2026 F1 Cars - General Thread
Re: 2026 F1 Cars - General Thread
SealTheRealDeal wrote:
02 Feb 2026, 23:37
What? Passing is how you gain positions, and thereby increase your points. Cars with similar pace have every reason to try passing eachother.
I should have said "no mechanism", not "no reason". How should you drive around the person in front of you when you are not faster? What would be the mechanism? telekinesis? :lol:
#ReleasetheADUO
TeamKoolGreen
TeamKoolGreen
02 Feb 2026, 20:43
TeamKoolGreen wrote:
02 Feb 2026, 20:23
Anyway , some receipts are in about how these cars follow. And this was at shakedown speed :roll:
From the Race https://www.the-race.com/formula-1/what ... elations/
Haas driver Ollie Bearman said: "It was a bit more challenging to follow. It picked up quite a big shift in balance compared to clean air, which seemed a bit more so than the previous generation of cars."
Team-mate Ocon said: "You seem to lose quite a lot of front load, a bit more maybe than before."
Full Ocon quote
I've been following a few cars. You seem to lose quite a lot of front load, a bit more maybe than before. But we need to see. And the overtake, yes, I played with it. I don't want to give too early conclusions on how it's going to be, because obviously it needs to be adjusted, optimised, etc, for that to work in a perfect way. But so far it looks to be difficult to pass - that's my first first thought about it. But I hope it's going to get on the easier side.
However George Russell said
"Following definitely does seem easier, especially in the high-speed corners," he said. "It's firstly because you have less downforce, and you're going through the corners slower, so there is naturally less wake."
Of course they surgar coated it a bit in the end. But it is blatantly obvious what they were saying. Shift of balance and lose a lot of load is the operative words here.
And the whole Mercedes crew can't be trusted to be telling the truth. They wanted a flat floor because they couldn't figure out a venturi floor.
Again , it's just physics.
TeamKoolGreen
TeamKoolGreen
Another report
Driving stays intensely PHYSICAL
https://x.com/i/status/2018369385765781765
SealTheRealDeal
SealTheRealDeal
02 Feb 2026, 23:42
02 Feb 2026, 23:37
There are many ways to be situationally faster than the car ahead despite a tight field spread on average. There are many spec series with tons of passing. Returning to the example of 2021, the driver with the most overtakes that year was Seb, how can that be if field spread was the main factor in overtaking and the AMR21 was towards the back of that field spread?
ascinating insight from @GeorgeRussell63 Today on how the 2026 F1 cars have to be driven: "It's definitely challenging for the drivers, and you have instances when you go around the corners faster, you're spending more energy, and you're harvesting less. So you end up over the course of a lap having less energy to spend. So you may gain a few tenths into corners, but you may lose a couple of tenths in the straight. That takes a little bit of time just to get your head around it.
#ReleasetheADUO
johnnycesup
johnnycesup
03 Feb 2026, 01:33
:? How can anyone be happy about this? They've destroyed Formula 1...
I really doubt there could be a situation where that's the case, unless you're defending from someone and doing a Checo Perez AD 21 type of thing. Any other situation, you'd want to take the corners as fast as your car can do it
johnnycesup wrote:
03 Feb 2026, 01:39
03 Feb 2026, 01:33
It's a straight line speed Formula. It's no longer important to be quick in the corners. It's just important to recharge the battery so you don't lose out on the straights where even more lap time is lost from having a depleted battery. Exactly as Russell said.
This is such a fundamental paradigm shift. I'm baffled by how we got to this point. Horner was the only one who cared about the sport when he wanted them to reduce the electric output.
#ReleasetheADUO
johnnycesup
johnnycesup
03 Feb 2026, 01:45
johnnycesup wrote:
03 Feb 2026, 01:39
03 Feb 2026, 01:33
It's faster for the same battery recharge to spend an extra second doing a full recharge against the ICE in the straight (which would work similarly to lift and coast since the ICE is stronger than the MGUK) before the braking point and take the corners as usual, than to keep pushing that extra second and brake for a little longer and take the corner slower. One reason is that if you take a corner slower you have to spend energy to accelerate from a lower starting speed, alongside all the time you lost in the corner itself.
Now maybe this new formula makes certain driving styles more useful, like doing a "V" line instead of a "U" line .
