http://www.youtube.com/watch?v=hZWMz17w ... =f1%202006
That's because top plane crosses greater distance than the lower planne. I wonder if it flexes at all or perhaps whole wing is connected to gearbox via transversal axle and secured by spring that stretches under air pressure load and pulls back wing in neutral position on lower speeds.Tom wrote:...but from the onboard it loooks more like just the top plane moving.
3.17.3 Bodywork may deflect by no more than one degree horizontally when a load of 1000N is applied
simultaneously to its extremities in a rearward direction 780mm above the reference plane and 20mm
forward of the rear wheel centre line.
and
3.17.5 The uppermost aerofoil element lying behind the rear wheel centre line may deflect no more than 5mm
horizontally when a 500N load is applied horizontally. The load will be applied 800mm above the reference
plane at three separate points which lie on the car centre line and 250mm either side of it. The loads will be
applied in an rearward direction using a suitable 25mm wide adapter which must be supplied by the
relevant team.
