[KVRC] Khamsin Virtual Racecar Challenge 2016
LVDH
52
Re: Khamsin Virtual Racecar Challenge 2016
CAEdevice wrote:I'm ready for the first race: it doesn't matter if there will be no points, I'm going to use the most optimized car I could design.
Here's the new car, with the official colors . I hope it can intimidate the other teams , especially MantiumRAY ;)
CAEdevice wrote: PS: Is Mantium still hiding? :wink:
What is it with you? Dreaming about my car? Don't worry it will come and eat your's for lunch.
CAEdevice
52
I'm still impressed by the performance of your car during the last 2015 race and I tryed to animate the forum... consider it a compliment. Anyway, I am hungry too.
TalnoRacing
Here is my car for the first race.
CAEdevice
52
Well done Talno. Your engine intake is a concept I would like to test.
RicME85
52
Is that your model you out in GrabCAD Matteo?
CAEdevice
52
My MP003 (that you can find on grabcad) is very different in the nose area, and has a front diffuser istead of a double profile wing.
TalnoRacing
Thank you CAEdevice. Hopefully the car is competitive.
etsmc
etsmc
Can't do the cool renders you guys do but here is my car for the first race
https://onedrive.live.com/redir?resid=8 ... hoto%2cjpg
sorry can't get one drive to show just the image has to be a link..
CAEdevice
52
The intro class will be an interesting challenge. If I were you I would try to optimize the airfoils (starting from standard naca profiles).
etsmc
etsmc
actually just a question on submissions. last year i only submitted half a car is this still ok or do we have to submit a whole car??
cdsavage
cdsavage
19
etsmc wrote:actually just a question on submissions. last year i only submitted half a car is this still ok or do we have to submit a whole car??
It would make things slightly easier for us if you submit the whole car, but it's OK if you want to continue submitting a half-car.
etsmc
etsmc
ok so when submitting the whole car are we submitting with hx-shape-1 for left or right hand side?
cdsavage
cdsavage
19
I believe we will need to use the fallback method for K4.1 option 2, so the rulebook is out of date on this point. You should submit the 2 front faces of the heat exchangers as one part, and the 2 rear faces as another part (similar to how the cooling inlet and outlet surfaces are submitted). The name doesn't matter for now.
etsmc
etsmc
so we are submitting the following if we have modeled the cooling ducts
body
wing-front
wing-rear
cooling-intake
cooling-exhaust
engine-intake
engine-exhaust
hx-front
hx-rear
parts-offset.txt
cdsavage
cdsavage
19
etsmc wrote:so we are submitting the following if we have modeled the cooling ducts
body
wing-front
wing-rear
cooling-intake
cooling-exhaust
engine-intake
engine-exhaust
hx-front
hx-rear
parts-offset.txt
Yes, that's correct if you are using K4.1 option 2.
