2026 Drama: Alleged engine loophole
CHT
CHT
-7
Re: 2026 Drama: Alleged engine loophole
Rodak wrote:
12 Feb 2026, 22:45
Round and round and round we go....... If wishes were horses beggars would ride.
ICE is just 50% of the PU, the remaining 50% is going to play a bigger role this year
CrazyCarperF1
CrazyCarperF1
This engine drama quite possibly could be the most interesting part of F1 this year, it looks to me like the racing will be 11 teams fundamentally doing a time trial, they won't want to waste energy defending or attacking.
Martin Keene
Martin Keene
Hoffman900 wrote:
12 Feb 2026, 19:35
Pressure sensors aren’t going to show compression RATIO like you some of uou imagine it will. This has been spelled out several times in this thread.
How many of you actually have experience with these sensors and what they can show you? I do.
This, and this again!
A pressure sensor will show peak cylinder pressure, it will not show compression ratio.
Martin Keene wrote:
13 Feb 2026, 10:55
Hoffman900 wrote:
12 Feb 2026, 19:35
There are gas laws that relate pressure to cylinder volume. That the connection between cylinder pressure and compression ratio. There are some minor considerations like valve openings and the TJI to be mindful of, but it can be done.
Beware of T-Rex
Martin Keene
Martin Keene
No it can't. If you advance ignition timing it will increase PCP, but the compression ratio has not changed.
Martin Keene wrote:
13 Feb 2026, 11:01
Then don't advance the timing? You can practically take a hot engine, bump it with the MGU-K without any ignition and measure the pressures.
Beware of T-Rex
Martin Keene
Martin Keene
The point with the comment about the ignition timing is there any many many factors that effect cylinder pressure, the compression ratio, which is a ratio of the geometry of the cylinder at BDC vs TDC is of those many many factors.
Hoffman900
Hoffman900
243
13 Feb 2026, 11:03
Martin Keene wrote:
13 Feb 2026, 11:01
That’s not how it works at all, as has been explained by myself, Martin, and others. If people don’t know how something works, that’s okay, you learn. This place, people just double down and argue topics that they obviously have no idea what they’re talking about.
Mercedes teams are running the agenda really hard. They can't stop talking about Red Bull :lol:
It looks like it's going to a vote and they want to fool FOM.
Beware of T-Rex
f1isgood
f1isgood
Russell saying Red Bull have 1s per lap left...
gearboxtrouble
gearboxtrouble
This still sounds like deflection from Mercedes engined teams. For me to really start believing a brand new engine manufacturer have at the first time of asking produced an engine thats materially ahead of everyone else who’s been at this for decades I would need to see the other manufacturers say the same things. Ferrari, Audi and Honda haven’t said anything about this advantage RBPT allegedly have and are still very much focused on the Mercedes CR hack. RBPT have probably produced an engine thats in the ballpark of competitive and that by itself is the best engine supplier debut I’ve ever seen in my 35 years of watching F1. Them being noticeably ahead would be science fiction.
13 Feb 2026, 14:49
Albon, sainz, Norris, Russell have all come out and spoken about red bulls power unit. Haha.
SB15
SB15
13 Feb 2026, 16:14
13 Feb 2026, 14:49
After Redbull switched sides, I don't blame them :lol: :lol:
venkyhere
45
13 Feb 2026, 16:14
13 Feb 2026, 14:49
Don't the teams know that people will figure out PR-trained-parrots ? How desperate are they ? (I am imagining a godfather1 ending scene analogy where we catch a glimpse of Vowles,Brown,Briatore gathering around Toto and kissing his hand, as James Allison closes the door).
"Please, please, we are the underdogs, believe me"
game has started even before 1st race, hasn't it ? Naaaaiiiceeely duunnnnn....
vorticism
vorticism
449
Hoffman900 wrote:
12 Feb 2026, 19:35
Nor will the gas displacement method you are advocating necessarily measure it, which presumably measures gas displaced by the piston between TDC and IVC and/or EVO, or maybe it's comparing compression through that same region. If the latter, it's doing what you say can't be done. Those methods will resolve a certain definition of 'compression ratio,' but that's not necessarily what the FIA aims to inspect. They aim to inspect the GCR which is, I would say, independent from valve timing--a geometric figure, not always derivable from a comparison of gas volumes, gas flow, nor a comparison of pressure changes. How they define GCR is important, and we don't know what their definition is.
Martin Keene wrote:
13 Feb 2026, 11:01
He's talking about cold cranking the ICE. Ignition is irrelevant. A certain definition of CR can be deduced by comparing pressure changes between valve closing and TDC. That's unavoidable.
13 Feb 2026, 10:58
This is fundamentally correct although it won't necessarily provide the GCR owing to variables such as valve timing (as you say), among others. Ideally the valves can be kept closed through 180* either side of TDC, but if the cams can't supply that, you need some other method. Disconnecting the cam gears would be too time consuming. If they're measuring at the track it's presumably an in-situ type of measurement, not an engine teardown.
So what's left?
They could be defining GCR as "compression/expansion between TDC and valve opening" ie "observed compression regardless of valve timing" in which case they are ignoring GCR in the sense of a true comparison of the total volume at BDC with the total volume at TDC. In which case it becomes easier to measure.
If the engine is disassembled then piston travel and the CC can be inspected with probes and optics. This could be cross-referenced to CAD. CAD might be necessary if there are inaccessible voids, as is being suggested. Such voids, including something like a TJI, would make measurement with fluids difficult. Invert head, fill, wait for air bubbles to escape... seems unlikely.
Using a band saw to inspect inaccessible voids would be a non-starter. The concept of an "unmeasurable CC" is interesting to consider in this context.
