25 Oct 2025, 20:57
Max knows he can win from P1 P2 or P3 and lando is expert at bottling a pole at T1..
This is optimistic...
Beware of T-Rex
Max should tow Yuki into Q3, then Yuki can return the favor.
Beware of T-Rex
f1isgood
f1isgood
25 Oct 2025, 20:57
When was the last time Lando bottled pole this year? I genuinely can't seem to recollect.
f1isgood
f1isgood
25 Oct 2025, 20:59
The only way.
Valeo
Valeo
I can't believe McLaren won't be in trouble If they have to run in traffic tomorrow. Is their cooling system so much better than everything the other 9 teams could come up with, even the works team?
Vettel165
25 Oct 2025, 20:58
Vettel165 wrote:
25 Oct 2025, 20:47
Maybe they sacrificed some one-lap speed for better race pace. Starting one or two places behind Lando is not a bad thing, the slipstream is massive into T1. What I am saying, its better to start P2, P3 and then having better race pace, then to just get pole and having bad race pace. Its a compromise.
Listen to this interview by Max from yesterday. He said exacly the same thing.
Today is the reverse of yesterday. Today they are competitive on the medium tire short runs, but nowhere on the softs. Yesterday was the opposite.
Indeed, very strange. Also Max set 3 time laps on his soft run at the end, improving on his last lap. And at the same time staying out much longer than everyone else.
f1isgood
f1isgood
Valeo wrote:
25 Oct 2025, 21:01
I mean, the engines were fixed these regulations. So works team effectively had no advantage with regard to packaging. McLaren have done the best job at everything. Their car is still the only one that works in all conditions all tracks.
This looks very weird.
Beware of T-Rex
Vettel165
25 Oct 2025, 21:03
https://i.postimg.cc/dt8j1rzV/image.png
Now please look for how many laps did Norris and Verstappen have fuel. I dont have the data.
Vettel165 wrote:
25 Oct 2025, 21:07
25 Oct 2025, 21:03
The timing says Lando did 8 laps and Max did 11 but then we don't know if teams fuel exactly for these stints or they over fuel. We can just say Norris had at least 8 laps of fuel.
Beware of T-Rex
f1isgood
f1isgood
25 Oct 2025, 21:03
In what sense? In that Max only loses a tenth on the long straight?
f1isgood wrote:
25 Oct 2025, 21:09
25 Oct 2025, 21:03
Yes the top speeds are too low into T1, into T4, and into T12.
Beware of T-Rex
Vettel165
25 Oct 2025, 21:08
Vettel165 wrote:
25 Oct 2025, 21:07
25 Oct 2025, 21:03
Thank you. One member from f1 autosport forum managed to observe Max while being onboard with him.
"Just re-watched the run on board on F1TV, so he goes out, does an out lap, fast lap, 2 slow laps, quick lap, and after is told to do 2 more slow laps (as the session winds down to get to the practice start). He says no grip but on both runs the car is pretty nailed and he loses a ton of time in S1, even to Tsunoda". "Lower engine mode/ higher fuel"
Emag
Emag
137
25 Oct 2025, 21:10
f1isgood wrote:
25 Oct 2025, 21:09
25 Oct 2025, 21:03
Seems like for the delta there's only 86% confidence.
I can tell there's a significant offset on the telemetry data. Just checked to confirm and GPTempo has the same problem although more pronounced. I have worked with these stuff for so long, I can just tell by eye when something is off.
In any case, even if you can't tell visually that there's some data quality problem from the telemetry, then just from what makes most sense, I doubt Lando can gain that much on the braking of T1. So basically, either Lando's or Max's trace for those laps has some sampling issues (i.e corrupt data). But it only seems to be a problem for the first sector, the rest seems reasonable enough.
For the first bit, I think about 1 tenth more should be lost during the straight itself and less during the next 3 corners.
Developer of F1InsightsHub
Emag wrote:
25 Oct 2025, 21:15
25 Oct 2025, 21:10
f1isgood wrote:
25 Oct 2025, 21:09
For that I don't even consider the delta. I just look at the speed traces. Unless somehow that data is also wrong, it's strange how Verstappen is now 4km/h down on the front straight and missing a bit of top end on the others. It is probably cooling and engine modes, but strange nonetheless.
Beware of T-Rex
