Do the smart People in here also see a Restrictor in the Exhaust? If yes, what yould it be for? Is it the same as last Year with the RW Pylon Mounted through the Eshaust that they actually don't want that big of an exhaust Pipe diameter?
#aerogollumturbof1 wrote: YOU SHALL NOT......STALLLLL!!!
Could you not just run the engine on a Engine Centrifuge, a bit like what they do with astronauts on a Human Centrifuge?, would be rather cheap and simple to build I would a thoughtziggy wrote:You can beleive it is true. Although I can't say what percent is simulable, cornering G forces are not (yet) simulable. Ex. if you want to simulate 4G trough a corner for let's say 5 seconds, you need to accelerate the whole car with 4G for 5 seconds. You would need a dyno size of a football field if not bigger. Chassis tensions as well as curbs and vibrations can be simulated perfectly, but not full G forces, and the fluids simulations are a pain in the arse.Jef Patat wrote:I wonder to what extent this is true. For impulse forces I can agree, although I do not know to what level. But I have the impression the oil tank is not functioning correctly due to cornering forces, those should be simulatable at the dyno.ziggy wrote:Those circumstances (G forces) simply can't be simulated, not even on the best dyno. But they can be predicted. Although it's possible they are trying something new...
Well I guess you could, but I didn't see such thing yet. The big problem is that we don't know for sure what's going on.the EDGE wrote:Could you not just run the engine on a Engine Centrifuge, a bit like what they do with astronauts on a Human Centrifuge?, would be rather cheap and simple to build I would a thoughtziggy wrote:You can beleive it is true. Although I can't say what percent is simulable, cornering G forces are not (yet) simulable. Ex. if you want to simulate 4G trough a corner for let's say 5 seconds, you need to accelerate the whole car with 4G for 5 seconds. You would need a dyno size of a football field if not bigger. Chassis tensions as well as curbs and vibrations can be simulated perfectly, but not full G forces, and the fluids simulations are a pain in the arse.Jef Patat wrote:
ziggy wrote:Well I guess you could, but I didn't see such thing yet. The big problem is that we don't know for sure what's going on.the EDGE wrote:Could you not just run the engine on a Engine Centrifuge, a bit like what they do with astronauts on a Human Centrifuge?, would be rather cheap and simple to build I would a thoughtziggy wrote:
EDIT: Seems like Porsche ran into same problems. Engine Oil Sump Test Rig:
https://www.youtube.com/watch?v=fv53RbvgfGc
With such system you are limited to 1g acceleration. Probably F1 cars reach that while pulling into the pits.ziggy wrote:EDIT: Seems like Porsche ran into same problems. Engine Oil Sump Test Rig:
By any means, did he mention when the problem is going to be fixed? (E.g. this week or next week?)GoranF1 wrote:So Honda monday problem
-Design of oil tank(interior)
-Inside the tank baffels do not pick up oil at high G as they should, cousing pressure drop.
-At the circuit only a small fix is possible
-Honda saw problem during film day
-Hasegawa says problem not big, can be fixed
No....i think this week only a small/part fixBosF1 wrote:By any means, did he mention when the problem is going to be fixed? (E.g. this week or next week?)GoranF1 wrote:So Honda monday problem
Sorry Goran what is an Interior oil tank? Is this where oil collects after lubricating/coolingGoranF1 wrote:So Honda monday problem
