Ferrari SF23
S D
Re: Ferrari SF23
CMSMJ1 wrote:
03 Mar 2023, 18:13
Con Inglese? En Anglais? Auf Englisch?
Can we have that translated? Grazie!
F1 - Vasseur: "Leclerc's dancing rear wing is not usable"
Re: Ferrari SF23
gordonthegun wrote:
03 Mar 2023, 18:25
This wing was already in testing and broke, now, after a week, you put it again on the car and it swings like a bell and you can't use it for the race.
That wing was very important because it gave a little more downforce and now you can't test with that setup.
A top team can't do that.
Worth noting that Ferrari is the only top team (really? :? ) to still have two pylons for the rear wing.
So I guess you know how they can aggressively keep the weight down with composite parts, without actually having any issues and nail the saftey factor exactly, to the 3rd decimal? I'm sure you'll also be able to explain how is single pylon miles better than two pylons?
gordonthegun
254
Re: Ferrari SF23
Vanja #66 wrote:
03 Mar 2023, 18:54
gordonthegun wrote:
03 Mar 2023, 18:25
It's not me to have to know all these things. I don't work at Ferrari.
If single pylon is not better than double why to (try to) use it like Mercedes, Red Bull?
Anyway, no one else had such serious problems pursuing the correct weight saving.
That's enough because we're close to get off topic.
<mod edit: we are way past being off topic, but it is a good example for others to see where off topic begins. A few follow up posts below about cars painted mostly in blue were simply deleted, the educational value had been exhausted.>
Re: Ferrari SF23
CMSMJ1 wrote:
03 Mar 2023, 18:13
The headline is "Leclerc's dancing rear wing is not usable".
Inside the article Vasseur, "It's a piece we couldn't test last week, we tried this morning but, as we saw, it wasn't a succesful test, in the end we can't use this wing, even if we want too".
He also makes passing comments on Aston's form and the changes in the strategy team (downplays them).
LM10
LM10
127
Re: Ferrari SF23
gordonthegun wrote:
03 Mar 2023, 19:27
Vanja #66 wrote:
03 Mar 2023, 18:54
gordonthegun wrote:
03 Mar 2023, 18:25
I’m guessing single pylon is better deflectable on higher speeds. A single pylon rear wing with slightly more downforce might be a good choice obviously.
Ferrari will push to have a rear wing as light as possible and also as deflectable as possible/legal. It’s not easy to get it 100% right immediately, if you’re pushing the limits.
Sempre Forza Ferrari
Re: Ferrari SF23
Comparison of the two different configurations that were to be tested in fp1
Small RW + medium bw // larger RW + smaller bw
f300v10
f300v10
185
Re: Ferrari SF23
Sevach wrote:
03 Mar 2023, 19:59
Unlike the double pylon wing spec where the pylons are attached to the mainplane and can thus carry load and stabilize the wing, the single pylon does not appear to attach to the mainplane. It looks as if all the single pylon does is support the DRS mechanism. I guess it's possible the pylon does connect to the mainplane via the 'beak' of the swan neck, out of view from the camera but that seems unlikely. All the load would thus have to pass down the endplates and through the beam wings, which currently are not up to the task. I do find it surprising Ferrari didn't do some form of lateral load test on the wing during design that would have shown it lacked the required rigidity.
Andi76
Andi76
476
Re: Ferrari SF23
New Ferrari brake caliphers
hollus
Re: Ferrari SF23
A reminder to everyone but specially to the new people (welcome!).
We know the season has just started and the passions are high, but...
The car threads are specially strictly moderated in this forum. Stick to this car and to hardware in the car threads.
Team politics and other team things, please in the team threads.
Lap times, happy faces, sensations and will they be faster/slower than XYZ, either in the team threads or in the race threads.
If your post is in this thread and is not centering on this car, the physical car, it might have been or might be deleted or moved.
Let's keep the awesome car threads on this forum
a) focused on the hardware and
b) awesome.
Anyone counting how many posts land, daily, on the car threads, should see why this needed.
Thanks.
¡Puxa Sporting!
gordonthegun
254
Re: Ferrari SF23
Vanja #66 wrote:
03 Mar 2023, 20:52
gordonthegun wrote:
03 Mar 2023, 19:27
Since you don't know the details, trust me that this is a very complex topic for composite parts and tiny differences in design and manufacture can lead to this kind of behaviour. It's not a big issue, especially in 23-race season. I think two pylons are better for what it's worth, but Ferrari is trying something different and they will make it work quickly.
Remember RB18 DRS trouble in Spain and a few following races? If everything is going according to plan, you are not pushing hard enough. :)
Looking at this photo it seems also that the support wrapping the exhaust pipe is not so aerodynamically favorable.
It creates a block in the airflow:
ing.
69
Re: Ferrari SF23
ing. wrote:
03 Mar 2023, 22:55
ing. wrote:
03 Mar 2023, 22:52
gordonthegun wrote:
03 Mar 2023, 22:22
https://imgr1.auto-motor-und-sport.de/C ... 980991.jpg
Toroidal airfoil shape with flow-through annulus—likely used as jet-pump to draw air from rear facing cooling exit—is pretty much standard. Some “beefiness” is needed for adequate stiffness of the support at its base.
Re: Ferrari SF23
Re: Ferrari SF23
gordonthegun wrote:
03 Mar 2023, 22:22
Vanja #66 wrote:
03 Mar 2023, 20:52
gordonthegun wrote:
03 Mar 2023, 19:27
I just noticed now, Ferrari have these camera targets on the rear wing (which are separate from the FIA ones).
A crash test for reference:
This type of sighting is much better than the plain white sightings that the FIA requires (and makes me question the quality of the FIA's monitoring processes...)
#ReleasetheADUO
ing.
69
Re: Ferrari SF23
03 Mar 2023, 23:22
https://i.postimg.cc/qqfGQL5f/image.png
https://i.postimg.cc/yNg95R97/image.png
Good observation. I suppose better targets are a necessity when the rear wing moves like it’s been in a crash. 😂
gordonthegun
254
Re: Ferrari SF23
Here we can see the strange profile of the brakes cooling inlets and the Z-cut in the floor edge with a swelling at the end, like last year, but without the fissure after it.
Two pylons look much better than just one:
