2026 Aerodynamic & Chassis Regulations
FrukostScones
Re: 2026 Aerodynamic & Chassis Regulations
FittingMechanics wrote:
11 Dec 2025, 18:42
FW17 wrote:
11 Dec 2025, 18:08
Doubt that will be final on the front.
They would need something that can be quickly installed while replacing a damaged front wing. Hydraulic and pneumatic lines will be a pain. Eclectic or electro hydraulic more likely.
If I remember correctly, The Race said that they can be either hydraulic or electric. The teams can choose.
yes, I think it can be anything, the rules don't prescribe something as far as I could figure out : ). edit: rear has to be hydraulic? so front too? does someone understand?
"I ain't with the FIFA, I'm in Tokyo." LH
djos
130
Waz wrote:
11 Dec 2025, 17:02
FW17 wrote:
10 Dec 2025, 08:48
Is the 2026 F1 wing actuators electric?
I've seen they're pneumatic.
The teams have a choice, it’s not mandated how they do it.
"In downforce we trust"
Martin Keene
Martin Keene
11 Dec 2025, 18:42
FW17 wrote:
11 Dec 2025, 18:08
I am expecting them to be hydraulic with a dry break connector incorporated into the nose mountings.
Hi F1Technical community,
The new F1 2026 regulations are sparking some serious debate within the paddock and among technical analysts. We've done a comprehensive analysis on NewsF1.it, delving into the announced changes for aerodynamics, power units, and their potential impact on racing.
Our article explores key aspects such as:
The "Agile Car" concept: significant reduction in downforce (30%) and drag (55%), coupled with smaller dimensions and lighter cars (-30kg).
The revolutionary active aerodynamics ("Z-mode" vs. "X-mode") and how they're intended to work.
The dramatic shift in power unit philosophy: a much larger electric component (350kW from 120kW), a smaller ICE (400kW from ~550kW), and the much-discussed removal of the MGU-H.
The contentious point: is the fear of mandatory downshifts on long straights (due to energy depletion) a real concern, or will active aero sufficiently mitigate this?
We've tried to cover the technical implications and the potential effects on driver skill and race spectacle. This is a massive shift for Formula 1, aiming for sustainability but bringing unprecedented technical challenges.
I'd love to hear your thoughts on these changes. Do you believe the "agile car" will deliver closer racing, or just more unstable and difficult-to-drive machines? Is the MGU-H removal a necessary evil for new manufacturers, or will its absence create more problems than it solves with energy management?
You can read the full analysis here:
https://www.newsf1.it/f1-2026-new-regul ... s-engines/
Looking forward to a lively technical discussion!
Best regards,
The NewsF1.it Team
TeamKoolGreen
TeamKoolGreen
More last minute changes.
With reduced downforce on the straights , the tires will have a hard time retaining heat. This will be a problem on medium speed corners and in cold or damp conditions. So race control can decide if a certain zone of the track will require full downforce.
So presumably in these conditions , it will be F2 on the straights if all the downforce is mandated by race control.
FrukostScones
Can of worms?
_cerber1
302
TeamKoolGreen
TeamKoolGreen
Can of worms indeed. We now have low downforce mode, high downforce mode and partial downforce mode.
How are they going to police all of these modes ? Especially without spec parts. Teams will be interpreting all of these modes too and looking for loopholes.
I guess one of the positives will be variance between cars. Just imagine one team finds a clever design or loophole on the active aero. But everything else with the car is not up to par. It will be gaining on everyone in one part of the track and losing it on the rest.
mzso
mzso
75
TeamKoolGreen wrote:
16 Dec 2025, 18:18
So how this will be implemented? Sensors at the beginning and the end of every straight/fast section?
By the way I don't see the fuss. Pirelli makes tries that work perfectly in every given condition. That's why we don't have warming blankets anymore.
mzso
mzso
75
Uh-oh. Hamilton melodrama incoming. If he couldn't handle the teeny bit forward cockpit in 2022, I can only imagine how he will deal with his seat being even closer to the front wheels.
karana
karana
16 Dec 2025, 23:12
It's really simple. If full activation is allowed, both front- and rear wing can be switched to straight line mode in the activation zones for full activation. If for reasons of safety or in low grip conditions full activation is not allowed by the race director, partial activation is allowed, which means only the front wing can be switched to straight line mode and only in the activation zones for partial activation. It's the same for anyone and can be easily monitored through the FIA Standard ECU, which is a spec part.
mzso
mzso
75
16 Dec 2025, 18:18
Yeesh. With all the eclectic changes that the FIA can make for active-aero activations, and considering non or wrongful activations this might the the season of the most spectacular crashes. With drivers just flying away when the active aero is not in the state they expect it to be. The DRS related crashes of Ericsson, Grosjean and Bortoleto come to mind. And they all happened when breaking and not going into a high speed section with a less then expected downforce.
Muramasa666
Given that the new regulations limit the wheelbase to 3400 mm and the width to 1900 mm, which past cars would be comparable in terms of dimensions? Just curious
FW17
189
Muramasa666 wrote:
17 Dec 2025, 17:52
Mercedes W05: 3427 mm
Ferrari F14T: 3410 mm
cplchanb
cplchanb
https://www.motorsport.com/f1/news/f1-a ... /10785237/
some terminology updates.
its pleasing to see that the cars are going back in time and picking up where they left off at the end of 2008.
