Aston Martin AMR23
Ashwinv16
Re: Aston Martin AMR23
Highest downforce rear wing among all teams (the new drs efficient wing) and two iteration of front wing, miami/baku style and the more loaded brazil style.
Halo not as bad as we thought
ThijsMuis
ThijsMuis
They're running the single plane beam wing too.
GoranF1
GoranF1
151
Bahrain spec engine cover apparently.
GoranF1 wrote:
16 Nov 2023, 18:14
16 Nov 2023, 18:59
GoranF1 wrote:
16 Nov 2023, 18:14
I'm convinced, It's the tightest one for the coolest races. They use the other one in hotter races. The other mods are just to vary the cooling ...more or less.
Changes to AMR front wing flaps for Abu Dhabi. Unclear if he means adjustments or a new part that they will declare in the documents
I understand that it is a camera on the to monitor the rear wing of the Aston Martin on the track.
This follows the sensor they had mounted to the rear-wing pylon @ Suzuka. They're clearly interested in monitoring something in this region - potentially rear-wing assembly deflection under load?
ThijsMuis
ThijsMuis
Ashwinv16
I am 90% sure the front wing and Rear wing is brand new.
Ashwinv16 wrote:
23 Nov 2023, 18:23
I'm aware you might have a good source of information for this given your past insights.. and I would agree that the front flaps look unfamiliar to me.
The rear-wing configuration on the other hand seems to be something that has been seen before. Looks like Stroll has his Miami wing without gurney flap and Alonso has his Miami wing
From @AMF1News on Twitter:
-wkst-
-wkst-
Ashwinv16 wrote:
23 Nov 2023, 18:23
And I am 100% sure, you are talking BS, as usual. RW was used in former races.
Talk from Fabrega could be that they change the top flap of the FW back to pre Vegas spec (top flap was updated there).
-wkst- wrote:
23 Nov 2023, 18:51
Ashwinv16 wrote:
23 Nov 2023, 18:23
What do you mean by that?
issey
issey
23 Nov 2023, 14:44
He just means they added flaps to the front wing for Abu Dhabis load requirements, Aston Martin often arrives in the paddock with a front wing where the flaps aren’t mounted yet. This FW was already used in Monza and Silverstone
-wkst-
-wkst-
23 Nov 2023, 18:52
-wkst- wrote:
23 Nov 2023, 18:51
Ashwinv16 wrote:
23 Nov 2023, 18:23
Just remember his "update-list" phantasy post on 25.10.2023. He has no clue regarding AMR.
