McLaren MCL34
rccrdc
rccrdc
Re: McLaren MCL34
SmallSoldier wrote:
28 Mar 2019, 18:15
PhillipM wrote:At last the front bargeboard pieces and new boomerangs =D>
I thought we were going to see those at Melbourne, wonder what held them back? :cry:
Are they still running the same rear wing or the new one?
Still looking for pictures of it... The front wings seemed to be the same as in Australia though:
https://uploads.tapatalk-cdn.com/201903 ... c41d39.jpg
Via AMuS
What about the bottom left front wing?
SmallSoldier
SmallSoldier
488
Re: McLaren MCL34
rccrdc wrote:
SmallSoldier wrote:
28 Mar 2019, 18:15
Via AMuS
The flap adjusters aren’t installed and the elements are just hanging.
Marc.W
26
Re: McLaren MCL34
SmallSoldier wrote:
28 Mar 2019, 19:31
rccrdc wrote:
SmallSoldier wrote:
28 Mar 2019, 18:15
Via AMuS
Looks like the bottom left wing has 5 elements on it like the rest
SmallSoldier
SmallSoldier
488
Re: McLaren MCL34
Damn you PhillipM!!! Now you have me updating my tweeter feed every few minutes to see if I can find a picture of the rear wing! Hahaha :)
Re: McLaren MCL34
Here you go god... you were looking for this...
the crossbar of the goal has arch in it to that wasn't there before...
Re: McLaren MCL34
If you're wondering what this is ...This is an above view with the sidepod to the right . The "Richard Mille" is on top of the wing structure on top of the sidepod.
The crossbar thingy is on the left and we can see that it is not only arched but narrower as well now.
RZS10
359
Re: McLaren MCL34
diffuser wrote:
28 Mar 2019, 23:06
https://pbs.twimg.com/media/D2wN8NbW0AEgyws.jpg
they had to since they removed some/changed the shape of the area below
trinidefender
trinidefender
318
Re: McLaren MCL34
diffuser wrote:
28 Mar 2019, 23:06
If you look carefully what you will see is that the outer vertical element is probably the same height however the crossbar element has more than just an arch, it is actually sloped upwards. The inner vertical plate of the barge board connecting the other side of the crossbar goes higher than it did before. You can see this by comparing its height to the vertical turning vane elements right behind it.
Trying to get a larger mass of airflow moving outward to control front tyre wake.
Edit: you can also tell that it's talker when comparing the before and after picture if you look at where it is in relation to the connection for the front suspension wishbone is right in front of it.
GoranF1
GoranF1
149
Re: McLaren MCL34
Ivan Roldan is working on bargeboard's this year at Mclaren. So this update is his work.It's important that this is recognized.
Lucky
Lucky
157
Re: McLaren MCL34
Re: McLaren MCL34
GoranF1 wrote:
29 Mar 2019, 09:17
Why is it important?
f1rules
f1rules
635
Re: McLaren MCL34
Re: McLaren MCL34
Looks different to me...
M840TR
M840TR
315
Re: McLaren MCL34
trinidefender wrote:
28 Mar 2019, 23:25
diffuser wrote:
28 Mar 2019, 23:06
They're gradually exploring the limits of maximum height regulations pertaining to bargeboards. It can still go higher than it is now.
NiyolHuayra
NiyolHuayra
Re: McLaren MCL34
