basti313
basti313
32
f1isgood wrote:
21 Nov 2025, 11:14
How is it looking so far?
Great! Finally Yuki finished ahead of Max in a timmed session today in FP1. =D>
Don`t russel the hamster!
search
basti313 wrote:
21 Nov 2025, 13:59
f1isgood wrote:
21 Nov 2025, 11:14
which means they definitely should experiment with the floors in FP3 ;)
venkyhere
43
With so many different PU modes, fuel loads and run plans in FP2, and the interrupted session, couldn't form any meaningful idea of the pecking order across teams, the only sensible comparison to do, in my mind, is Max's fastest run on S from FP1 v/s fastest run on M from FP2 :
- PU mode seemed same
- Achilles heel slow section 7-8-9 improved by ~0.2
- gain from entry/exit of T12 was worth ~0.15, and it's purely driver confidence (braking point was same, later off-throttle)
- gain from the mega straight from T12 to T14 was 7 hundredths or so.
- overall lap time gain is ~1s. Even if we are very pessimistic, we can attribute atmost 3/4 s to track evolution and the rest 1/4 s to car's performance improvement. It's noteworthy, considering that the slower time was on the softer compound and the faster time was done when the track temp dropped even lower (by 2 degrees).
- from the 'what the driver said' comments I was able to read, it seemed that both Redbull drivers were happy with the balance of the car (something significant, because quite often what Max says in his media snippet is worth more than all the amateur data analysis we do)
f1isgood
f1isgood
basti313 wrote:
21 Nov 2025, 13:59
f1isgood wrote:
21 Nov 2025, 11:14
Very cool. Where is Bill?
Emag
Emag
137
venkyhere wrote:
21 Nov 2025, 15:27
Yep, Max didn't complain about anything in particular, just the usual caveats with the limited running making the job a bit difficult. Only mentioned that they need to find a bit more, but who doesn't after 2 FP sessions with limited running.
Of course he didn't mention anything about the team running different floor specs, but it will be interesting to see how they proceed with the rest of the weekend now. The Mexico floor seems to be throwing them off a bit, occasionally performing on certain sessions.
Developer of F1InsightsHub
Bill
Bill
f1isgood wrote:
21 Nov 2025, 15:48
basti313 wrote:
21 Nov 2025, 13:59
f1isgood wrote:
21 Nov 2025, 11:14
Its not suprising even in Mexico he was within 0.2 tenth of max on long runs on the medium,so on track were they are no high speed corners like Baku he can be closer to Max.but still we have to wait he still need to put every thing together the field is very close top 4 teams are on similar laptime.p8 worst case  may seem like bad result but putting everything into context is not bad.
basti313
basti313
32
f1isgood wrote:
21 Nov 2025, 15:48
basti313 wrote:
21 Nov 2025, 13:59
f1isgood wrote:
21 Nov 2025, 11:14
Yeah...was hoping for some cool theory... :cry:
Bill, come on! That can not be everything.
=P~
TNTHead
I hope for Yuki that P15 in FP2 was an anomaly.
It was nice seeing Yuki up there in FP1. Would be nice if he could wreak havoc on the competition. A double podium would be perfect. Not impressed by FP2. I don't see anything to fight with there. :?
#REPEALtheADUO
f1isgood
f1isgood
21 Nov 2025, 22:38
A 1-2 with Ferrari and Mercedes right behind would be perfect. But perfect doesn't exist this year now does it :D
tinuva
Aaaans Yuki out in the wet q1
Sent from my Pixel 8 using Tapatalk
euv2
euv2
Yeah, good job by Max, did what he could. The MCL becomes the biggest rocketship on drying intermediate conditions.
8 lap old inters on drying track...Gift wrapped to Mclaren. P2 is good for tomorrow. The GP should be dry.
#REPEALtheADUO
search
biggest problem was the timing, I think. The McLaren started their final lap at the very end, Sainz and Verstappen with around 1:30 to go.
euv2
euv2
search wrote:
22 Nov 2025, 08:11
Eh, that was the 2nd biggest problem. It's been a trend since the first race in Australia. Intermediates overheat very quickly if the racing line becomes dry and MCL is the best at keeping them in check whereas, RBR and MERC started losing pace relative to them.
