2026 F1 Cars - General Thread
Re: 2026 F1 Cars - General Thread
Stu wrote:
16 Jan 2026, 08:53
If (a very big IF) these are true renditions of what to expect…
The VCARB has twin DRS actuators mounted on the wing main plane itself, splitting the flaps into three sections when activated; whereas the RB seems to have a single actuator under the nose operating the flaps as a whole.
I have my own thoughts on the merits (or otherwise) of each but discuss….
I don't think the middle section is mobile on any car (although it's not that clear in the regulations). Regardless, the current VCARB render wouldn't be able to move the middle section. There are two small supports connecting the middle section to the mainplane at the front, so we know that won't move.
The thing you see on the Red Bull is (imo) just a support strut. The actuator mechanism is not in the rendering.
Beware of T-Rex
collindsilva
collindsilva
Can we get a launch dates for all cars, previously we had separate thread...
The differences bewteen RB and VCARB says It's going to be 2010 again for front wings. It's definitley going to be a battlezone area for development and loopholes will be found and contested.
mzso
mzso
75
vorticism wrote:
15 Jan 2026, 19:42
The wheel regs are quite restrictive (don't tell me you're surprised).
C10.7.2
e. There must be no passage for air between the inboard and outboard cavities of the Wheel Rim.
Any closing panel may either be integrated into the rim or may be a separate piece. All separate
closing panels must respect clauses (d), (j), and (k) of this Article. Closing panels which are not
required to prevent airflow between the inner and outer cavities are not permitted.
k. Features intended to influence the heat transfer characteristics of the Wheel Rim are not
permitted. F1 Teams are required to submit designs to the FIA for approval.
So while we may see spokes they'll be bridged by panels. I assume this is what the Audi wheel consists of--alternating front panels and rear panels bridging the spokes.
So what are "clauses (d), (j), and (k)"?
Seanspeed
Seanspeed
Incredible difference in underside of the sidepods. Red Bull is very narrow waisted, while the Toro Rosso is quite the opposite. Again, assuming any of the sidepods are a real representation of the real cars.
Xyz22
Xyz22
125
Rake
Beware of T-Rex
Another "feature" of these 2026 cars seems to be a bargeboard strut. Its present on the Cadillac and it's visible in the VCARB renders.
Beware of T-Rex
Further discussion on active front wing details:
The optimum solution to me would be a central system actuated by an electric solenoid. When the coil is energized, the solenoid lifts the flaps up. Cut the power and the wing closes. There would be a spring that preloads the wing in the down position. This design is also fail safe so if the solenoid fails for some reason, the wing would return to the down position.
Beware of T-Rex
kptaylor
kptaylor
17 Jan 2026, 03:50
Can these have aerodynamic "covers" on them in the regs? That might explain why they all look plain now. Area to innovate?
mzso
mzso
75
17 Jan 2026, 02:33
Rake
With the car's show car level of detail, it's not really indicative of anything.
17 Jan 2026, 03:54
https://i.postimg.cc/prMB4bLr/image.png
Optimum, why? Judging by this tweet an ultra weight reduced double actuator one would be the best, since clearly that is which weighs more.
Maybe they should actuate it with cables. :)
mzso wrote:
17 Jan 2026, 13:15
17 Jan 2026, 02:33
Rake
17 Jan 2026, 03:54
I disagree with the author about weight.
Beware of T-Rex
vorticism
vorticism
449
vorticism wrote:
30 Dec 2025, 01:17
Items not yet given much attention online:
Diffuser winglet. It seems like that there will be a common, FIA supplied 3-element wing that will attach to the side of the diffuser. It’s unclear to me what it is called. It looks like previous years’ rear brake duct wings, just attached to the diffuser. It is barely visible on early FIA renderings and the Audi livery renderings. The “Diffuser Winglet” allowance seems to be a single element flap that the teams can add to the top of the common 3-element wing. It must only be single-section, but obviously in official renderings there’s a four element wing in that area, so this is how I’ve resolved the discrepancy for myself.
Visible in blue here.
Screenshot from: https://x.com/Qvist_Designs/status/2012 ... 38357?s=20
Vappy
Vappy
vorticism wrote:
17 Jan 2026, 17:37
vorticism wrote:
30 Dec 2025, 01:17
https://pbs.twimg.com/media/G-25F2BWsAA ... name=large
Is there a brake duct restriction this year that goes hand in hand with that allowed diffuser winglet?
vorticism
vorticism
449
Yes, no more brake duct wings.
