2017 Mclaren F1 Team - Honda
NathanOlder
Re: 2017 Mclaren F1 Team - Honda
Good to see Lando getting a run out in an F2 car in Abu Dhabi. Will probably be towards the back as its a new car and new track up against the season regulars. But will certainly help him be a little better prepared for next year.
GoLandoGo
Lewis v2.0
King George has arrived.
GhostF1 wrote:
15 Nov 2017, 00:38
diffuser wrote:
14 Nov 2017, 04:24
Singabule wrote:
14 Nov 2017, 03:45
Removing shark fin is a political move, as their car is still empty from sponsor. Imagine FI unable to find more space in their car, and MCL would say 'hey, our car still empty, why not promote ur brand in our car instead, only for 10% higher price'
Agreed.
Definite sponsor drive there, but I'd say there is a little bit of tactical gain there as well... They've likely developed the MCL33 without the big sail and waited until the final vote was required (which by the way, needed a unanimous decision to continue for 2018) and then voted no, that screws the other teams who have been developing it.
There has been a couple teams who are not happy about the late decision and that is likely because of sponsor issues but also aero development will now have to restart in this area. It has been known that McLaren do not like the sail, now that could be for sponsor reasons, but there has also been comment that it affects the airflow onto the rear wing at all other angles except straight on... so.
Either way, we'd be silly to assume a company in the middle of a competition, trying to claw back to the top end of the field, have not thought about this possible advantage in saying no this late.
I really hope they stick to their guns !!!
I HATE the shark fin
marvin78
marvin78
And I like it. And now?
marvin78 wrote:
15 Nov 2017, 12:19
Now you have one Race and the Post Season Test to slowly say goodbye to it.
marvin78 wrote:
15 Nov 2017, 12:19
"Each to his own" as the saying goes :D :D
I hope I win this one [-o< :wink: [-o< :wink:
marvin78
marvin78
Thunder wrote:
15 Nov 2017, 12:24
marvin78 wrote:
15 Nov 2017, 12:19
I wanted to say that you don't always get, what you wish for and in F1 case it would be really bad for the sport if everything the so called "fan" wishes is the way it goes. We have had that far too much by now. And that is not directly related to shark fins.
marvin78 wrote:
15 Nov 2017, 12:51
Thunder wrote:
15 Nov 2017, 12:24
marvin78 wrote:
15 Nov 2017, 12:19
Agreed. I have been watching/following F1 for over 35 years now. You can imagine what I've seen and experienced over the years !!! :D :o :D
HPD
198
:!: :!: :!: :idea:
After finishing the technical briefing after the Brazilian GP qualifying, Fernando Alonso said after removing the intercom for the conversation between the staff.
"Is not this a downforce too much? It can not come out at tomorrow's race, is not it tough enough?"
McLaren tried set-up that lightly reduced downforce on Friday. At that time, the fastest speed of Alonso was 325.8 km / h, and Stelle Bandoon extended to 327.3 km / h.
In light of the highest speed of qualifying, it is the speed which is the 8th overall. In other words, even a powerless Honda Power Unit proved that the fastest speed would be available depending on the setup.
However, the MCL 32 could not ensure satisfactory behavior at that downforce amount. As a result, on Saturday the corner was steady fast as usual, but the corner was steady and fast, but the fastest was down about 10 km / h, with Alonso at 316.2 km / h and Bando at 315.5 km / h respectively .
Matt Morris: "Because the balance between straight speed and in-field is a very important and difficult circuit here, we explored that balance.
Of course, I want the fastest speed when considering the competitiveness in the final. However, if you cut downforce, you can not run sector 2 fast.
As a result, it turned out that setting downforce for Saturday was the best compromise for us. "
However, it explains that it is not a characteristic of the car body, but because it is setting a wing to draw speed.
Matt Morris: "That's because we are setting downforce.
It might seem like they are saying strange things, but if you have more power you can cut downforce and set up a direction to earn straight.
However, we can not earn straight even if we break downforce.
On the other hand, it will also be lost in the corner.
So, because there is no power, there is no choice but to go downforth and earn it in the corner. "
However, some engineer at Honda refutes to it.
McLaren is aiming not "the machine that can deliver the fastest time," but the driver is "a machine that is easy to run".
