...And if BTE is 40% and heat value is 43,2 then this engine needs a fuel rate of 155kg/h to reach 1000ps ?
And max RPM would be 16500 if we take this formula into concideration: Q (kg/h) = 0.009 N(rpm)+ 5.5 ?
Juzh
161
PlatinumZealot wrote:James Allen reporting that the 2014 engines have 900hp all things combined.
http://www.jamesallenonf1.com/2015/01/e ... a-on-2015/
If that's true then V10s were pushing 1200 minimum. 2014 acceleration is no match for V10s by a long, long shot. I honestly don't believe this 900 hp stuff.
dren
228
That's over 40% efficiency for the ICE alone with good fuel.
Honda!
Juzh
161
Example: raikkonen was doing 324 over the start/finish line in monza 2005 with half a race worth of fuel, so pretty much similar weight to 2014 quali car. Compared to DRSed bottas at 317 in 2014.
S1 speed trap 342 kmh in 2005, 330 in 2014 without DRS. There's just no contest.
900bhp is BS imo.
kooleracer
kooleracer
James Allen says:
January 9, 2015 at 10:47 am
A good source, it’s a rough figure for the best performing engine in the field of course
Andy Cowell: ''#F1 Current internal cumbustion engines would easily reach 1600HP even with 100kg/h fuel flow limit if they were 100% thermal effective.''
56.25 TE = 900bhp that is obviously crazy.
50 TE = 800bhp would be a really great achievement. But maybe the hybrid combined with the ICE is more efficient then we can imagine.
Irvine:"If you don't have a good car you can't win it, unless you are Michael or Senna. Lots of guys won in Adrian Newey's cars, big deal. Adrian is the real genius out there, there is Senna, there is Michael and there is Newey.They were the three great talents."
dren
228
James Allen's reply on his site as to where the 900hp figure came from:
James Allen says:
Edit - looks like you beat me too it kool... :)
Honda!
dren
228
Juzh wrote:Example: raikkonen was doing 324 over the start/finish line in monza 2005 with half a race worth of fuel, so pretty much similar weight to 2014 quali car. Compared to DRSed bottas at 317 in 2014.
900bhp is BS imo.
Aren't they limited to one set of gear ratios for the year? I would guess due to that limit, Monza speeds would be lower than they could otherwise be.
Honda!
Juzh
161
Gear ratios don't play a major role in acceleration anymore. Case in point mercedes: long/short gears --> no difference. Been discused loads of time already.
pgfpro
76
According to German Auto Motor und Sport some of the technical items on the discussion table were, “the position of the wastegate valve in the exhaust tract, the diameter of the tail pipe and the number of turbochargers and the question of a second turbo
I would love to see a second turbo added to the equation. From my own personal experience I built on my car a twin turbo "high pressure/low pressure turbo compound system, with a lean-burn stratified charge.
http://ecomodder.com/forum/showthread.p ... 28776.html
IMO I think F1 could increase their efficiency numbers even more, if they ran a high pressure/low pressure turbo compound system. This would improve engine delta p numbers!!! They also would use less battery power to spool the turbo because of the use of the small turbine/compressor high pressure turbo helps a ton by reducing turbo lag. I'm seeing full boost 55psi at 4000rpm on my 2.0L compound system. :wtf:
building the perfect beast
Blanchimont wrote:From the comments:
grifle: "James, I am interested in where you heard the 900hp figure. We are having a heated discussion on f1technical over the horsepower output of the ICE and ERS systems."
James Allen: "A good source, it’s a rough figure for the best performing engine in the field of course"
haha. thanks for finding my question! I was looking for it. Seems Jame's replied.
Blackout wrote:900hp ---> 740hp witout KERS ---> if fuel heat content is 43,2MJ/kg then efficiency = 45% !?
you forget the MGU-H!
so it is ICE + MGUH = 760hp.
That is a crazy engine you have there. Sounds more powerful than a current F1 engine. Instead of two turbos they can use variable vane turbos as well. This is legal in WEC but not legal in F1 at the moment.
mrluke
mrluke
DC was really impressed with the power of the 2014 cars when he drove one, I can't see him saying that if the V10s were ~500bhp/t lower.
Moose
Moose
52
It's kinda crazy. The number of people who keep coming out saying that the engines are around the 900 Hp range, or around the 40% range for the ICE... These are the numbers that keep getting repeated again and again by all kinds of F1 engineers. Yet so many of the forum's members keep trying to assert "no, they're only 550/700hp because I don't believe them".
I don't believe them is not a reason it's wrong.
rscsr
51
A story doesn't necessarily have to be true to be believed, it just needs to be told.
But on the other hand, I believe RET and they published about the same power as 2013.
