myurr wrote:mx_tifosi wrote:Shiny new tires and clean bling wheelz. (
I tried saying this in a serious voice but couldn't hold back from laughing, wait, I mean I loled.)
From Scarbs' Twitter page.
You can clearly see on that picture the split in the rear wing - a few cm above the more visible gap between the two wing elements there is a faint horizontal line that meets with two vertical lines in the centre of the wing.
I'm guessing this is the channel through which they're venting air.
Yip, looks like they're flap blowing.
Lets see how it works out for them.
I've given it some thought how they can open the slot to allow pressurised air to vent but first how to pressurize it.
I have often wondered if anyone would try achieving fuel efficiency through cutting fuel to cylinders under low load throttle conditions and recirculating this air via an EGR system. If the EGR could be bled off to pressurise a chamber you have one problem solved.
Now how to open the vent without a mechanical valve.
the wings have a tolerance for flex they have to adhere to but at speed flex is inevitable. So if you design an element to flex slightly more than the one above it you could open the gap, release the pressure and blow closely coupled air over the rear of the wing element dropping the pressure further...
[scratches chin]
