venkyhere
43
f1isgood wrote:
24 Oct 2025, 18:40
24 Oct 2025, 18:24
Floor upgrades earlier than I had hoped, but sounds like an optimization/modification job.
Also sounds like the engine cover upgrade is a modification job of the new spec, wider engine cover introduced at Singapore, but isn't just specific to Mexico like many teams' engine cover will be. It'll be useable at any other hot races (Qatar, Abu dhabi for instance)
https://i.ibb.co/RGy83L2P/20251024-172625.jpg
That Monza floor unlocked so much performance it's insane. Reminds me of the floor they bolted on in 2022 on the final day of testing in Bahrain. They couldn't contain their smiles then. Hopefully they can smile now.
Technical team deserves so much 👏.
f1isgood wrote:
24 Oct 2025, 18:46
That would be ideal. Let's hope Yuki for once can be between 3 to 4 tenths off Max. That will be very good progress. He might even be retained if he proves a capable second driver for the last 5 races.
Don't count your chickens before they hatch... FP2 will tell us, possibly it will take until end of FP3 to form a verdict.
Reading the published datasheet of the changes, looks like A LOT for the (N-4)th race of the last year of a regulation. This is the engineering team in full-on attack mode (probably planned 4-5 months ago). However, I won't get excited just yet, will wait until end of FP3. The team has a not-very-old history of 'upgrades' ending up as 'updates' , hopefully not this time.
venkyhere wrote:
24 Oct 2025, 19:06
The cooling stuff tends to be mexico specific. It is therefore planned well in advance and common for most teams. I've heard that the floor stuff is just CFD going straight to track as it's not a revolution, it's just refinement. The RB21 windtunnel model has been collecting dust for a while.
Beware of T-Rex
f1isgood
f1isgood
venkyhere wrote:
24 Oct 2025, 19:06
f1isgood wrote:
24 Oct 2025, 18:40
24 Oct 2025, 18:24
f1isgood wrote:
24 Oct 2025, 18:46
Sure but it's a refinement on the Monza floor. I'd be surprised if they put this to production without confirmation at Monza.
Also Monza floor worked better than expected so I hope this upgrade works better than expected as well.
Badger
Badger
46
24 Oct 2025, 19:12
venkyhere wrote:
24 Oct 2025, 19:06
The cooling louvres are Mexico specific, but my read is that the rest of the cooling update is not.
This may be the engine cover (minus louvres) that will be used in Brazil, Qatar, and AD.
Henk_v
Henk_v
89
Any pictures yet?
Henk_v wrote:
24 Oct 2025, 19:30
Any pictures yet?
Beware of T-Rex
Fabrega is saying that the cooling inlet (sidepod) has also been updated. That is not circuit specific.
The sidepod update is not directly stated in the document, but then there is an errant reference to it
Beware of T-Rex
venkyhere
43
24 Oct 2025, 19:12
venkyhere wrote:
24 Oct 2025, 19:06
f1isgood wrote:
24 Oct 2025, 19:17
Badger wrote:
24 Oct 2025, 19:22
Yes I did understand from the document that the changes are circuit specific cooling needs and the floor revision. My surprise is that they are going ultra-aggressive with the shape of the floor tunnel ('lowered uoper floor surface') - unsure whether it is fore or aft of the venturi neck, apart from a 'sidepod revision' that is mentioned as well. I rather expected some edge wing changes only, to clean-up/modify the edge vortices. This is like a 'main' change. Hence my comment.
24 Oct 2025, 19:33
Henk_v wrote:
24 Oct 2025, 19:30
Any pictures yet?
I found the document very confusing to read.
Sergej
Cooling parts were expected and they're track specific (at least the louvre engine cover), let's hope the floor parts do their job.
btw what is the "sidepod revision" ?
Badger
Badger
46
I sincerely hope RB ditch these ancient air to air intercoolers for next year. It’s a big packaging penalty and clearly the system doesn’t perform to the same standard as what McLaren uses. Weight seems to be the only benefit, but it can’t be much.
Sergej wrote:
24 Oct 2025, 19:48
I don't know if it is appropriate to call it significant, but it is not a "minor" revision either: viewtopic.php?p=1306487#p1306487
Beware of T-Rex
Sergej
24 Oct 2025, 20:11
Sergej wrote:
24 Oct 2025, 19:48
Thanks.
Hope Lindblad doesn't crash Max's car [-o<
Henk_v
Henk_v
89
That sidepod sure looks like it was slapped together in a rush. No time was spent on aesthetics there...
Valeo
Valeo
Yuki seems to feel well so far
