2017 Mclaren F1 Team - Honda
Joseki
Joseki
Re: 2017 Mclaren F1 Team - Honda
Wazari wrote:
07 Nov 2017, 08:40
In my experience, you can't always believe what the press writes, team principles rarely speak the facts and when they do, spin them to make the team and/or themselves look better than maybe they actually are.
This is surely true for Red Bull, McLaren, Ferrari, Renault and Honda.
Even if we limit it to F1 that Statement is true for everyone that says something to the Media.
McHonda wrote:
08 Nov 2017, 02:46
The difference between Renault and Honda performance wise is worth giving up 7 years of Works Support for which is the only 100% cast iron fact out there and tells us absolutely everything we need to know.
I have to believe this. I can't phantom that if McLaren would have believed there was a high probability in Honda catching Renault for the beginning of the 2018 season that they would have gone through all the pain of switching.
By "catching" I mean , HP, reliability, fuel efficiency and amount of electrical power generated by the MGU-H, therefore, how much time the MGU-K can be used over a single lap.
I think In total HP they're close...The reliability it's hard to tell. Honda is doing so much testing on the track that I'm sure that's showing up in their reliability. It's the last 2 items, which might be interpreted as one and the same, where they're is a HUGE gap. The old flashing red light.
bigblue
An elementary question, but what does the flashing rear red light mean ? MGU-K harvesting, or MGU-H harvesting, or either ? (I guess MGU-K). Can MGU-K harvesting be of varying intensity, I mean it's not just an 'on or off' scenario (I guess, yes, can vary). Lastly, if anyone has a link to a good explanation of both sorts of mechanism, could you post it here, or PM me ? I think I know roughly what they are, but only roughly ! Thanks.
the EDGE
the EDGE
68
bigblue wrote:
08 Nov 2017, 19:10
I always thought it meant they had run out of energy to deploy
mrluke
mrluke
GPR-A wrote:
07 Nov 2017, 05:28
mrluke wrote:
06 Nov 2017, 22:06
GPR-A wrote:
06 Nov 2017, 17:15
Floor is one part that can be used for optimum downforce generation through Venturi effect. That is the reason why a lot of purists, want higher levels of ground effect and want a lot of these wings be simplified, for better racing. Lowering the wake with reduced wing elements, helps car follow closer.
Is there any evidence that supports the view that lower wake helps car follow closer of that less wing downforce helps cars follow closer?
Im going to suggest that at Mexico it was much harder for cars to follow closely. Further due to the lower air density even having one of the longest straights in F1 and DRS it was very difficult for one car to get past another slower car.
I think that running very high drag would actually make overtaking easier as the slipstream would be a much higher benefit.
Link -> Lewis Hamilton says boosting downforce to lower lap times in 2017 is the 'worst idea'
Lewis Hamilton to SkySport, 27/11/15 wrote:"I know they're talking about giving us more aerodynamics, which for me is like the worst idea. It just shows that, for me, they don't really know what they're trying to solve.
"From a driver's point of view, we want more grip from the tyres; we want less wake coming from the car in front so therefore we can get closer.
This will help you gain some more understanding of the "Wake" issue.
https://www.f1technical.net/forum/viewtopic.php?t=22412
Highlighted the key word.
FWIW I am in agreement with Bhall from your link (as I was the last time this was discussed)
Quoting from Bhall:
There was a big change in Aero rules between 2008 and 2009 which greatly simplified the cars, removed a lot of the sensitive winglets and there was absolutely no change in the amount of overtaking in the season.
From this:
to this:
Made absolutely no difference at all.
But sorry I am dragging this somewhat off topic.
adrianjordan
You could at least have used pics of Mclaren cars!! Lol
Favourite team: McLaren
GPR-A duplicate2
64
mrluke wrote:
08 Nov 2017, 22:05
GPR-A wrote:
07 Nov 2017, 05:28
mrluke wrote:
06 Nov 2017, 22:06
Quoting from Bhall:
http://i.imgur.com/AX7HeMc.jpg
From this:
https://cdn-1.motorsport.com/static/img ... -ferra.jpg
to this:
https://www.f1fanatic.co.uk/wp-content/ ... _20091.jpg
Did you try and understand what could have been the reason, why the overtaking trend was such, through the years? Let me try and help.
The numbers of cars participated over the years.
This is the % AND NOT the actual number of overtakes. I will explain why this is accurate.
And if you see there, THERE WAS AN INCREASE in overtakes in 2009. Something more interesting here. I have taken qualifying performance from Malaysian GP in 2008 and in 2009 as a reference. As the track generally offered good overtaking opportunities, this is a good reference.
2008
2009
Observe the performance difference between the top 10 cars from 2008 to 2009. The field got bunched up! Which means, lower overtaking possibilities. But again, here is another interesting statistic. The DNFs in 2008 and in 2009.
More DNFs in 2008, compared to 2009. Had the 2008 cars managed to have the 2009 reliability, there was theoretically more overtakes possible. Contrary to that, if the field in 2009 was as spread as it was in 2008, theoretically, more overtakes were possible. Different factors balancing the act, but in different ways! But, if you look at the first picture, it shows that the % of overtakes increased 2009!
2008
2009
And compare the reliability situation to 1991. (Click to enlarge). 34 cars and disastrous reliability. If those cars would have had the 2011 type of reliability, the overtaking numbers would have gone out of the roof.
This is the qualifying performance difference between top 10 cars in 1991 USA GP. With such a large performance gap, there must have been great number of overtakes, but the balancing factor was bad reliability that never allowed cars to really be on track in races. If the cars of 1991 would have managed a reliability like that of 2016-17 Mercedes cars, Ayrton could have lapped the last 15 (of the 34) cars, atleast 15 times in the race. That is around 225 overtakes in one for race for one driver alone! Ayrton had lapped the 8th placed Gabriele Tarquini, 4 times.
So, the truth of the matter lies in the details of the situations. Factors like number of cars participated, performance difference between the cars and the reliability issues have all contributed to a skewed picture of overtaking over the years. The overtaking graph considers none of those factors as I don't think the intent was that either. It just shows number of overtakes, without going into any further details.
Simply looking at a trend graph says nothing. When a credible driver talks about his difficulties in overtaking, it has to be granted a level of authenticity.
Mods, please move this discussion to an appropriate thread. Thanks.
Alonso Fan
It seems the ban on refueling did more for overtaking than the new aero regs of 2009 did.
Lets ban refuelling. Oh wait...
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
ollandos
ollandos
the key for more overtakes is the tires...sort life tires and more pit stops...3 types with 15-18 laps life with 2 of them must use ...for 3 and more pit stops per race ...and giving all drive style
Nonserviam85
Nonserviam85
Again this is the McLaren Team thread why are we discussing number of Overtakes?
Alonso Fan
ollandos wrote:
09 Nov 2017, 12:51
In 2010 we still had Bridgestones which could probably last the entire season
SHR Modding
Youtube
Twitter
Discord
Alonso Fan
Nonserviam85 wrote:
09 Nov 2017, 13:13
Actually it started from a floor related aero discussion about wake and that lead to its effects on overtaking etc. Completely off topic but hope the mods will move it because it is quite interesting
SHR Modding
Youtube
Twitter
Discord
Joseki
Joseki
Alonso probably testing with Toyota LMP1 before the end of the year... Isn't Alonso a Honda driver until the season ends? I would like to hear Wazari's opinion on this, in Japan it must be important I think.
Nonserviam85
Nonserviam85
Alonso Fan wrote:
09 Nov 2017, 13:16
Nonserviam85 wrote:
09 Nov 2017, 13:13
Again it would be more suited to the McL-32 car thread...
