McLaren MCL34
Re: McLaren MCL34
Re: McLaren MCL34
Nice angle of new bargeboard...
SmallSoldier
SmallSoldier
486
Re: McLaren MCL34
the EDGE wrote:
SmallSoldier wrote:
30 Mar 2019, 04:04
trinidefender wrote: Don't think so. People just thought so because the release renders showed very little rake.
Yes, there was an analysis by AMuS if I’m not wrong where they analyzed the rake of the cars during week one of testing and even then, the Mclaren was in the middle in terms of rake compared to the rest of the cars... Although lower rake and larger wheelbase compared to last year.
AMuS just another sports magazine... just cos they say it, doesn’t mean it’s true
The way they did the analysis looked pretty sound.
SmallSoldier
SmallSoldier
486
Re: McLaren MCL34
mwillems wrote:
mclaren111 wrote:
30 Mar 2019, 09:36
https://cdn-3.motorsport.com/images/mgl ... oard-1.jpg
No opening on top off sidepod for cooling... Must be confident with cooling solutions...
I've seen in a couple of analyses that this also energises the air around the sidepod whilst allowing for a tighter back end, However, in the red bull thread they say it is just cooling.
So is it just cooling? Ferrari have had this since Barcelona and to increase cooling in Aus they opened up the back end a bit.
The opening behind the cockpit is for cooling not for aero/performance... It’s a solution that has been used by the teams for quiet some time (it has been moved slightly backwards due to the Halo), but it’s there for heat management.
DiogoBrand
74
Re: McLaren MCL34
mwillems wrote:
30 Mar 2019, 10:21
mclaren111 wrote:
30 Mar 2019, 09:36
The only reason I can think of that would make you want energized airflow is if you run the risk of stalling, and if the sidepods ran the risk of stalling so that you'd need that opening to energize the flow, you'd need it all the time, not just for some races. Also, airflow over the sidepods create lift, so you want as little as possible of it.
I don't know what the big fuss is about, teams have been placing cooling gills around that area for more than a decade, and last year the halo created the possibility to place that opening there. But this time, out of nowhere, there are several theories about it energizing flow, or even blowing the rear wing.
Go figure...
mwillems
Re: McLaren MCL34
DiogoBrand wrote:
30 Mar 2019, 16:22
mwillems wrote:
30 Mar 2019, 10:21
mclaren111 wrote:
30 Mar 2019, 09:36
Go figure...
I think the main benefit quoted was having a tighter rear end and more airflow to the diffuser. But I don't know if that becomes a net gain or not given the drawbacks.
-Bandit
Re: McLaren MCL34
I just compensates for having the cooling there if you need it, basically, it's not a net gain, it just negates the downside with the placement of the cooling holes.
DiogoBrand
74
Re: McLaren MCL34
mwillems wrote:
30 Mar 2019, 16:45
That is most likely a benefit of these openings, but it's an indirect benefit from not having to increase the size of the main cooling outlets, not a direct advantage of the opening on the halo mounting itself.
SmallSoldier
SmallSoldier
486
Re: McLaren MCL34
Re: McLaren MCL34
A "different" looking car under the lights... :o :o
Re: McLaren MCL34
Racefans:
Another team which has modified its bargeboards, McLaren’s changes are more pronounced and easily visible. They affect the boomerang section and the 6 vanes mounted within.
charliesmithhd
67
Re: McLaren MCL34
mclaren111 wrote:
31 Mar 2019, 12:59
Racefans:
https://www.racefans.net/wp-content/upl ... claren.jpg
Which session did they do back to back test?
Re: McLaren MCL34
Early FP1
M840TR
M840TR
315
Re: McLaren MCL34
Here is Carlos' Q3 P7 lap. Car very stable and no issues besides a minor snap of oversteer in the last corner.
https://cdn-b-east.streamable.com/video ... 1554039884
Macklaren
Macklaren
Re: McLaren MCL34
M840TR wrote:
31 Mar 2019, 14:08
That sounds glorious!
