Aston Martin wants hyper-car to be faster than F1 cars
roon
roon
412
Re: Aston Martin wants hyper-car to be faster than F1 cars
Also, the sharp trailing edge was replaced by a tall engine vent.
Some F1 similarities: the front wing appears to have a "neutral" section and two elements outboard. This should generate an equivalent Y250 type vortex.
I wonder if they make it all the way to the back of the car; the diffuser seems nicely shaped to accept them.
Nickel
Nickel
I don't see a neutral section? What does the underside look like? Why on earth would you implement a complicated vortex like that? It only exists in f1 because of the rules: neutral section transition creates this vortex anyways so you use it to your advantage to control the tire wake or seal the floor or whatever. In the absence of rules, all these problems have simple solutions that don't require losing downforce-generating areas.
humble sabot
27
I think the centre section has to be flatter anyway, making it more like a splitter. There's not much use to directing the air upwards there since there's a flat roof over the whole front, and it's even lower in the middle. Pretty sure Newey put in those big fender holes, and angled the flow guide behind the front wheel outwards because the front section needed more expansion.
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
roon
roon
412
Nickel wrote:
18 Jun 2017, 04:54
I posted two images of exactly these things. Note the parenthesis I used around the word neutral, and words such a "similarities" & "equivalent." The wing has a single element in the center, flanked by two-element sections at either end. It would seem inevitable that spillover will be created from this design, resulting in something like a Y250 in terms of location and direction of rotation.
Nickel wrote:
18 Jun 2017, 04:54
A wingtip vortex is all it is—most subsonic wings exhibit them. Why do you consider it a complicated phenomenon?
variante
135
roon wrote:
17 Jun 2017, 23:54
The big vortices under the diffuser rotate in the opposite way compared to the Y250s
roon
roon
412
True, and they'd fill the outer radiuses. Wasn't commenting on them. The inner radiuses being filled with these pseudo y250s. Their counterrotation being beneficial in this scenario.
SR71
1130 HP
1000 HP coming from 6.5L V12 - 153.85 HP/L
2,270 pounds
http://jalopnik.com/aston-martin-valkyr ... 1796352960
153bhp/litre? Sorry, but that is sounding a bit far fetched - no naturally-aspirated road car engine has ever got close to that.
lawnmower
lawnmower
-1
Just_a_fan wrote:
23 Jun 2017, 21:04
Ferrari 458 - 134 hp/L
This may be possible on a hyper car
Andres125sx
It´s looking good, at any angle
specially this one =P~ =P~
I know it´s old and the diffuser will be different, but that does not relevant in this angle, I watched the pic from a link to an older article and simply had to click, this is what I call a mindblowing design
humble sabot
27
lawnmower wrote:
23 Jun 2017, 23:32
Just_a_fan wrote:
23 Jun 2017, 21:04
Ducati Panigale is 164hp/L or thereabouts in most iterations. Also a 10.5k rpm NA engine. It's within reason especially considering they aren't trying to get honda civic levels of life out of it.
static balance
dynamic balance
static imbalance
dynamic imbalance
Ana
Is it the same one that was reviewed by in the The Grand Tour on Amazon. I remember them doing one Aston Martin.
humble sabot
27
Reviewed? They haven't built a running one yet. You might be thinking of the Vulcan?
static balance
dynamic balance
static imbalance
dynamic imbalance
Ana
humble sabot wrote:
01 Jul 2017, 06:00
Yes, you are right that was the Vulcan they reviewed on The Grand Tour. Except for the speed they did not have much to praise about it. The Vulcan and this Hyper car resemble quite lot IMO.
humble sabot
27
Anyone else curious why they dropped the raised center section of the rear wing despite bringing the exhaust so much further back? Would seem to make sense to have kept at least for heat reasons.
static balance
dynamic balance
static imbalance
dynamic imbalance
