Red Bull RB22
edu2703
edu2703
37
Re: Red Bull RB22
What it seems to me is that while Ferrari's mechanism rotates the wing clockwise, Red Bull's rotates the wing anticlockwise.
Stu
Re: Red Bull RB22
carisi2k wrote:
22 Apr 2026, 22:26
Stu wrote:
22 Apr 2026, 16:29
carisi2k wrote:
17 Apr 2026, 07:02
…and certainly the gearbox needs to be sorted out as well because those are the 2 areas that the drivers seem to be complaining about and struggling with. The huge amounts of understeer is horrible.
Is it gearbox that they are complaining about or the gear shifts?
Where do the gear shifts take place?
Gear shifting is impacted by how the MGU-K is operated; in the previous rule set MV often complained about the quality of downshifting & and was frequently coached by GP on settings to alleviate it.
SiLo
144
Re: Red Bull RB22
This version of the wing uses a central actuator, I guess if most of the drag loss is from the inversion of the wing this is actually the simpler solution surely? Ferrari are having issues having only a single actuator on one side and having to balance it on the other.
Felipe Baby!
carisi2k
Re: Red Bull RB22
Stu wrote:
23 Apr 2026, 19:48
carisi2k wrote:
22 Apr 2026, 22:26
Stu wrote:
22 Apr 2026, 16:29
KERS is then part of the gearbox and so the connection between engine, gearbox and KERS needs to be fixed. This update for Miami is almost a B revision with front wing, rear wing, sidepods, halo winglet and reduced weight.
carisi2k
Re: Red Bull RB22
Badger wrote:
23 Apr 2026, 10:23
Well they are clearly running two different wings, one with the McLaren-style side winglet and one looks like the old spec without it. We can gather these are from the same test because both have the new sidepod.
Also allegedly a new rear wing opening mechanism (not the same as Ferrari). I can't tell on that one.
Red Bull had a tyre test in Suzuka and then the camera day at Silverstone during this break.
Brahmal
Brahmal
73
Re: Red Bull RB22
edu2703 wrote:
23 Apr 2026, 19:11
I think you're correct, as that's the only way the central actuator arms could work without clipping. Downside could be a stronger parachute effect during actuation than Ferrari. The ends are mounted on small swing-arms to increase the size of the opening. It all looks a bit delicate no?
edu2703 wrote:
23 Apr 2026, 18:29
It appears to be a different and more complex mechanism than Ferrari's. Very curious to see how it works.
It certainly has more moving parts and seems like a bit of a contraption. Ferrari's actuators seem like the bigger engineering challenge though, and probably weigh more.
matteosc
matteosc
32
Re: Red Bull RB22
SiLo wrote:
23 Apr 2026, 23:58
I think Ferrari has one actuator per side. Removing the central actuator is in general beneficial for efficiency, both open and closed. It is all a matter of how small and reliable the side actuators are.
SilviuAgo
121
Re: Red Bull RB22
matteosc
matteosc
32
Re: Red Bull RB22
This seems a normal rear wing. Pretty confused about these pictures. Are we sure they are not from two separate events?
SilviuAgo
121
Re: Red Bull RB22
matteosc wrote:
24 Apr 2026, 09:53
About Red bull's flip flop wing (at Silverstone today) it's certainly a lot more different from Ferrari's “Macarena” wing.
There's central actuator present, plus the small elements which make the upper part of the wing stay opened higher(which reduces even more gap than normally, seems more than Ferrari's). But there's something else that actually got me wondering.
The upper part of the wing seems to me way too short for it to be able to fully close when it's turned off. That is just based on this photo. Compare its length to the amount of gap created when it opened. Ferrari's macarena wing for example was a lot longer than this one. Maybe this one is also closing differently?
nico5
25
Re: Red Bull RB22
edu2703 wrote:
23 Apr 2026, 19:11
And how would it not hit the actuator? Maybe it's made of ghost matter, who knows
SiLo
144
Re: Red Bull RB22
SilviuAgo wrote:
24 Apr 2026, 10:51
matteosc wrote:
24 Apr 2026, 09:53
https://pbs.twimg.com/media/HGnF1mMbAAA ... ame=medium
My guess is that it rotates counter clockwise (if you were looking from the side and the car was driving from right to left). So the actuator arm is actually pushing the upper flaps and it's rotating about that connection point.
The sides of the flaps are then connected by a longer arm, they likely extend farther down the side of the wing endplate than you have drawn.
Felipe Baby!
Lasssept
118
Re: Red Bull RB22
updt.
AI ?
link
Farnborough
Farnborough
152
Re: Red Bull RB22
You can juuust make out what looks like tge pivot point of "bell-crank" arrangement in the side mount of wing.
The front most item (lighter in shade) looks to be a ram and possibly pneumatic and pulling downward to deploy , upward to retract the wing in return to downforce position. Thst in addition to central primary control mechanical facility.
Doesn't look particularly complex, more a nice rational interpretation of that flip stance concept, designed with pre assessment of Ferrari etc.
Looks eminently functional, and particularly allowing the return phase to be completed in shortest time frame , also whilst promoting airflow reatachment in more beneficial .... less ambivalent .... fashion.
djos
130
Re: Red Bull RB22
This looks more elegant than the Ferrari solution. Ferrari’s actuators take up some space that reduces the rear wing width.
"In downforce we trust"
