Paa
It doesn't matter how good the car is because winning everything is not enough.
There are 116 points to gain so it is enough for either McLaren driver to score just 80 points in the remaining 4+2 events, and that's it. That is Max can maximize everything. If he loses again 10 points then 70 is enough for either Lando/Oscar.
I don't think people realize how much harder to achieve something like this against 2 opponents. As Verstappen is now relies on some bad luck from the others, but then the bad luck needs to hit two drivers, while avoids Max completely.
It basically needs a miracle at this point, or a race ending crash for the McLaren drivers. I'm sure they also know this and will be extra careful.
To be honest it is much more likely at this point that either McLaren driver will have a crash with Max, while the other takes the title.
Piastri is out of the title race IMO. He's slumped and there's no sign of a revival. If max drives like he usually does and the car is competitive with McLaren at the remaining races (yes, a big if) then he can push Norris close. It's possible that with ramping pressure Norris won't handle that well. We shouldn't make a definitive statement either way about whether he's completely overcome his tendancies. 4 wins in a row with a competitive car is not out of the ordinary for Max (see 2021, 2022) even when things are tight.
pantherxxx
pantherxxx
But last year Mclaren was particularly weak in both Qatar and Vegas. If the temperature drops like in Vegas, they will be fighting with the Ferraris, while Verstappen can win. So there's still room to makeup for that 36 points of deficit.
Mclaren was not weak in Qatar. Are you thinking of a different weekend? The curious thing is Mercedes thinks they will be quick in Qatar.
Imo assuming the races will be predictable is a mistake. There could be rain in brazil. Mercedes fighting in Qatar and Las Vegas. There are chances to still win the title as long as Max can win races and you don't assume Lando Norris finishes 2nd.
Beware of T-Rex
Henk_v
Henk_v
89
The point Paa makes still stands. If Max drives impeccable, he is not guaranteed a win.
Piastri out of contention makes it worse in my opinion. If Norris and Piastri would devide 2nd and 3rd evenly over the next 4 races and one of them becomes second in both sprints, max can drive all the 1st places he wants and still loses.
The point being he needs 2 drivers to f#ck it up at some point AND have a perfect score.
Ferrari had pace in Mexico. Better hope they did not develop too much pace and start contesting max for 1st places. Hopium mandates they need to have exacly enough pace to squeeze in between Max and Mclaren.
Badger
Badger
46
28 Oct 2025, 16:49
We’re returning to more traditional circuits where Piastri could fare better. It’s difficult to be miles off in Brazil. Before Mexico I gave Norris a 50% chance of taking it, now that’s closer to 70% IMO. For Max the only chance is that Piastri continues to slump and that Norris has a DNF.
venkyhere
43
I think (don't hate me for this) that in this thread there is too much hopium. Max needs 9 points per race on BOTH McLarens. Which can't happen unless both of them DNF one race each, even if Max wins every single race and sprint from now on. That final VSC denied him 3 points (which is 1/12th of the deficit, around 8%) and that itself can make Max lose by 2-3 points, even if the previous sentence, even if highly improbably, happens.
So I think we should stop 'clinging on' to something that has something like 1/1000 probability.
venkyhere wrote:
28 Oct 2025, 17:03
I think you're thinking about it in the wrong way. The championship is only won based on the points total after Abu Dhabi. So much can happen between now and then. It's not about hope. It's a fact that he's only 36 points away and so much can happen as we know from the history of this sport.
Beware of T-Rex
venkyhere
43
28 Oct 2025, 17:04
venkyhere wrote:
28 Oct 2025, 17:03
'so much can happen' relies too much on two DNFs , or Leclerc/Russel consistently coming P2. Even if we assume Max will pull off 4+2 P1s.
venkyhere wrote:
28 Oct 2025, 17:07
28 Oct 2025, 17:04
venkyhere wrote:
28 Oct 2025, 17:03
I'm not relying on anything or making any predictions. I'm just pointing out that assuming the remaining 4 races will be straightforward is just as big of an assumption as assuming chaos. What we've seen is that Max is very good at surviving chaos. For the Mclaren drivers, I wouldn't say the same. It could be wet in Brazil. There could be Mercedes in Qatar and Las Vegas. I think Verstappen has better chances navigating this than the Mclaren drivers.
M5X is not a recipe without ingredients. They are there. Mclaren will not have it easy.
Beware of T-Rex
Paa
Of course, it is not over until it's over and anything can happen.
We just need to be realistic on how unlikely it is.
rbirules
rbirules
There's a couple, semi-realistic scenarios where Max can still win the WDC, all of them include him winning all remaining events (he used his last non-win in Mexico).
1. McLaren drivers split the podiums - 4 GPs and 2 sprints remaining. Two GP 2nds (36 points), two GP 3rds (30 points), one sprint 2nd (7 points), one sprint 3rd (6 points) equals 79 points each.
Max - 437
Lando - 436
Oscar - 435
(One McLaren driver getting 2nd in both sprints doesn't change anything, Max wins on countback or the order for 2nd and 3rd reverses.)
Would McLaren invert the order in Abu Dhabi to get the driver in 3rd into 2nd and win the WDC? Possibly, unless the driver in 2nd has a chance to challenge Max and win it themselves. This also assumes the McLarens are running 2-3 in Abu Dhabi and have this option available.
2. McLaren has a lone bogey race - Lando, or Oscar can win the WDC (by 6 or 5 points, respectively), by finishing 2nd to Max at every event. So for Max to beat them, or tie in Lando's case (and win the WDC on countback), he needs them to drop 6 points. We saw above this is accomplished by finishing 3rd instead of 2nd in two GPs, but this can also be accomplished in a single event if they finish in 4th (or lower) in a GP, as that is worth 6 points less than 2nd place (12 vs. 18). Vegas is the obvious track for this to happen as Mercedes was very strong here last year (Max was 5th while the McLarens were 6th and 7th), and the Ferraris were as well. Again, Max has to win (or we're getting into scenarios of the McLarens finishing 7th, and 8th; or 8th, and 9th, depending on if Max has to beat Lando or Oscar), but a Max, George, Kimi (or Charles, or Lewis, or Yuki?!) podium brings this into play.
Max would head to Qatar 15 points down on Lando if this happened.
Max would tie Lando, and win the WDC on countback, if he wins out, while Lando gets 2nd in every event and only 4th in Vegas. One non-podium is all it takes if Max is perfect.
3. A combination of #1 and #2 - whichever driver ends up being the main threat loses a single 2nd place to their teammate, and then loses to Max and one other driver at another GP (Max and George in Vegas to use the most obvious choice).
Yes, Max has to be perfect, and that alone makes this unlikely, but a McLaren driver has to be very close to perfect as well if that happens, and those perfect outcomes have to start immediately, and perhaps before McLaren know who to back.
Bonus - the McLaren drivers are separated by one point, a single skirmish between them leading to a double DNF or significantly reduced finishing position kicks the door wide open for Max.
Henk_v
Henk_v
89
It is disturbing we are talking about a driver against a team. Yuki should watch Perez's '21 Abu Dhabi race.
rbirules wrote:
28 Oct 2025, 17:41
Then Max should slow down and bait the 2nd place Mclaren driver across the line to make sure they can't swap the cars.
Beware of T-Rex
Leclerc and Russell will challenge the Mclaren drivers at some point.
Beware of T-Rex