"I think it is not the fastest compromise.
Even Mercedes AMG and Ferraris were spinning and off tracking this time, were not you? Still McLaren is busy, I do not off course.
When it shaved downforce on Friday, Stelle spun at turn 2, "It is not possible to run after all" situation. Even the top team attacks the downforce as much as it is cutting downforce, McLaren has firmly put downforce, making a car that makes it easy for the driver to run.
McLaren is traditionally a team of such engineering policy.
Absolutely to complain about the driver, because it is their policy to deal with it.
As a result, although it is hard to run, it is not a fast machine, and the driver will be finished in a machine that is easy to run.
"This setting is faster, so afterwards you are going to run hard and run" It is a team that can not tell the driver. "
That was why Alonso told the opening story at the briefing after qualifying.
I did not bother to talk to the engineer by removing the intercom because it was not asked by the factory and no recording was done either. Alonso himself recognized that it was "inconvenient truth".
In fact, discussions have been discussed with McLaren and Honda about the direction of this setup.
Rather than discussion, it is close to claims from Honda side.
Honda Yusuke Hasegawa F1 general manager says,
"Of course we discussed, many times.
I've talked about 'Let's make it a lighter downforce' many times, but still quite ......
As the team gives priority to the faster lap time, the downforce also affects the stability of the car, so it will not spin absolutely even in places where Hamilton will spin it (bitter smile) .
Not to criticize the team but to say that it is such a directional setting, since it is a way of thinking in the way ahead, so if you capture the pole position then there is no problem ... (bitter smile) "
https://sportiva.shueisha.co.jp/clm/mot ... ndex_4.php
kptaylor
kptaylor
So what does that really mean or reveal? Honda wanted less downforce so their speed trap times wouldn't look bad and McLaren wanted the downforce that gave the best overall lap time? These Google translations strip away much of the nuance of the replies given...
Hammerfist
Hammerfist
kptaylor wrote:
15 Nov 2017, 17:34
To me it is a case of a chassis lacking overall downforce coupled to a power unit lacking overall power. I have suspected this a long time, because whenever they have to compromise like this, for so little reward, it's likely because both of the parts of the sum aren't great.
Redbull on the other hand, seems to be able to run so little wing and still be fast in the corners, and that has been the case since the v8 era. I still think Mclaren is facing a rude awakening next year.
bigblue
Hard to know with that auto-translation. Maybe Honda felt that the straightline speed would be more beneficial in the race, rather than just to 'appear better'. Matt Morris's quote seems to suggest that taking downforce off wouldn't result in enough straightline speed gain, given the power they have, to make it worthwhile. But it's all mangled in the translation, so hard to say.
HPD
198
I know, the translation is very complicated, there is not much to do. I am sorry
dren
228
To me, it sounded like Mclaren went for a set-up towards car stability for the drivers instead of outright speed like the Honda engineers were saying. They also said it appeared that other teams went the outright speed direction since other drivers like Hamilton were spinning the car.
Honda!
Alonso Fan
bigblue wrote:
15 Nov 2017, 18:24
This is what I picked up too
SHR Modding
Youtube
Twitter
Discord
Sound Developer for Reiza Studios
Sound Modder for Assetto Corsa
j.yank
j.yank
Well, basically this is what I suspected - McLaren are not capable to increase the downforce without increasing the drag. This is the problem of all customer teams - they have the power of Mercedes or Ferrari engines but they are wasting this power with huge drag. That's why they are forced, to choose between high drag-downforce settings or thin wings with high straight speed. Actually, the first option is not an option for them - if they run high drag-downforce they will loose in the corners against better balanced chassis of the works teams, but also they will loose the only real asset that they have - the power advantage given by the Mercedes or Ferrari PU on the straights. On other hand, Red Bull have very efficient chassis which means no-drag-high-downforce. This allows them to be superior in the corners sections without sacrificing too much of the limited available power on straights. Because McLaren obviously have high drag-downforce chassis they cannot run the same settings like Red Bull. Saying this I don't wish to hurt the feelings of McLaren fans here. I am really sorry that the McLaren-Honda project failed. This is not good for both sides. Three years of efforts and hopes have gone because of corporate games and mistakes.
