Changes To Qualifying
ENGINE TUNER
ENGINE TUNER
25
Re: Changes To Qualifying
dans79 wrote:
17 Sep 2019, 19:05
ENGINE TUNER wrote:
17 Sep 2019, 18:51
What does F1 not being a spec series have to do with drivers knowing how to both pass and defend cleanly?
Because In a formula series the cars are not designed for close racing. They are designed to yield the best lap time.
A reverse sprint race in Monaco for example would be ridiculous. A Williams would start P1 and finish p1 as long as the driver didn't screw up.
The regs are being reformulated to focus on closer racing for 2021, you know this, why ignore it?
Yes Monaco would be rediculous, IT ALREADY IS.
But assuming Williams won the sprint race, they would still qualify last and so their combined qually score would NOT put them on pole position for the gp anyway in my proposed system.
ncx
ncx
19
ENGINE TUNER wrote:
17 Sep 2019, 17:44
Turn Fp3 into a reverse wdc position grid sprint race.
Keep qually as it is, combine the results of both to form the grid for the gp.
In that case, it would be better to do Q first and the sprint race later, otherwise not that many cars would take part in Q. Anyway, with the current regulations I don't think a sprint race would work well, as overtaking is too difficult and risky; a driver's racecraft is not enough of a differential in a short race, imo.
ENGINE TUNER
ENGINE TUNER
25
ncx wrote:
17 Sep 2019, 19:19
ENGINE TUNER wrote:
17 Sep 2019, 17:44
I agree, qually before sprint race, could be a better solution.
I've seen top drivers make up several positions on the first lap, racecraft matters. 45mins +1 would fit well in tv time and give plenty time for racecraft to make a difference.
The car/aero regs and tires are supposedly being reformulated to give us closer racing, we shall see.
dans79
267
ENGINE TUNER wrote:
17 Sep 2019, 19:11
It will still be a design series, and nothing the FIA/FOM can do will prevent the teams and engineers from exploiting every possible avenue to decrease lap times, and this always has an adverse effect on close racing.
Maybe it will be ok for a season or 2, but the teams will find a way. They always have and they always will.
202 105 104 9 9 7
ENGINE TUNER
ENGINE TUNER
25
dans79 wrote:
17 Sep 2019, 19:27
ENGINE TUNER wrote:
17 Sep 2019, 19:11
The teams will have to choose between designing a car that works better in free air or in traffic, nothing new, as they now compromise peak downforce for more consistent downforce often.
strad
117
The problem with qualifying (and maybe with the races) is that there are too many cars on too short of a track at one time.
Perhaps we should consider having FP1 and maybe FP2 broken into two sessions with only half the field on track at one time.
Or something similar to the days when they had to pre-qualify within a certain preset time.
Sir Stirling Moss
Nickel
Nickel
It seems to me that much of the resistance to the concept is based on people enjoying watching qualifying rather than its suitability for deciding the starting order of the race.
To say that a reverse order sprint race is arbitrary is true, however it's no more or less arbitrary than basing it on a time trial session as it is now. It is different, yes, but that doesn't mean there's anything wrong with that.
As for the enjoyment derived from watching quali as it exists now, they could easily have a time attack session for points during the weekend instead of using it to decide the grid. Ditch the point for fastest lap in race and do a short time attack session.
I for one think a reverse order sprint race to decide the grid is a fantastic idea and monaco can suck a lemon. That place should only be a time attack, the race is generally awful.
dans79
267
Nickel wrote:
17 Sep 2019, 22:40
what?
A reverse order sprint race is the governing body intentionally penalizing those that are faster. That's worlds apart from what we have now.
202 105 104 9 9 7
Nickel
Nickel
I agree that it's vastly different. my point is that the current method is also arbitrary.
Big Tea
99
So what if a car does not set a time? either an off or mechanical etc?
The obvious answer would be start from the back, but as its reversed..?
Zynerji
112
Qualifying is perfect as it is, it just contains imperfect competitors, as we've witnessed.
1000 things need fixed in F1 before qualifying is "next"on the list.
I'm guessing the competitors want this because they can't beat Mercedes technically. They're hoping that Mercedes won't be able to follow close enough to overtake and so give them a qualifying advantage.
strad
117
Sir Stirling Moss
notsofast
notsofast
Please let's not change qualifying. To achieve close racing, all we need is a small adjustment to the rules. It is my understanding that we already have a rule that prohibits impeding another driver. Simply define "dirty air" as impeding another driver. Problem solved!
gngr
gngr
More action on track, more people from different teams on the podium, closer championship fights and more excitement for the people on the venue... I see mostly positives. Maybe I'm just crazy for not wanting to see the same guys on the podium race after race and year after year. This gives the smaller teams somewhat of a fighting chance.
