2026 McLaren Mastercard F1 Team
Macklaren
Macklaren
Re: 2026 McLaren Mastercard F1 Team
Lando top of times now*
*times still irrelevant but...
SilviuAgo
190
As I mentioned before, Lando is getting laptime in a significantly different manner compared to Oscar earlier this morning. Incredible that these two deployment strategies that are so different from each other yield laptimes within a tenth of each other. 1:35:5 for Lando vs 1:35:6 for Oscar
Now Lando done 1:34:669, fastest time until now for the first day. =D>
FittingMechanics
FittingMechanics
Looks like Lando will try a soft run during the broadcast, I hope they follow him with the camera.
Darth-Piekus
-1
Skysports is now live. And it's crazy seeing for the first time after nearly 30 decades cars that are different from each other.
Slahinki
Slahinki
Car looks good on track. Also looks much less bouncy than in recent years.
Ground Effect
What's Lando's lap count?
bauc
Ground Effect wrote:
11 Feb 2026, 17:32
40 laps, last update from 20 min ago
Emag
Emag
137
bauc wrote:
11 Feb 2026, 17:39
11 Feb 2026, 17:32
Lando did 57/58 laps. Not a lot but they spend the first 2 hours doing static speed runs for aero. And then most of the later runs were just setup experimentations.
Lando got a "long" run stint in the end though.
Developer of F1InsightsHub
Darth-Piekus
-1
So 58 laps from Lando and close to 60 from Piastri that is close to 120 laps. Productive first day I think.
LionsHeart
LionsHeart
Leon Kennedy wrote:
11 Feb 2026, 16:37
LionsHeart wrote:
11 Feb 2026, 07:10
Leon Kennedy wrote:
11 Feb 2026, 01:04
I did a quick calculation to understand how much the chicane on the Barcelona circuit was worth in terms of time. Consider that in the 2022 tests we went very close to the limit (perhaps due to also to the use of a softer tyre than that given in the Grand Prix) with a time of 1.19.1, pole time that year 1.18.7. Pole time the following year 1.12.2 (without chicanes). The performance leap from 2022 to 2023 was approximately 1.1 second per lap (Miami 1.8 because it had been resurfaced), between 23 and 24 0.8 seconds. But let's keep 1.1 as an approximate reference threshold. In essence in 2022 the pole would have been 1.13.3 which subtracted from 1.18.7, gives a difference of 5.4 seconds (this is the value of the chicane). The fastest time of the 2026 tests was Hamilton's in 16.3, so only about 3 seconds off the virtual pole time of 2022. And in my opinion they weren't even close to the limit, neither as a car configuration nor as an engine configuration.
My personal opinion: 3 seconds difference considering they didn't push in the tests, is really little and can be made up, I wouldn't be surprised if we were in line with the 22 times.
Welcome newcomer to the forum!
Fine. So be it. That might not be far from the truth. At the moment, with so little data, it's really hard to calculate all the possibilities. Admittedly, I'm not too concerned about the pace of a single fast lap. I'm more interested in how quickly the new cars can cover the race distance. And that directly depends on race pace. Naturally, we're not taking the safety car and rain into account.
Hi! Thank you so much!
I agree with you that there will be less difference on the flying lap than on the race distance. There are factors that make you believe they can be faster: such as the more powerful engine, the active aerodynamics, the lack of venturi (more stability and less tyre degradation) and the possibility of rake setup. At the same time, other factors say the opposite: battery management during the race, the tyres which are narrower and degrade more quickly and also the cars which are narrower. Furthermore, the lack of a venturi also gives you less downforce at the "ideal" load (we know that in fact this doesn't translate 100% on the track). We'll see, it will be interesting!
Exactly. I forgot about the tires. They've gotten narrower, which means they'll overheat a little faster and wear out more quickly. I checked the life-time report. Lando did two slow laps between his fast laps. It's possible the tires are overheating, or two laps are needed to fully charge the battery. This is interesting, as qualifying will be more competitive. Any mistake by the driver will have a very serious impact. Every fast lap in qualifying will be more important. Considering the new cars slide more and the rear end is more likely to spin out, it's going to be very interesting.
LionsHeart
LionsHeart
We discussed rake earlier. After watching the last hour of testing, I got the impression that Williams' rear end is higher than the rest.
Regarding the McLaren, the car looks fast in sectors 2 and 3. Max, in his last fast attempt, was 0.5 seconds faster in sector 1, but then lost ground in sectors 2 and 3, ending up 0.129 seconds behind. The loss in sectors 2 and 3 is 0.33 seconds. According to the infographic, Lando showed his time on C2 tires, while Max on C3 tires.
SilviuAgo
190
Norris sets the fastest time and Leclerc improves on the final runs. It's clear how power delivery makes a huge difference, even more so than the deltas in the corners at the moment.
Verstappen starts off strong in the lap, Lando makes a mistake in T4, Leclerc makes a great LiCo right at 4. Then McLaren comes out in S2 with great acceleration up to 9. Ferrari is like RedBull in the middle sector. Then Max pushes hard at 12, but Lando gains a 14-point lead on him and Charles on the final straight and takes P1. Who knows if this direct dependence on power strategies will continue or if they will gradually become more aligned and we'll be talking about cornering speed again. Let's see
Emag
Emag
137
LionsHeart wrote:
11 Feb 2026, 18:25
https://i.ibb.co/TMvkMBmg/576892-C7-EEB ... AF6-D2.jpg
The tire difference is correct. The sectors are quite drastically different for multiple reasons. In S1 Max is way faster partly because he deploys more at the start of the lap and partly because he is way faster at T4 (by 2 tenths).
The thing is Max has done a lot of long runs inbetween today. Whereas Lando has just been experimenting a lot. Quite a bit of time was spent in the garages.
Perhaps a more "normal" session can give us some better insights.
LionsHeart
LionsHeart
Emag wrote:
11 Feb 2026, 18:29
LionsHeart wrote:
11 Feb 2026, 18:25
I agree. The programs varied greatly throughout the day. But these two fast times are comparable. It's interesting to see how energy can be distributed more effectively throughout the circuit.
LionsHeart
LionsHeart
SilviuAgo wrote:
11 Feb 2026, 18:29
https://pbs.twimg.com/media/HA4p60BawAA ... =4096x4096
Mate, thank you so much for this graphics!
