRITAIN
bar555
bar555
FRONT BRAKES - SILVERSTONE
FRONT SUSPENSION - SILVERSTONE
With their 30kg KERS system immoveable, the only chance for Ferrai to considerably alter the F60's weight distribution was to move the front axle backwards. They have done this for Silverstone by altering the angle of the suspension arms (previous angle in yellow). Of course, to do this they have also had to introduce a new nose, which had to pass the mandatory crash test
from www.f1.com
FRONT WHEEL RIM SHEILDS - SILVERSTONE
REAR AXLE WINGLETS - SILVERSTONE
New T shaped winglets were added on top of the rear brake ducts to add some downforce
bar555
bar555
GP GERMANY (NURBURGRING)
Undergone changes from Silverstone
1. Different front wing’s version for Raikkonen and Massa
2. A modified front chassis version was tested but not used
3. The slotted on both sides engine cover was not used during free practices as the team tries to find ways to cut some drag
4. Revised diffuser
