Vodaphone McLaren Mercedes MP4-24
roost89
roost89
Re: Vodaphone McLaren Mercedes 2009 MP4-24 Launch
Thank you shir0 and bassimon most helpful :)
"It could be done manually. It would take quite a while, but it could be done. There is however a much more efficient and accurate way of getting the data. Men with lasers." Wing Commander Andy Green
timbo
timbo
113
Seems like McLaren run their new car with 2008 wing. What's the point? They hide something secret, or still have to figure out how to make up DF loss at the rear?
djos
116
I would suggest it is just some sort of Aero Benchmarking test as they know how much Downforce the old one generates and they are prolly comparing against the new for setup purposes?
"In downforce we trust"
Shaddock
I didn't realise how high the nose of the McLaren was until I saw this photo.
i70q7m7ghw
i70q7m7ghw
49
Very smooth lines :) Also, have they changed the exhausts as well?
gcdugas
What is up with the front rim plates in the last two photos? I think there is a rule that says that nothing is to extend wider than the widest cross section of the front tire. Is that some sort of testing gauge/device?
Innovation over refinement is the prefered path to performance. -- Get rid of the dopey regs in F1
the stig
The rim plates are just for testing puposes measuring airflow and tyre temps...but I have no clue why they are running the 08 wing...
VODAFONE McLAREN MERCEDES
vyselegend
Shaddock wrote:I didn't realise how high the nose of the McLaren was until I saw this photo.
Exact. Quite high nose. Another thing on that pic, is the disturbing impression that front tyres are of greater diametre than rear ones. Given the perspective of the pic, it should be the opposite... :?
Another weird optical illusion I guess.
joseff
the stig wrote:...but I have no clue why they are running the 08 wing...
Because it looks better!
i70q7m7ghw
i70q7m7ghw
49
gcdugas wrote:What is up with the front rim plates in the last two photos? I think there is a rule that says that nothing is to extend wider than the widest cross section of the front tire. Is that some sort of testing gauge/device?
I thought there was a maximum width for the car so to put body work beyond the width of the wheels you had to compromise track width...
modbaraban
modbaraban
Maybe it was worth it? They used similar things last year for testing purposes but those had clearly non-aerodynamic shape and were much thicker.
ISLAMATRON
vyselegend wrote:Exact. Quite high nose. Another thing on that pic, is the disturbing impression that front tyres are of greater diametre than rear ones. Given the perspective of the pic, it should be the opposite... :?
If the car is under hard acceleration the rear end will squat and weight will shift to the rear loading down the rear tires... thus making the front tires look larger than the rear... opposite under braking.
ESPImperium
ESPImperium
64
The thing i fing funny is the fact its a 2009 car with a 2008 rear wing at the moment.
Just looks weird, but i approve.
Shaddock
ESPImperium wrote:The thing i fing funny is the fact its a 2009 car with a 2008 rear wing at the moment.
Apparently they switched front and rear wings from 08 specs to 09 specs and combinations of the two during testing.
myurr
myurr
Diesel wrote: Very smooth lines :) Also, have they changed the exhausts as well?
Looks like it - possibly because of the lower rear wing they need to divert the exhaust gases to a lower height. They appear much more steeply angled than those in the launch shots.