TeamKoolGreen
TeamKoolGreen
More from Ocon
Overtaking looks “difficult” with 2026 F1 cars, Esteban Ocon warns
“I don't want to give too early conclusions on how it's going to be because obviously, you know, it needs to be adjusted, optimised, etc., for that to work in a perfect way. But so far, it looks to be difficult to pass. That's my first thought about it, but I hope it's going to get on the easier side.”
I just hope they made provisions for a small venturi but probably not. Maybe they'll just change the floor regs in a year or 2. The packaging will have to change. If the product is bad enough , they will have to change it. Everyone just took the 2022 cars for granted for the last 4 years.
It is all relative. If you thought the 2025 car was bad at following , throwing a flat floor on it would make it even worse. And that's where we are.
FittingMechanics
FittingMechanics
One video I saw of McLaren following (I think Piastri) he was right on the gearbox of the car ahead through the corner. Looked super close but maybe it was because of speed differential. I'd wait to see how all drivers see this and how it is in a real race. As we can see, Russell thinks it is easier (and he is an a good car).
We also might not need to have drivers super close in corners because they can use their energy in a different way.
I also don't get how 2025 regulations were good, it was 100% a clean air formula and whoever was ahead would just drive off.
TeamKoolGreen
TeamKoolGreen
FittingMechanics wrote:
03 Feb 2026, 09:21
There was literally no reason for any car to pass in 2025 because of the field spread. And there was still mid pack battles front wing to gearbox until someone made a mistake. You can kiss those goodbye. Nobody even remembers what real bad racing is.
And about that pesky thing called physics. If you thought the 2025 car was bad , putting a flat floor on it is going to make it worse.
FittingMechanics
FittingMechanics
03 Feb 2026, 17:44
Let's wait and see. My opinion is that the differences in potential energy usage will allow drivers to overtake, this should lead to some interesting tactical battles and unorthodox overtakes.
Badger
Badger
46
03 Feb 2026, 01:45
But we were told that when Horner pointed out these issues he was just trying to save himself from his own terrible engine project. Because shifting the "50/50" power split slightly would have made all the difference for RBPT apparently (don't ask for logic on that). It was Toto and the car manufacturers who were looking out for the fans and entertainment factor with their corporate mantras.
All this rhetoric about the "50/50" power split and "sustainable fuels", that was literally the point behind all of it, a marketing exercise. But now the marketing phase is over and reality is about to set in. I think there will disappointment as cars head down the straight in Q1 and start to harvest 250 meters before the corner.
Badger wrote:
03 Feb 2026, 20:08
03 Feb 2026, 01:45
https://www.autosport.com/f1/news/how-f ... /10794739/
They are already downshifting on the straights in Barcelona. :lol:
“There was obviously lots of chat around potentially having a downshift on the straights in some circumstances. That will probably continue to be the case, but it doesn't feel that abnormal to be honest. The way I would describe it is like if you're driving your car up a hill, you're still going flat out, but you're losing a bit of speed and you may just downshift to give you a bit of extra revs to get up that hill. That's how it sometimes feels when the engine is harvesting and you're regenerating the battery.
“So there are occasions that you can downshift at the end of the straight even while you're flat out, but it felt more bizarre in the simulator than it did in reality. I spoke with a few other drivers and they actually commented the same, so that was quite intuitive.”
#ReleasetheADUO
venkyhere
43
Badger wrote:
03 Feb 2026, 20:08
Which reminds me about a question I had when I came to know about F1 using 'sustainable fuels' and had forgotten to ask :
How is 'sustainable fuel' produced in a lab/factory purely from chemicals, 'helping to achieve carbon neutrality' ? It goes against entropy, doesn't it ? Unless we are talking of nuclear fuel, the amount of energy needed to break a bunch of chemical bonds from 'stable' raw materials and then create another bunch of chemical bonds and form a 'stable' product, in addition to the energy needed to 'extract' the raw materials from nature, all combined , has to be lesser than the 'oxidising exothermic chemical bond energy' present in the final product itself, for us to be even saying 'using an energy source'.
For fossil fuels, the 'raw materials' were already created by gravity and time. The same (to an extent) applies to biofuels created by bacteria and time, on animal/human/kitchen waste. So they are 'free'. In case of synthetic fuels, where does the raw material come from ? Shouldn't it be 'created as well' by spending energy in turn, by some factory ? (if that's not the case, all human knowledge about entropy will break).
So why is 'synthetic fuel' considered a savior of humanity ? I am unable to connect the dots and understand the meaning of 'sustainable'.
